Is there an easy way to modify the compiler flags used to build a sketch?
As far as I see -Wall is not turned on at all and -Os is the default optimization level. How could I change these with Arduino IDE 1.5.8?
AFAIK, older versions would need to recompile the IDE. Newer versions of IDE allow changing the settings inside the platform.txt file. 1.5.8 should have the platform.txt file.
