Changing Variables via python script
Hey gang, new here and new to programming too lol.
I have an arduino script that I'm using to toggle a couple of relays and the script serial output is being read by a python script I have, which then plots data. I'm trying to make it so the python script can change some variables in the arduino script, but I'm having serious trouble. Any tips?
Arduino Script:
///// Fatigue Testing Script /////
// By: Luna Mircea
// V3-Changelog: Added dynamic parameter updates via serial input
// Pin definitions
const int InPin = 4; // Digital pin controlling relay 1 (input)
const int OutPin = 5; // Digital pin controlling relay 2 (output)
#define HI_PSI_PIN A7     // High-pressure sensor pin (analog pin A7)
// Pressure calibration
#define AGREE_SLOPE 1.005
#define AGREE_OFFSET 0
#define HIGHPSI 300.0
#define PSI_HV_COUNT 920
#define PSI_LV_COUNT 102
// Timing and cycle variables
unsigned long InActivationTime = 500; // Time input relay is active (in milliseconds)
unsigned long OutActivationTime = 500; // Time output relay is active (ms)
unsigned int totalCycles = 10;           // Total number of cycles
unsigned int cycleCount = 0;             // Counter for completed cycles
unsigned int TDelay = 500;              // Time between relay activations
// Logging and pressure variables
bool logging = false;
float pressure = 0.0;
// Function prototypes
void logPressure();
void performRelayCycleWithLogging();
void delayWithPressureLogging(unsigned long duration);
void updateParameter(String input);
  Serial.begin(250000); // Start serial communication
  pinMode(InPin, OUTPUT);
  pinMode(OutPin, OUTPUT);
  pinMode(HI_PSI_PIN, INPUT);
  digitalWrite(InPin, LOW);
  digitalWrite(OutPin, LOW);
  Serial.println("Welcome to the Fatigue Testing System!");
  Serial.println(__DATE__); // Compilation date
  Serial.println(__TIME__); // Compilation time
  Serial.println("--------------------------------------------------");
  // Handle incoming serial commands
  if (Serial.available() > 0) {
    String command = Serial.readStringUntil('\n');
    updateParameter(command);
  // Toggle logging with spacebar
  if (logging) {
    // Log pressure continuously
    logPressure();
    // Perform relay cycle with logging
    if (cycleCount < totalCycles) {
      Serial.println("Test complete. Logging stopped.");
      logging = false;  // Stop logging
    // Ensure both relays are off when logging is stopped
  // Check for user input to toggle logging
        int incomingByte = Serial.read();
        if (incomingByte == ' ')
            logging = !logging;
            if (logging)
                Serial.println("--------------- LOGGING STARTED ----------------------");
                Serial.print("millis,pressure");
                Serial.println(); // Print newline
void updateParameter(String input) {
  if (input.startsWith("InActivationTime=")) {
    InActivationTime = input.substring(17).toInt();
    Serial.print("Updated InActivationTime to ");
    Serial.println(InActivationTime);
  } else if (input.startsWith("OutActivationTime=")) {
    OutActivationTime = input.substring(18).toInt();
    Serial.print("Updated OutActivationTime to ");
    Serial.println(OutActivationTime);
  } else if (input.startsWith("TDelay=")) {
    TDelay = input.substring(7).toInt();
    Serial.print("Updated TDelay to ");
    Serial.println(TDelay);
  } else if (input.startsWith("totalCycles=")) {
    totalCycles = input.substring(12).toInt();
    Serial.print("Updated totalCycles to ");
    Serial.println(totalCycles);
    Serial.print("Unknown command: ");
    Serial.println(input);
void logPressure() {
  static unsigned long lastLogTime = 0;
  unsigned long currentTime = millis();
  if (currentTime - lastLogTime >= 10) { // Log every 10ms
    lastLogTime = currentTime;
    int value = analogRead(HI_PSI_PIN); // Declare value here
    if (value < PSI_LV_COUNT) {
      pressure = 0.0;
    } else if (value > PSI_HV_COUNT) {
      pressure = HIGHPSI;
      pressure = AGREE_SLOPE * (HIGHPSI * ((float)(value - PSI_LV_COUNT) / (PSI_HV_COUNT - PSI_LV_COUNT))) + AGREE_OFFSET;
    Serial.print(millis());
    Serial.print(",");
    Serial.println(pressure);
void performRelayCycleWithLogging() {
  // Relay 1 Activation
  Serial.println("Activating Relay 1...");
  digitalWrite(InPin, HIGH);
  delayWithPressureLogging(InActivationTime); // Wait while logging pressure
  Serial.println("Deactivating Relay 1...");
  delayWithPressureLogging(TDelay); // Delay between relay activations
  // Relay 2 Activation
  Serial.println("Activating Relay 2...");
  digitalWrite(OutPin, HIGH);
  delayWithPressureLogging(OutActivationTime); // Wait while logging pressure
  digitalWrite(OutPin, LOW); // Ensure this turns off Relay 2
  Serial.println("Deactivating Relay 2...");
  delayWithPressureLogging(TDelay); // Delay before next cycle
