Greetings to everyone. Please consider me a "NOOB" on this, so be patient ![]()
I have a project, i want to build a device that let me turn on/off devices remotly. So with an arduino uno R3 + ethernet shield (esp8266 based) i want to build a web server, with a basic authentication (usr/pass) and manage 2 relays; i have done that part, i have a functional device.
But now, i want to go for more, and im stuck. I want to change IP, MASK, Gateway and, occasionally the mac address,... and if I can user and password too, like a low price router o network device.
So i found some code on this forum, i just forgot the relay control part and im only triying to success with the IP change from the HTML code (web server). I have found the eeprom.h library, and a some code, but the post chance was closed (topic: 120 days old).
I will left the code i adapted and the error im receiving...
Sketch:
#include <EEPROM.h>
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0x54, 0x34, 0x41, 0x30, 0x30, 0x31 };
IPAddress ip(192, 168, 1, 250);
IPAddress subnet(255, 255, 254, 0);
IPAddress gateway(192, 168, 1, 1);
EthernetServer server(80);
ShieldSetup();
Ethernet.begin(mac, ip, gateway, subnet);
server.begin();
void ShieldSetup() {
int idcheck = EEPROM.read(0);
if (idcheck != ID){
if (idcheck == ID){
for (int i = 0; i < 4; i++){
ip[i] = EEPROM.read(i+7);
subnet[i] = EEPROM.read(i+11);
gateway[i] = EEPROM.read(i+15);
Ethernet.begin(mac, ip);
if (client) {
TextFinder finder(client );
while (client.connected()) {
if (client.available()) {
if( finder.find("GET /") ) {
if (finder.findUntil("setup", "\n\r")){
if (finder.findUntil("SBM", "\n\r")){
byte SET = finder.getValue();
while(finder.findUntil("DT", "\n\r")){
int val = finder.getValue();
// if val from "DT" is between 1 and 6 the according value must be a MAC value.
if(val >= 1 && val <= 6) {
mac[val - 1] = finder.getValue();
// if val from "DT" is between 7 and 10 the according value must be a IP value.
if(val >= 7 && val <= 10) {
ip[val - 7] = finder.getValue();
// if val from "DT" is between 11 and 14 the according value must be a MASK value.
if(val >= 11 && val <= 14) {
subnet[val - 11] = finder.getValue();
// if val from "DT" is between 15 and 18 the according value must be a GW value.
if(val >= 15 && val <= 18) {
gateway[val - 15] = finder.getValue();
// Now that we got all the data, we can save it to EEPROM
//for (int i = 0 ; i < 6; i++){
//EEPROM.write(i + 1,mac[i]);
for (int i = 0 ; i < 4; i++){
EEPROM.write(i + 7, ip[i]);
EEPROM.write(i + 11, subnet[i]);
EEPROM.write(i + 15, gateway[i]);
EEPROM.write(0, 0x92);
// and from this point on, we can start building our setup page
// and show it in the client's browser.
client.println("Content-Type: text/html");
client.println();
strcpy_P(buffer, (char*)pgm_read_word(&(string_table0[i])));
client.print( buffer );
for (int i = 0; i < 3; i++)
strcpy_P(buffer, (char*)pgm_read_word(&(string_table1[i])));
client.print(mac[0],HEX);
strcpy_P(buffer, (char*)pgm_read_word(&(string_table1[3])));
client.print(mac[1],HEX);
strcpy_P(buffer, (char*)pgm_read_word(&(string_table1[4])));
client.print(mac[2],HEX);
strcpy_P(buffer, (char*)pgm_read_word(&(string_table1[5])));
client.print(mac[3],HEX);
strcpy_P(buffer, (char*)pgm_read_word(&(string_table1[6])));
client.print(mac[4],HEX);
strcpy_P(buffer, (char*)pgm_read_word(&(string_table1[7])));
client.print(mac[5],HEX);
strcpy_P(buffer, (char*)pgm_read_word(&(string_table2[i])));
client.print(ip[0],DEC);
strcpy_P(buffer, (char*)pgm_read_word(&(string_table2[4])));
client.print(ip[1],DEC);
strcpy_P(buffer, (char*)pgm_read_word(&(string_table2[5])));
client.print(ip[2],DEC);
strcpy_P(buffer, (char*)pgm_read_word(&(string_table2[6])));
client.print(ip[3],DEC);
strcpy_P(buffer, (char*)pgm_read_word(&(string_table3[0])));
client.print(subnet[0],DEC);
strcpy_P(buffer, (char*)pgm_read_word(&(string_table3[1])));
client.print(subnet[1],DEC);
strcpy_P(buffer, (char*)pgm_read_word(&(string_table3[2])));
client.print(subnet[2],DEC);
strcpy_P(buffer, (char*)pgm_read_word(&(string_table3[3])));
client.print(subnet[3],DEC);
strcpy_P(buffer, (char*)pgm_read_word(&(string_table4[0])));
client.print(gateway[0],DEC);
strcpy_P(buffer, (char*)pgm_read_word(&(string_table4[1])));
client.print(gateway[1],DEC);
strcpy_P(buffer, (char*)pgm_read_word(&(string_table4[2])));
client.print(gateway[2],DEC);
strcpy_P(buffer, (char*)pgm_read_word(&(string_table4[3])));
client.print(gateway[3],DEC);
strcpy_P(buffer, (char*)pgm_read_word(&(string_table4[4])));
for (int i = 0; i < 7; i++)
strcpy_P(buffer, (char*)pgm_read_word(&(string_table5[i])));
strcpy_P(buffer, (char*)pgm_read_word(&(string_table4[5])));
client.println();
client.println();
(F("<tr><td><font color=\"red\" size=\"2\"
face=\"Verdana\"> You can not change the MAC
address</font></td></tr></table>
delay(1);
client.stop();
Error (at least one of them): Marked on the line:
if (idcheck != ID){ <------ ERROR
'ID' was not declared in this scope
Maybe its an ambitious goal to me, (too high over my possibilities or skills, but but a guy says : "your only real obstacle is yourself", so thats why im posting... keep trying.
Thank you
