Change code from wifi to ethernet
Compilation error: HTTPSClient.h: No such file or directory
Using an arduino uno r3 and keep getting this error on compilation
#include <SPI.h>
#include <MFRC522.h>
//#include <WiFi.h>
[quote="kenb4, post:5, topic:1269098"]
#include "Network.h
#include <HTTPClient.h>
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
#include <driver/adc.h>
#include <Wire.h>
A UNO R3 has NO WiFi, so there can't be an HTTPS. Post ALL code in code tags so we can test.
Sorry. New here. What are code tags?
Hopefully I did the code tag right. Sorry if not.
Below is my code foe use with wifi. How do I change this so it uses ethernet?
// Feel free to use it if you subscribed to this channel: https://www.youtube.com/channel/UCWE70GK4SaYz1dxMMN0TzkQ
// The tutorial video is available here https://youtu.be/xeHBKi0GLow
//Tested with Arduino IDE 2.1.0
//Arduino core for the ESP32 2.0.7
//You need to install these libraries
//https://github.com/miguelbalboa/rfid
//https://gitlab.com/joearmstrong980/LCD_I2C
#include <SPI.h>
//#include <WiFi.h>
`#include "Network.h`
#include <Wire.h>
#define SS_PIN 15
#define RST_PIN 13
#define BUZZ_PIN 4
#define BUZZ_CHANNEL 2
#define DOOR_PIN 2
#define TERMINAL_NAME  "basement"
// SCRIPT LINK MUST BE LIKE THIS "https://script.google.com/macros/s/AKfycbzBCsPz3ZDVUkdP7mloaX1AAKI1mC_NxM802hvDNRwyE4vw4oo/exec"
const char *https://script.google.com/macros/s/AKfycbzVTvQl9W1FdLTA-dtjvwiYJto8NlYBCOeTGpzSTcvVpLQ0A2muMyqEZ8uvRdF1lpF_/exec = "";
const char *James2011 = "wifi name";
const char *Ftwayne2014 = "password";
LiquidCrystal_I2C lcd(0x27, 16, 2);
MFRC522 mfrc522(SS_PIN, RST_PIN);
MFRC522::StatusCode status;
//#define DISABLE_WRITTING
// #define OTA
uint64_t clearDisplayTimer=0;
bool needDisplayUpdate=true;
//  WiFiClientSecure client;
const char *root_ca =
"-----BEGIN CERTIFICATE-----\n" \
"MIIFVzCCAz+gAwIBAgINAgPlk28xsBNJiGuiFzANBgkqhkiG9w0BAQwFADBHMQsw\n" \
"CQYDVQQGEwJVUzEiMCAGA1UEChMZR29vZ2xlIFRydXN0IFNlcnZpY2VzIExMQzEU\n" \
"MBIGA1UEAxMLR1RTIFJvb3QgUjEwHhcNMTYwNjIyMDAwMDAwWhcNMzYwNjIyMDAw\n" \
"MDAwWjBHMQswCQYDVQQGEwJVUzEiMCAGA1UEChMZR29vZ2xlIFRydXN0IFNlcnZp\n" \
"Y2VzIExMQzEUMBIGA1UEAxMLR1RTIFJvb3QgUjEwggIiMA0GCSqGSIb3DQEBAQUA\n" \
"A4ICDwAwggIKAoICAQC2EQKLHuOhd5s73L+UPreVp0A8of2C+X0yBoJx9vaMf/vo\n" \
"27xqLpeXo4xL+Sv2sfnOhB2x+cWX3u+58qPpvBKJXqeqUqv4IyfLpLGcY9vXmX7w\n" \
"Cl7raKb0xlpHDU0QM+NOsROjyBhsS+z8CZDfnWQpJSMHobTSPS5g4M/SCYe7zUjw\n" \
"TcLCeoiKu7rPWRnWr4+wB7CeMfGCwcDfLqZtbBkOtdh+JhpFAz2weaSUKK0Pfybl\n" \
"qAj+lug8aJRT7oM6iCsVlgmy4HqMLnXWnOunVmSPlk9orj2XwoSPwLxAwAtcvfaH\n" \
"szVsrBhQf4TgTM2S0yDpM7xSma8ytSmzJSq0SPly4cpk9+aCEI3oncKKiPo4Zor8\n" \
"Y/kB+Xj9e1x3+naH+uzfsQ55lVe0vSbv1gHR6xYKu44LtcXFilWr06zqkUspzBmk\n" \
"MiVOKvFlRNACzqrOSbTqn3yDsEB750Orp2yjj32JgfpMpf/VjsPOS+C12LOORc92\n" \
"wO1AK/1TD7Cn1TsNsYqiA94xrcx36m97PtbfkSIS5r762DL8EGMUUXLeXdYWk70p\n" \
"aDPvOmbsB4om3xPXV2V4J95eSRQAogB/mqghtqmxlbCluQ0WEdrHbEg8QOB+DVrN\n" \
"VjzRlwW5y0vtOUucxD/SVRNuJLDWcfr0wbrM7Rv1/oFB2ACYPTrIrnqYNxgFlQID\n" \
"AQABo0IwQDAOBgNVHQ8BAf8EBAMCAYYwDwYDVR0TAQH/BAUwAwEB/zAdBgNVHQ4E\n" \
"FgQU5K8rJnEaK0gnhS9SZizv8IkTcT4wDQYJKoZIhvcNAQEMBQADggIBAJ+qQibb\n" \
"C5u+/x6Wki4+omVKapi6Ist9wTrYggoGxval3sBOh2Z5ofmmWJyq+bXmYOfg6LEe\n" \
"QkEzCzc9zolwFcq1JKjPa7XSQCGYzyI0zzvFIoTgxQ6KfF2I5DUkzps+GlQebtuy\n" \
"h6f88/qBVRRiClmpIgUxPoLW7ttXNLwzldMXG+gnoot7TiYaelpkttGsN/H9oPM4\n" \
"7HLwEXWdyzRSjeZ2axfG34arJ45JK3VmgRAhpuo+9K4l/3wV3s6MJT/KYnAK9y8J\n" \
