Hello.
I am making a project where RFID tags on 6 RFID readers will create a 6-digit HEX-code which will be converted and output through RGB.
I am converting HEX values to RGB values and print the values in serial, which works fine. E.g when I write #FFFFFF, Serial prints its respective RGB values - 255, 255, 255.
However, I want to be able to replace one of the letters in the HEX code at a time, which should change its RGB output in serial. In this example, I am attempting to replace the last letter of #FFFFFF to 3 - #FFFFF3. Serial still reads the first two values correctly, but does not convert the last value correctly.
I have read that it is better to create a new array with the new value -
instead of replacing a value and changing the array but do not really know how. Here's what I have got now:
#include <stdlib.h>
#include <string.h>
char hexColor[] = "#FFFFFF";
void HEXtoRGB();
void HEXtoRGB() {
hexColor[6] = "3";
char red[5] = {0};
char green[5] = {0};
char blue[5] = {0};
red[0] = green[0] = blue[0] = '0';
red[1] = green[1] = blue[1] = 'X';
red[2] = hexColor[1];
red[3] = hexColor[2];
green[2] = hexColor[3];
green[3] = hexColor[4];
blue[2] = hexColor[5];
blue[3] = hexColor[6];
long r = strtol(red, NULL, 16);
long g = strtol(green, NULL, 16);
long b = strtol(blue, NULL, 16);
Serial.println(r);
Serial.println(g);
Serial.println(b);
Serial.println(hexColor);
Any sort of input would be greatly appreciated.
Thank you.