  // Increment cycle count
  cycleCount++;
  Serial.print("Cycle ");
  Serial.print(cycleCount);
  Serial.println(" complete.");
void delayWithPressureLogging(unsigned long duration) {
  unsigned long startTime = millis();
  while (millis() - startTime < duration) {
    logPressure(); // Log pressure repeatedly during the delay
Python script:
@author: Luna Mircea
Version 7 - Print All Serial Data
########## Pressure Arduino Serial Plot Script ##########
import serial
import csv
import os
import matplotlib.pyplot as plt
import pandas as pd
from threading import Thread, Lock
import msvcrt
import time
# Set up serial connection
arduino_port = 'COM6'  # Replace with the port where your Arduino is connected
baud_rate = 250000  # Baud rate must match the rate defined in your Arduino code
# Global stop flag
stop_flag = False
# Lock for serial port access
serial_lock = Lock()
# Generate a unique filename
def get_unique_filename(folder_path, prefix):
    counter = 1
    filename = f"{folder_path}/{prefix}_{counter}.csv"
    while os.path.exists(filename):
        counter += 1
    return filename
def plot_csv_data(filename):
    # Skip the header row and read data
    df = pd.read_csv(filename, names=["millis", "pressure"], skiprows=1)
    # Convert 'millis' and 'pressure' columns to numeric, coercing errors
    df["millis"] = pd.to_numeric(df["millis"], errors='coerce')
    df["pressure"] = pd.to_numeric(df["pressure"], errors='coerce')
    # Drop rows with NaN values
    df = df.dropna()
    # Calculate min and max for x-axis
    xmin = int(df["millis"].min())
    xmax = int(df["millis"].max())
    # Plot the data
    plt.plot(df["millis"], df["pressure"], color='black', linewidth=0.8)
    plt.xlabel('Milliseconds')
    plt.ylabel('Pressure (PSI)')
    plt.title('Pressure Log')
    # Set x-axis ticks from min to max in steps of 500
    plt.xticks(range(xmin, xmax + 1, 500))
    plt.grid(True)
    # Save the plot as an image
    plot_filename = filename.replace(".csv", "_Log.png")
    plt.savefig(plot_filename, bbox_inches='tight')
    plt.close()
# Read data from serial and save to CSV, while printing all serial output to terminal
def read_from_serial(ser, writer):
    global stop_flag
    last_print_time = time.time()  # Track the last print time
    while not stop_flag:
        with serial_lock:
            if ser.in_waiting > 0:
                line = ser.readline().decode('utf-8').strip()
                print(line)  # Print all serial data to the terminal
                if "," in line:
                    writer.writerow(line.split(","))
# Send updated parameters to Arduino
def send_parameters_to_arduino(ser):
    parameters = {
        "InActivationTime": input("Enter Input Valve Open time (ms): ").strip(),
        "OutActivationTime": input("Enter Output Valve Open time (ms): ").strip(),
        "TDelay": input("Enter Valve Delay (ms): ").strip(),
        "totalCycles": input("Enter total number of cycles: ").strip()
    for key, value in parameters.items():
        command = f"{key}={value}\n"
        arduino.write(command.encode())
# Main function
def main():
    global stop_flag
    username = input("Hi! Please enter your name: ").strip()
    testname = input("Thanks! Now enter the test name: ").strip()
    folder_name = f"Fatigue_Test_{username}_{testname}"
    os.makedirs(folder_name, exist_ok=True)
    filename = get_unique_filename(folder_name, "pressure_log")
    try:
        with serial.Serial(arduino_port, baud_rate, timeout=1) as ser:
            print(f"Connected to {arduino_port}")
            # Send parameters to Arduino
            input("Got it! Parameters sent to Arduino! Press Enter to start the test...")
            ser.write(b' ')  # Send a space character to the Arduino to start the test
            with open(filename, "w", newline="") as file:
                writer = csv.writer(file)
                thread = Thread(target=read_from_serial, args=(ser, writer))
                thread.start()
                print("Press ESC to stop the test and generate the plot.")
                    if msvcrt.kbhit() and msvcrt.getch() == b'\x1b':  # Check for ESC key
                        print("\nESC pressed. Stopping the test...")
                        stop_flag = True
                thread.join()
    except Exception as e:
        print(f"An error occurred: {e}")
if __name__ == "__main__":
    main()
Excuse my shit coding plz!
Python works very well at finding stuff in a line of text and you can write Python code to change that text and then append the remaining part of the original line. Examples, please!
I send data from python via serial port like this
arduino.write(command.encode("ascii"))
because arduino expects ASCII characters, not UTF-8.
The rest I do similarly to how you do except that I use indexOf() instead of startWith().