"ZgfIPxz88NtFMN9iiMG1D53Dn0reWVlHxYciNuaCp+0KueIHoI17eko8cdLiA6Ef\n" \
"MgfdG+RCzgwARWGAtQsgWSl4vflVy2PFPEz0tv/bal8xa5meLMFrUKTX5hgUvYU/\n" \
"Z6tGn6D/Qqc6f1zLXbBwHSs09dR2CQzreExZBfMzQsNhFRAbd03OIozUhfJFfbdT\n" \
"6u9AWpQKXCBfTkBdYiJ23//OYb2MI3jSNwLgjt7RETeJ9r/tSQdirpLsQBqvFAnZ\n" \
"0E6yove+7u7Y/9waLd64NnHi/Hm3lCXRSHNboTXns5lndcEZOitHTtNCjv0xyBZm\n" \
"2tIMPNuzjsmhDYAPexZ3FL//2wmUspO8IFgV6dtxQ/PeEMMA3KgqlbbC1j+Qa3bb\n" \
"bP6MvPJwNQzcmRk13NfIRmPVNnGuV/u3gm3c\n" \
"-----END CERTIFICATE-----\n" \
void dualPrint(const __FlashStringHelper* text)
  lcd.print(text);
  Serial.println(text);
// piezo buzzer beep
void beep(int count=1)
ledcSetup(BUZZ_CHANNEL, 5000, 10);
ledcAttachPin(BUZZ_PIN, BUZZ_CHANNEL);
for (size_t j = 0; j < count; j++)
  /* code */
  if(j!=0)
  delay(300);
  for (int i = 200; i < 1000; i++)
    ledcWrite(BUZZ_CHANNEL, i);
    delayMicroseconds(30);
  ledcWrite(BUZZ_CHANNEL, 0);
  ledcDetachPin(BUZZ_PIN);
  pinMode(BUZZ_PIN,INPUT);
//sample action
void openDoor()
  digitalWrite(DOOR_PIN,HIGH);
  delay(2000);
  digitalWrite(DOOR_PIN,LOW);
 pinMode(DOOR_PIN, OUTPUT);
  lcd.init();
  // Print a message to the LCD.
  lcd.backlight();
  lcd.setCursor(0, 0);
  lcd.print("Connecting wifi");
  lcd.setCursor(0, 1);
  Serial.begin(115200); // Initialize serial communications with the PC
  while (!Serial);
  SPI.begin();        // Init SPI bus
  mfrc522.PCD_Init(); // Init MFRC522
  WiFi.begin(ssid, password);
  Serial.println(F("Connecting wifi"));
  byte printedDots=0;
  while (WiFi.status() != WL_CONNECTED)
    Serial.print(".");
      if(printedDots++>15)
      for(;printedDots>=1;printedDots--)
        lcd.setCursor(printedDots,1);
        lcd.print(' ');
      lcd.setCursor(1,1);
    printedDots=1;
    lcd.print(".");
  lcd.clear();
  lcd.setCursor(0,0);
  Serial.println("");
 dualPrint(F("WiFi connected"));
  lcd.setCursor(0,1);
#ifdef OTA
  ArduinoOTA
      .onStart([]() {
        String type;
        if (ArduinoOTA.getCommand() == U_FLASH)
          type = "sketch";
        else // U_SPIFFS
          type = "filesystem";
        // NOTE: if updating SPIFFS this would be the place to unmount SPIFFS using SPIFFS.end()
        Serial.println("Start updating " + type);
      .onEnd([]() {
        Serial.println("\nEnd");
      .onProgress([](unsigned int progress, unsigned int total) {
        Serial.printf("Progress: %u%%\r", (progress / (total / 100)));
      .onError([](ota_error_t error) {
        Serial.printf("Error[%u]: ", error);
        if (error == OTA_AUTH_ERROR)
          Serial.println("Auth Failed");
        else if (error == OTA_BEGIN_ERROR)
          Serial.println("Begin Failed");
        else if (error == OTA_CONNECT_ERROR)
          Serial.println("Connect Failed");
        else if (error == OTA_RECEIVE_ERROR)
          Serial.println("Receive Failed");
        else if (error == OTA_END_ERROR)
          Serial.println("End Failed");
  ArduinoOTA.begin();
#endif
  //lcd.clear();
  lcd.print("Ready");
  beep(2);
void clearDisplayIn(int mSec=5000)
   clearDisplayTimer=millis()+mSec;
void handleDataFromGoogle(String data)
  int colonIndex = data.indexOf(":");
  String accessType = data.substring(0, colonIndex);
  int nextColonIndex = data.indexOf(":", colonIndex + 1);
  String name = data.substring(colonIndex + 1, nextColonIndex);
  String text = data.substring(nextColonIndex + 1, data.length());
