Change the access point on the device web to restart
I made a program to change the access point but instead it made the esp restart even though there was no command to restart the access point, only the access point was having problems?
jws.ino.txt (134.9 KB)
index.html.txt (125.2 KB)
    server.on("/setap", HTTP_POST, [](AsyncWebServerRequest *request) {
        if (request->hasParam("ssid", true) && request->hasParam("password", true)) {
            String ssid = request->getParam("ssid", true)->value();
            String pass = request->getParam("password", true)->value();
            if (pass.length() > 0 && pass.length() < 8) {
                request->send(400, "text/plain", "Password minimal 8 karakter");
                return;
            Serial.println("\n========================================");
            Serial.println("Simpan AP");
            Serial.println("========================================");
            Serial.println("New AP SSID: " + ssid);
            ssid.toCharArray(wifiConfig.apSSID, 33);
            pass.toCharArray(wifiConfig.apPassword, 65);
            saveAPCredentials();
            Serial.println("Stopping old AP...");
            WiFi.softAPdisconnect(false);
            delay(200);
            Serial.println("Forcing AP_STA mode...");
            WiFi.mode(WIFI_AP_STA);
            delay(100);
            WiFi.softAP(wifiConfig.apSSID, wifiConfig.apPassword);
            delay(200);
            IPAddress newAPIP = WiFi.softAPIP();
            Serial.println("AP Settings updated");
            Serial.println("New SSID: " + String(wifiConfig.apSSID));
            Serial.println("New IP: " + newAPIP.toString());
            Serial.println("========================================\n");
            request->send(200, "text/plain", "OK");
            request->send(400, "text/plain", "Missing parameters");
function setAP() {
            const ssid = document.getElementById('apSSID').value.trim();
            const password = document.getElementById('apPassword').value;
            if (!ssid) {
                showToast('SSID Access Point tidak boleh kosong', 'error');
                return;
            if (password.length > 0 && password.length < 8) {
                showToast('Password minimal 8 karakter', 'error');
                return;
            const btn = event.target;
            const originalText = btn.textContent;
            btn.disabled = true;
            btn.textContent = 'Menyimpan...';
            fetch('/setap', {
                method: 'POST',
                headers: {
                    'Content-Type': 'application/x-www-form-urlencoded',
                body: `ssid=${encodeURIComponent(ssid)}&password=${encodeURIComponent(password)}`
            .then(response => {
                if (response.ok) {
                    savedWiFiConfig.apSSID = ssid;
                    if (password) {
                        savedWiFiConfig.apPassword = password;
                    showToast('Pengaturan Access Point berhasil disimpan', 'success');
                    document.getElementById('apPassword').value = '';
                    setTimeout(() => {
                        loadWiFiConfig();
                    }, 1000);
                    setTimeout(() => {
                        showToast('Sambungkan ke AP: ' + ssid, 'warning');
                    }, 3500);
                    setTimeout(() => {
                        btn.disabled = false;
                        btn.textContent = originalText;
                    }, 6000);
                    setTimeout(() => {
                        showToast('Halaman akan di-refresh otomatis...', 'warning');
                        setTimeout(() => {
                            window.location.reload();
                        }, 2000);
                    }, 18000);
                    return response.text().then(text => {
                        throw new Error(text);
            .catch(error => {
                showToast('Gagal menyimpan AP: ' + error.message, 'error');
If the ESP32 restarts, that is usually a sign of a very serious program error not caught by the compiler, such as out of bounds memory accesses.
Start by looking for array index violations (including character string arrays).
Help forum members by posting both the working and nonworking code (complete code, not snippets), and explaining what you changed and why.
The error is only in the access point program, once saved, esp restarts even though there is no command to restart esp, other programs are normal.
That's irrelevant, I've already found the problem, which is that the access point is delaying in sending information because it times out while running. I added a separate task for that.
