Ch376msc.h library wont write me a file
Using the USB reader - writer for the first time. I am trying to log some machine activity in a CSV
I got the hardware to work, I get the "Flash drive attached!".
I am using the hardware serial example from the library with an arduino mega on Serial3.
I went through all examples 1,2,3 etc and the serial feedback was fine, however when I eject the usb stick I find no file created on it. It is a 8g formatted as FAT32.
Shoulnt I see the TEST1.TXT in the root? I plugged it in a win10 pc and a mac os12.
Nothing,
What am I doing wrong?
here is my sketch
 *    Author: György Kovács        |
 *    Created: 28 Mar 2019        |
 *    Description: Basic usage of CH376 with hardware serial                                                        |
 *    Thanks for the idea to Scott C , https://arduinobasics.blogspot.com/2015/05/ch376s-usb-readwrite-module.html  |
#include <Ch376msc.h>
// Leave the default jumper settings for the baud rate (9600) on the CH376, the library will set it up the chosen speed(HW serial only)
Ch376msc flashDrive(Serial3, 115200); // Ch376 object with hardware Serial1 on arduino mega baudrate: 9600, 19200, 57600, 115200
 // buffer for reading
char adatBuffer[255];// max length 255 = 254 char + 1 NULL character
// strings for writing to file
char adat[]="Vivamus nec nisl molestie, blandit diam vel, varius mi. Fusce luctus cursus sapien in vulputate.\n";
char adat2[] = "Lorem ipsum dolor sit amet, consectetur adipiscing elit. Duis efficitur ac est eu pharetra. \n";
unsigned long totSect = 0;
unsigned long freeSect = 0;
byte percentg = 0;
byte tmpCommand; //used to store data coming from serial port
boolean readMore;
static char helpString[]= {"h:Print this help\n\n1:Create\n2:Append\n3:Read\n4:Read date/time\n"
            "5:Modify date/time\n6:Delete\n7:List dir\n8:Print free space"
            "\n9:Open/Create folder(s)/subfolder(s)"};
  flashDrive.init();
  printInfo(helpString);
	if(flashDrive.checkIntMessage()){
		if(flashDrive.getDeviceStatus()){
			Serial.println(F("Flash drive attached!"));
			Serial.println(F("Flash drive detached!"));
  if(Serial.available()){
    tmpCommand = Serial.read();                      //read incoming bytes from the serial monitor
    if(((tmpCommand > 48)&&(tmpCommand < 58)) && !flashDrive.driveReady()){ // if the data is ASCII 1 - 9 and no flash drive are attached
       printInfo("Attach flash drive first!");
      tmpCommand = 10; // change the command byte
     switch (tmpCommand) {
      case 49: //1
        printInfo("COMMAND1: Create and write data to file : TEST1.TXT");    // Create a file called TEST1.TXT
          flashDrive.setFileName("TEST1.TXT");  //set the file name
          flashDrive.openFile();                //open the file
          for(int a = 0; a < 20; a++){          //write text from string(adat) to flash drive 20 times
            flashDrive.writeFile(adat, strlen(adat)); //string, string length
          flashDrive.closeFile();               //at the end, close the file
        printInfo("Done!");
      case 50: //2
        printInfo("COMMAND2: Append data to file: TEST1.TXT");               // Append data to the end of the file.
        if(flashDrive.openFile() == ANSW_USB_INT_SUCCESS){               //open the file
        	flashDrive.moveCursor(CURSOREND);     //if the file exist, move the "virtual" cursor at end of the file, with CURSORBEGIN we actually rewrite our old file
        	//flashDrive.moveCursor(flashDrive.getFileSize()); // is almost the same as CURSOREND, because we put our cursor at end of the file
        	if(flashDrive.getFreeSectors()){ //check the free space on the drive
        		flashDrive.writeFile(adat2, strlen(adat2)); //string, string length
           Serial.println (adat2);
        		printInfo("Disk full");
        printInfo("Done!");
      case 51: //3
        printInfo("COMMAND3: Read File: TEST1.TXT");                         // Read the contents of this file on the USB disk, and display contents in the Serial Monitor
        readMore = true;
                //read data from flash drive until we reach EOF
        while(readMore){ // our temporary buffer where we read data from flash drive and the size of that buffer
        	readMore = flashDrive.readFile(adatBuffer, sizeof(adatBuffer));
        	Serial.print(adatBuffer);          //print the contents of the temporary buffer
        printInfo("Done!");
      case 52: //4
        printInfo("COMMAND4: Read File date/time: TEST1.TXT");      // Read the date and time of file, default 2004.01.01 - 00:00:00
                //print informations about the file
          Serial.println(flashDrive.getFileName());
          Serial.print(flashDrive.getYear());
          Serial.print("y\t");
          Serial.print(flashDrive.getMonth());
          Serial.print("m\t");
          Serial.print(flashDrive.getDay());
          Serial.print("d\t");
          Serial.print(flashDrive.getHour());
          Serial.print("h\t");
          Serial.print(flashDrive.getMinute());
          Serial.print(flashDrive.getSecond());
          Serial.println('s');