  lcd.setCursor(0,0);
  lcd.print("Hi ");
  lcd.print(name);
  lcd.setCursor(0,1);
  lcd.print(text);
  if(accessType.equalsIgnoreCase("beep"))
    beep(5);
  else if(accessType.equalsIgnoreCase("door"))
    openDoor();
void getGoogleData()
  HTTPClient http;
  String data;
  lcd.clear();
  uint64_t time = esp_timer_get_time();
  char url[150];
  int pointerShift=sprintf(url,"%s?uid=",mainLinkForSpr);
for (size_t i = 0; i < mfrc522.uid.size; i++)
    pointerShift+=sprintf(url+pointerShift,"%X",mfrc522.uid.uidByte[i]);
#ifdef TERMINAL_NAME
 pointerShift+=sprintf(url+pointerShift,"&terminal=%s",TERMINAL_NAME);
#endif
Serial.println(url);
Serial.println(F("Connecting to google"));
lcd.print(F("Connecting to"));
lcd.setCursor(7,1);
lcd.print(F("Google"));
//you need to make two request, the second request to a redirected url
//to get redirect url you need to read "Location" header
http.begin(url, root_ca);
  const char *location = "Location";
  const char *headerKeys[] = {location};
  http.collectHeaders(headerKeys, 1);
  int code = http.GET();
  Serial.printf("code %d\n", code);
  // 302 code means redirect
  if (code == 302)
    String newUrl = http.header(location);
    http.end();
    Serial.println(newUrl);
    http.begin(newUrl, root_ca);
    code = http.GET();
    Serial.printf("status code %d\n", code);
    data=http.getString();
    Serial.println(data);
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    // lcd.print("ready to wrt for");
    // lcd.print(res);
    else{
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print(code);
    if (code == 403|| code==-1)
      lcd.clear();
    lcd.setCursor(0,0);
    lcd.print(F("Err open terminl"));
    lcd.setCursor(0,1);
    lcd.print("for help");
    if(code==-1){
Serial.println(F("If it says somethink like start_ssl_clien error"));
Serial.print(F("try to update the ssl CERTIFICATE"));
    else{
    Serial.print(F("Open this link in any browser "));
    Serial.println(F("If it says Authorization is ...."));
    Serial.println(F("Open the google script and republish it"));
    else{
    lcd.print(F("Something wrong"));
    lcd.setCursor(0,1);
      if(!data.isEmpty() && data.length()>1)
             handleDataFromGoogle(data);
  Serial.printf("time=%d\n", esp_timer_get_time() - time);
  clearDisplayIn();
if(needDisplayUpdate && millis()>clearDisplayTimer)
  lcd.clear();
  lcd.setCursor(1,1);
  lcd.print("Ready To Scan");
  needDisplayUpdate=false;
  lcd.noBacklight();
  //clearDisplayIn(1000);
#ifdef OTA
  ArduinoOTA.handle();
#endif
  if (!mfrc522.PICC_IsNewCardPresent())
    return;
  // Select one of the cards
  if (!mfrc522.PICC_ReadCardSerial())
    return;
beep();
lcd.backlight();
  Serial.printf("%X",mfrc522.uid.uidByte[i]);
getGoogleData();
  mfrc522.PICC_HaltA();
  // Stop encryption on PCD
  mfrc522.PCD_StopCrypto1();
  beep();
Better than before, but still not good.
This line isn't code.
And your original post is still wrong. Please edit it and fix that.
Uno R3 doesn't have ethernet either. Unless maybe you have an ethernet shield? What model?
R3 and I have a shield for it.
The forum can't help if you keep secrets.
Your first post is still breaking forum rules.
You know, I'm here for help, not ridicule.. Good-bye
I was beginning to think you might be a troll. Thanks for confirming, and thanks for wasting no more of the forum's time.
