I've been trying to burn a bootloader set to run @8MHZ and 1.8v Brown out to 1.8v.
What happens is.. doesn't matter what I do.. it always burn the same bootloader..
OptiLoader Bootstrap programmer.
2011 by Bill Westfield (WestfW)
Target power on! ...
Starting Program Mode [OK]
Reading signature:950F
Searching for image...
Found "optiboot_atmega328.hex" for atmega328P
Start address at 7E00
Total bytes read: 502
Setting fuses for programming
Lock: 3F FFE000 Low: FF FFA000 High: DE FFA800 Ext: 5 FFA400
Programming bootloader: 512 bytes at 0x3F00
Commit Page: 3F00:3F00
Commit Page: 3F40:3F40
Commit Page: 3F80:3F80
Commit Page: 3FC0:3FC0
Restoring normal fuses
Lock: 2F FFE000
Target power OFF!
Type 'G' or hit RESET for next chip
You can see the fuse settings..
How are you burning the bootloader? What are you using for a Programmer?
If you do it using the IDE with the fuse changes in boards.txt, that will change them.
1 - Open my arduino uno, compile the OptiLoader.
2 - I wire the target Atmega328p-PU chip to the OptiLoader chip
3 - I open IDE, open the Serial Monitor and I receive:
Lock: 2F FFE000
Target power OFF!
Its ok!..
Now I go to the folder:
C:\Users\username\Documents\Arduino\hardware\optiboot
open boards.txt
Since I have the fuse settings from my default bootloader(now aptiboot) working without Cristal, I used the settings on this optiboot.
Well.. changed the optiboot low fuses and hi fuses like:
to:
atmega328o.bootloader.low_fuses=0xE2
atmega328o.bootloader.high_fuses=0xD8
4 - I save the settings on boards.txt file
5 - I close and open IDE again and open Serial monitor and burn the bootloader again.. but I get the SAME FUSE VALUES
its like don't matter how much I cange teh boards.txt file it doesn't change the way the fuses are burned.
Result after changing boards.txt:
Lock: 2F FFE000
Target power OFF!
I have done everything and created the optiboot_atmega328_384_8.hex etc...
But when I open the Arduino IDE and open de serial Monitor it burns the bootloader but not the one I selected on TOOLS > BOARDS.. It always burn the optiboot_atmega328.hex and no the optiboot_atmega328_384_8.hex..
I don't think you understand how "optiloader" works.
Optiloader is a stand-alone bootloader programmer with internal copies of the desirable fuses and the optiboot binary (rather old, by now.) It was intended to speed up the sort process of "I want to upgrade all my pre-uno Arduinos to the faster smaller bootloader."
It doesn't pay ANY attention to boards.txt, or any of the .hex files that might exist in various directories on your computer. Unless you've edited the optiloader source code itself, it's always going to burn the same bootloader and fuses into the target chips.
If you're using optiloader, you're NOT using "Arduino as ISP." It sounds like you should load ArdinoISP into your arduino and use the "burn bootloader" menu command.
