CFSENSOR XGZP6847D Pressure Sensor USing Problems
Need your help when using XGZP6847D Pressure sensor
Your topic does not indicate a problem with ODE 1.x and hence has been moved to a more suitable location on the forum.
Maybe something in these search results will help: arduino XGZP6847D - Google Search
Thank you, I am just collect the problems the people using XGZP6847
This might help if we knew EXACTLY which sensor you have:
https://cfsensor.com/wp-content/uploads/2022/11/XGZP6847D-Pressure-Sensor-V2.5.pdf
Do you use XGZP6847D?
Sorry, I don't, but if I did, I would have learned how to use it before I bought it. :wink:
Where did you buy yours?
There is a library:
https://www.arduino.cc/reference/en/libraries/xgzp6897d/
that can be used with the XGZP6847D pressure sensor.
You could try using one of the examples that comes with the library.
You can tell me which one you need, about the pressure range.
Do you use XGZP6847D with arduino?
I can offer you our document based on Arduino
