Hello!
Im working on a micro controlled mosfet for my airsoft gun, the idea is to have different shooting modes like.. Single, burst and full auto.
My problem is i can't figure out what code i should use to switch between this modes... i have tried if-statements but doesnt work that good..
when im changing to burst mode and presses the trigger button the motor start spins like hell.. but single works just fine ![]()
so if any one could give me and example of working code to change between different modes i would appreciate it very much!
const int TriggerPin = 7; //Trigger switch attached to digital pin 7
const int ButtonPin = 4; // Change Modes
const int ledPin = 13; //onboard LED on pin 13
const int MotorPin = 3; //Motor drive pin (on MOSFET) connected to PWM pin at pin 3
const int MotorSpeed = 255; //PWM value for motor, max 255
const int SelectorPin = 8; //Selector Pin
const float CurveThresh = -4; //negative slope detection threshold
const int IRD = 110; //In Rush Delay in milliseconds to deal with in-rush motor startup current
const int Debounce = 50; //Standard Debounce delay
const float SpringSense = 4; //spring compression slope detection threshold
int switchPin = 2; // switch is connected to pin 2
int led1 = 12;
int led2 = 11;
int led3 = 10;
int val; // variable for reading the pin status
int val2; // variable for reading the delayed status
int buttonState; // variable to hold the button state
int PowerCurve[7]; //initialize the power curve array size 8
float CurvePoint; //CurvePoint will be compared to CurveThresh to determine if the spring is in free-fall
int fireTime = 0;
int TriggerState = 0; // Trigger button state
int ModeState = 0;
int FireMode = 0; //Firing mode of the gearbox. 0 is always safe, 1 is always singleshot
volatile int IMain = 0; // Direct ADC reading from current sensor
int BurstSetting = 3; //The number of rounds in a burst
Serial.begin(115200); //High output serial for testing
pinMode(MotorPin, OUTPUT);
analogWrite(MotorPin, 0); //make sure the motorpin is off
pinMode(TriggerPin, INPUT);
pinMode(ButtonPin, INPUT);
digitalWrite(2, HIGH); //Turn on the internal pull-up on digital 2
pinMode(switchPin, INPUT); // Set the switch pin as input
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
pinMode(led3, OUTPUT);
buttonState = digitalRead(switchPin); // read the initial state
void loop(){
val = digitalRead(switchPin);
delay(10);
val2 = digitalRead(switchPin);
if (val == val2) {
if (val != buttonState) {
if (val == LOW) {
if (FireMode == 0) {
FireMode = 1;
if (FireMode == 1) {
FireMode = 2;
if (FireMode == 2) {
FireMode = 3;
if (FireMode == 3)
FireMode = 0;
buttonState = val; // save the new state in our variable
// Now do whatever the FireMode indicates
if (FireMode == 0)
{ // all-off
digitalWrite(led1, LOW);
digitalWrite(led2, LOW);
digitalWrite(led3, LOW);
if (FireMode == 1)
{ // Single
digitalWrite(led1, HIGH);
delay(100);
delay(100);
TriggerState = digitalRead(TriggerPin);
if (TriggerState == HIGH)
SINGLESHOT();
if (FireMode == 2)
{ // Burst
digitalWrite(led2, HIGH);
delay(100);
delay(100);
BURST(BurstSetting);
if (FireMode == 3)
{ // full auto
digitalWrite(led3, HIGH);
delay(100);
delay(100);
FULLAUTO();