        printInfo("Done!");
      case 53: //5
        printInfo("COMMAND5: Modify File date/time: TEST1.TXT");    // Modify the file date/time and save
          flashDrive.setYear(2019);
          flashDrive.setMonth(12);
          flashDrive.setDay(19);
          flashDrive.setHour(03);
          flashDrive.setMinute(38);
          flashDrive.setSecond(42);
          flashDrive.saveFileAttrb();           //save the changed data
        flashDrive.closeFile();               //and yes again, close the file after when you don`t use it
        printInfo("Done!");
      case 54: //6
        printInfo("COMMAND6: Delete File: TEST1.TXT");                       // Delete the file named TEST1.TXT
        flashDrive.deleteFile();              //delete file
        printInfo("Done!");
      case 55: //7
        printInfo("COMMAND7: List directory");                          //Print all file names in the current directory
          while(flashDrive.listDir()){ // reading next file
            if(flashDrive.getFileAttrb() == CH376_ATTR_DIRECTORY){//directory
              Serial.print('/');
              Serial.println(flashDrive.getFileName()); // get the actual file name
              Serial.print(flashDrive.getFileName()); // get the actual file name
              Serial.print(" : ");
              Serial.print(flashDrive.getFileSize()); // get the actual file size in bytes
              Serial.print(" >>>\t");
              Serial.println(flashDrive.getFileSizeStr()); // get the actual file size in formatted string
          printInfo("Done!");
      case 56: //8
    	  totSect = flashDrive.getTotalSectors(); // get the total sector number
    	  freeSect = flashDrive.getFreeSectors(); // get the available sector number
    	  percentg = map(freeSect,totSect,0,0,100); 		// convert it to percentage (0-100)
    	  Serial.print("Disk size in bytes: ");
    	  /*if the sector number is more than 8388607 (8388607 * 512 = 4294966784 byte = 4Gb (fits in a 32bit variable) )
    	    							 e.g. 8388608 * 512 = 4294967296 byte (32bit variable overflows) */
    	  if(totSect > 8388607){
    		  Serial.print(">4Gb");
        	  Serial.print(totSect * SECTORSIZE);
    	  Serial.print("\tFree space in bytes: ");
    	  if(freeSect > 8388607){
        	  Serial.print(freeSect * SECTORSIZE);
    	  Serial.print(F("\tDisk usage :"));
    	  Serial.print(percentg);
    	  Serial.print(F("%"));
    	  switch (flashDrive.getFileSystem()) { //1-FAT12, 2-FAT16, 3-FAT32
			case 1:
				Serial.println(F("\tFAT12 partition"));
			case 2:
				Serial.println(F("\tFAT16 partition"));
			case 3:
				Serial.println(F("\tFAT32 partition"));
			default:
				Serial.println(F("\tNo valid partition"));
      case 57: //9
        switch(flashDrive.cd("/DIR1/DIR2/DIR3",1)){
          case CH376_ERR_LONGFILENAME: //0x01
            Serial.println(F("Directory name is too long"));
          case ANSW_USB_INT_SUCCESS: //0x14
          Serial.println(F("Directory created successfully"));
          case ANSW_ERR_OPEN_DIR: //0x41
          Serial.println(F("Directory opened successfully"));
          case ANSW_ERR_MISS_FILE: //0x42
          Serial.println(F("Directory doesn't exist"));
          case ANSW_ERR_FOUND_NAME: //0x43
          Serial.println(F("File exist with the given name"));
          default:
      case 104: //h
      default:
    }//end switch
  }//endif serial available
}//end loop
//Print information
void printInfo(const char info[]){
  int infoLength = strlen(info);
  if(infoLength > 40){
    infoLength = 40;
    Serial.print(F("\n\n"));
    for(int a = 0; a < infoLength; a++){
      Serial.print('*');
   Serial.println(info);
      Serial.print('*');
thanks a lot,
Mitch
Did you forget to skip Test 6 where you delete the file?
Thanks John,
I pulled the stick out after step 2 to verify the file, and nothing was written.
Are you receiving the expected messages for each test?
yes, look after step one.
Screen Shot 2022-08-23 at 9.12.24 AM
Also look what the USB looks like in explorer,
Thanks
the USB host seems to see the file, but the PC wont,
Screen Shot 2022-08-23 at 4.07.18 PM
It's a mystery. I don't see anything to explain why the content of the thumb drive looks different on the two devices. Maybe the drive has multiple partitions, one of which works on your Arduino and one of which works on your PC. I don't know how you would check for that.
https://github.com/djuseeq/Ch376msc#firmware-difference
It was in the hardware. I tried a different unit and it writes the file.
Still a mystery, how come the Arduino sees the file but the PC wont....
Thanks John
ZX80 ,
The problem went away and now is back. The files written by arduino are not read by windows.
The windows files are not read by arduino...
So I downloaded the
Active@ Partition Manager
and made a new partition. Now files are visible by windows.
The problem is that I cant deliver this to my customer... Sounds like a mickey mouse solution to have to have a third party software for formatting.
So I wonder if you know of a good 8 G USB drive (What brand?) that will work .
Thanks
Mitch
