Modified thread " now its posted in thr right way I guess "
I try to generate a sine wave through vaaring the PWM duty cycle. IT works so far
I have a fixed PWM frequency of 10 KHz and I tried to cary the sine wave frequency in the ISR throught counting each second item from the sine array--> this will result a doppel frequency
counting each 4th item of the sine aeeay will result a ground frequency*4
This method is not so good cause I cant really have a fractions
The only part I need to change now to vary the frequency is this one
/* Standard frequency range e.g LENZE VFD 0-300 HZ */
/* Ground sine wave frequency = (PWM_Freq/ Size of sine wave array)
= 10 000 HZ/ 120 = 83.3 Hz*/
ul_count++;
/* to vary the sine wave frequency the u_count must be re defined due to the desired frequency*/
//ul_count= ul_count+2 ;
Can anyone tell me how to make it in another way to change thefrequency not only in 2,4,6,8 way ?
Thanks in advance this is my code
Code:
// **INCLUDE FILES & HEADER DATA****INCLUDE FILES & HEADER DATA****INCLUDE FILES & HEADER DATA**
#include "asf.h" // ATMEL SOFTWARE FRAMEWORK
#include "conf_board.h"
#include "conf_clock.h"
#include "SineArray.h"
// **Global variables and macros****Global variables and macros****Global variables and macros**
/** PWM frequency in Hz */
#define PWM_FREQUENCY 10000
/** Period value of PWM output waveform */
#define PERIOD_VALUE 4096
/** Initial duty cycle value */
#define INIT_DUTY_VALUE 50
// **GPIO pin definitions for 3 PWM signals****GPIO pin definitions for 3 PWM signals**
/* PIN Definition for the third PWM Channel @ Arduino Due Board = PWM PIN 07 */
#define PIN_PWM_3DPWM_GPIO PIO_PC23_IDX
#define PIN_PWM_3DPWM_FLAGS (PIO_PERIPH_B | PIO_DEFAULT)
#define PIN_PWM_3DPWM_CHANNEL PWM_CHANNEL_6
/* PIN Definition for the second PWM Channel @ Arduino Due Board = PWM PIN 08 */
#define PIN_PWM_2NDPWM_GPIO PIO_PC22_IDX
#define PIN_PWM_2NDPWM_FLAGS (PIO_PERIPH_B | PIO_DEFAULT)
#define PIN_PWM_2NDPWM_CHANNEL PWM_CHANNEL_5
/* PIN Definition for the first PWM Channel @ Arduino Due Board = PWM PIN 09 */
#define PIN_PWM_1STPWM_GPIO PIO_PC21_IDX
#define PIN_PWM_1STPWM_FLAGS (PIO_PERIPH_B | PIO_DEFAULT)
#define PIN_PWM_1STPWM_CHANNEL PWM_CHANNEL_4
/** PWM channel instance */
pwm_channel_t g_pwm_channel_instance;
// **Interrupt handler for the PWM controller****Interrupt handler for the PWM controller**
void PWM_Handler(void)
static uint32_t size; /* Size of the sine array*/
static uint32_t ul_count = 0; /* PWM counter value */
static uint32_t ul_duty1 = INIT_DUTY_VALUE; /* PWM duty cycle rate */
static uint32_t ul_duty2 = INIT_DUTY_VALUE; /* PWM duty cycle rate */
static uint32_t ul_duty3 = INIT_DUTY_VALUE; /* PWM duty cycle rate */
uint32_t events = pwm_channel_get_interrupt_status(PWM);
ul_count++;
/* to determine the size of the sine array*/
size = sizeof(sine)/2;
if (ul_count >= size) {
ul_count = 0;
/* Overlay a sine wave array to a PWM signal */
/* each output signal is 120 degree phase shifted to the other one */
