change the name of arduino pro micro shown in the "Devices and printers"
I have tried like show in change the name of arduino pro micro shown in the "Devices and printers" - Microcontrollers - Arduino Forum but it don't have any goal.
May be i don't understand correctly
I have changed name as code shows
micro.name=PannelloDestro
micro.vid.0=0x2341
micro.pid.0=0x0037
micro.vid.1=0x2341
micro.pid.1=0x8037
micro.vid.2=0x2A03
micro.pid.2=0x0037
micro.vid.3=0x2A03
micro.pid.3=0x8037
micro.vid.4=0x2341
micro.pid.4=0x0237
micro.vid.5=0x2341
micro.pid.5=0x8237
micro.upload.tool=avrdude
micro.upload.protocol=avr109
micro.upload.maximum_size=28672
micro.upload.maximum_data_size=2560
micro.upload.speed=57600
micro.upload.disable_flushing=true
micro.upload.use_1200bps_touch=true
micro.upload.wait_for_upload_port=true
micro.bootloader.tool=avrdude
micro.bootloader.low_fuses=0xff
micro.bootloader.high_fuses=0xd8
micro.bootloader.extended_fuses=0xcb
micro.bootloader.file=caterina/Caterina-Micro.hex
micro.bootloader.unlock_bits=0x3F
micro.bootloader.lock_bits=0x2F
micro.build.mcu=atmega32u4
micro.build.f_cpu=16000000L
micro.build.vid=0x2341
micro.build.pid=0x8037
#micro.build.usb_product="Arduino Micro"
micro.build.usb_product="Pannello dx"
micro.build.board=AVR_MICRO
micro.build.core=arduino
micro.build.variant=micro
micro.build.extra_flags={build.usb_flags}
and then o send again my sketch to configure Arduino as new game peripheric, but in resources is still Arduino Micro.
where i fault?
thank you
I don't know if I remember correctly but you may have to remove device from your device manager and have your micro rediscovered when you plug it in a USB port so hopefully it will change.
No nothing has been changed, but my question is : it's enough cange the board.txt in the conf directory of arduino API and then compile and send my sketch or in unknown way for me send wich is in board.txt to the processor?
Or i have to do more?
Yes it should be enough. Turn on verbose compilation in preference you will see lines like these:
"C:\a185\hardware\tools\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 '-DUSB_MANUFACTURER="Unknown"' '-DUSB_PRODUCT="Arduino Micro"' "-IC:\a185\hardware\arduino\avr\cores\arduino" "-IC:\a185\hardware\arduino\avr\variants\micro" "C:\a185\hardware\arduino\avr\cores\arduino\wiring_digital.c" -o "C:\Users\x\AppData\Local\Temp\arduino_build_370459\core\wiring_digital.c.o"
In there you will find a -DUSB_PRODUCT="Arduino Micro" option. This value is taken from the boards.txt file. I tested it. If your compilation message doesn't say your product name, maybe you don't have arduino micro, you have genuino micro or else. The script under Arduino micro has a few places for 0x8x37 which resulted from a fight between Arduino LLC and Arduino SRL an age ago. Make sure you look up your device manager for the EXACT product ID and change the corresponding info in boards.txt
If all fails and you're frustrated, go to USBCore.cpp, which is located here: Arduino\hardware\arduino\avr\cores\arduino\USBCore.cpp
Change the following lines at the beginning:
#ifndef USB_PRODUCT
// If no product is provided, use USB IO Board
#define USB_PRODUCT     "USB IO Board"
#endif
into:
#define USB_PRODUCT     "Your board name"