ul_duty1 = sine[ul_count%size];// // 1st sine wave output 0 degree phase shift
ul_duty2 = sine[(ul_count+(size/3)) %size]; // 2nd sine wave output 120 degree phase shift
ul_duty3 = sine[(ul_count+(2*size/3))%size];// 3rd sine wave output 240 degree phase shift
/* Set new duty cycle */
g_pwm_channel_instance.channel = PIN_PWM_1STPWM_CHANNEL;
pwm_channel_update_duty(PWM, &g_pwm_channel_instance, ul_duty1);
g_pwm_channel_instance.channel = PIN_PWM_2NDPWM_CHANNEL;
pwm_channel_update_duty(PWM, &g_pwm_channel_instance, ul_duty2);
g_pwm_channel_instance.channel = PIN_PWM_3DPWM_CHANNEL;
pwm_channel_update_duty(PWM, &g_pwm_channel_instance, ul_duty3);
// ******MAIN MENU*************************MAIN MENU*******************************MAIN MENU***************
int main(void)
/* Initialize the SAM system */
sysclk_init();
board_init();
/* GPIO Pin configuration */
gpio_configure_pin(PIN_PWM_3DPWM_GPIO, PIN_PWM_3DPWM_FLAGS); // for PWM PIN 3
gpio_configure_pin(PIN_PWM_2NDPWM_GPIO, PIN_PWM_2NDPWM_FLAGS); // for PWM PIN 2
gpio_configure_pin(PIN_PWM_1STPWM_GPIO, PIN_PWM_1STPWM_FLAGS); // for PWM PIN 1
/* Enable PWM peripheral clock */
pmc_enable_periph_clk(ID_PWM);
/* Disable PWM channels */
pwm_channel_disable(PWM, PIN_PWM_1STPWM_CHANNEL); // @ PWM PIN 9
pwm_channel_disable(PWM, PIN_PWM_2NDPWM_CHANNEL); // @ PWM PIN 8
pwm_channel_disable(PWM, PIN_PWM_3DPWM_CHANNEL); // @ PWM PIN 7
/* Set PWM clock A as PWM_FREQUENCY*PERIOD_VALUE (clock B is not used) */
pwm_clock_t clock_setting = {
.ul_clka = PWM_FREQUENCY * PERIOD_VALUE,
.ul_clkb = 0, // clock B is disabled
.ul_mck = sysclk_get_cpu_hz()
pwm_init(PWM, &clock_setting);
/* Initialize PWM channel for PWM PIN 7 */
/* Period is left-aligned */
g_pwm_channel_instance.alignment = PWM_ALIGN_LEFT;
/* Output waveform starts at a low level */
g_pwm_channel_instance.polarity = PWM_LOW;
/* Use PWM clock A as source clock */
g_pwm_channel_instance.ul_prescaler = PWM_CMR_CPRE_CLKA;
/* Period value of output waveform */
g_pwm_channel_instance.ul_period = PERIOD_VALUE;
/* Duty cycle value of output waveform */
g_pwm_channel_instance.ul_duty = INIT_DUTY_VALUE;
pwm_channel_init(PWM, &g_pwm_channel_instance);
/* Initialize PWM channel for PWM PIN 8 */
/* Enable channel counter event interrupt */
pwm_channel_enable_interrupt(PWM, PIN_PWM_2NDPWM_CHANNEL, 0);
/* Initialize PWM channel for PWM PIN 9 */
/* Disable channel counter event interrupt */
pwm_channel_disable_interrupt(PWM, PIN_PWM_1STPWM_CHANNEL, 0);
/* Configure interrupt and enable PWM interrupt */
NVIC_DisableIRQ(PWM_IRQn);
NVIC_ClearPendingIRQ(PWM_IRQn);
NVIC_SetPriority(PWM_IRQn, 0);
NVIC_EnableIRQ(PWM_IRQn);
/* Enable PWM channels */
pwm_channel_enable(PWM, PIN_PWM_1STPWM_CHANNEL); // @ PWM PIN 9
pwm_channel_enable(PWM, PIN_PWM_2NDPWM_CHANNEL); // @ PWM PIN 8
pwm_channel_enable(PWM, PIN_PWM_3DPWM_CHANNEL); //@ PWM PIN 7
// ******MAIN LOOP*************************MAIN LOOP*******************************MAIN LOOP***************
while (1) {
