Connecting my Arduino Uno to two python programs
Hi! I am trying to connect my Arduino Uno to two Python programs.
The main python program opens the serial.port communication with the Arduino and once it wants to execute the second code, it closes the serial.port communication so that the second code can open it.
When executing the first code, I am able to send data to my arduino and, the arduino is able to execute the desired commands. However, when closing the serial.port in order to execute the second code, I am able to send the data but Arduino is unable to execute the commands. Nevertheless, if I close my second code and open again the serial.port communication for the first code, everything works correctly.
My codes are really simple.
First code:
import serial  # Para comunicación serial
import time  # Para pausas temporales
from pynput import keyboard  # Para escuchar eventos de teclado
import subprocess  # Para ejecutar comandos del sistema
import re
from watchdog.observers import Observer
from watchdog.events import FileSystemEventHandler
# Configurar la conexión serial con Arduino
puerto_serial = serial.Serial('COM10', 9600)
time.sleep(2)  # Esperar para que Arduino se inicie
finalizar = False  # Para verificar si el programa debe finalizar
# Variable para almacenar la última tecla conocida
ultima_tecla = None
def on_press(key):
    global finalizar
    global ultima_tecla
    try:
        # Verificar si es una tecla imprimible
        if hasattr(key, 'char') and key.char is not None:
            char = key.char
            # Finalizar si se presiona 'q'
            if char == 'q':
                print("Presionaste 'q', terminando...")
                finalizar = True
                return False
                if  ultima_tecla != 'q':
                    puerto_serial.write(b'q\n')
                ultima_tecla = char
            if char == 'a':
                puerto_serial.write(b'a\n')
                print("Flecha hacia arriba")
                if ultima_tecla != 'a':
                ultima_tecla = char
            elif char == 'b':
                puerto_serial.write(b'b\n')
                print("Flecha hacia abajo")
                if ultima_tecla != 'b':
                ultima_tecla = char
            elif char == 'l':
                puerto_serial.write(b'l\n')
                print("Flecha hacia la izquierda")
                if ultima_tecla != 'l':
                ultima_tecla = char
            elif char == 'r':
                puerto_serial.write(b'r\n')
                print("Flecha hacia la derecha")
                if ultima_tecla != 'r':
                ultima_tecla = char
            elif char == 'p':
                puerto_serial.write(b'p\n')
                print("Flecha para parar")
                if ultima_tecla != 'p':
                ultima_tecla = char
            elif char == 'w':
                puerto_serial.write(b'm\n')
                if puerto_serial.is_open:
                    puerto_serial.close()
                    print("Puerto serial cerrado.")
                archivo_a_ejecutar = r'C:/Users/Lara\Desktop/TFG/comprobar_lectura_x.py'
                process = subprocess.Popen(['python', archivo_a_ejecutar])
                process.wait()  # Esperar a que el proceso termine
                if process.returncode is not None:  # Verificar si el proceso ha terminado
                    puerto_serial.open()
    except Exception as e:
        print(f"Error al procesar tecla: {e}")
# Iniciar el Listener para capturar eventos de teclado
with keyboard.Listener(on_press=on_press) as listener:
    listener.join()  # Mantener el Listener hasta que se presione 'q'
# Cerrar el puerto serial al finalizar
Second code that constants the comprobar_lectura_x.py:
import time
import subprocess
import serial
import cv2
import keyboard
# Variable para almacenar el último número del archivo
ultimo_numero = ""
ultimo_valor = ""
def imprimir_ultimo_numero(data):
    global ultimo_numero, ultimo_valor
    if data and data != ultimo_numero:  # Verificar si hay datos y si son diferentes al último número
        ultimo_numero = obtener_ultimo_numero(data)
        print("Último número:", ultimo_numero)
        if ultimo_numero == '1':
            if ultimo_valor != '1':
            ultimo_valor = ultimo_numero
        elif ultimo_numero == '2':
            if ultimo_valor != '2':
        elif ultimo_numero == '3':
            print("Flecha hacia izquierda")
            if ultimo_valor != '3':
        elif ultimo_numero == '4':
            print("Flecha hacia derecha")
            if ultimo_valor != '4':
        elif ultimo_numero == '0':
            print("PARAR")
            if ultimo_valor != '0':
        else:
            print("Posición no reconocida")
def obtener_ultimo_numero(data):
    # Eliminar no numéricos a la derecha
    data = ''.join(filter(str.isdigit, data))
    if not data:
        return '0'
    # último número de la cadena
    return data[-1]
class MyHandler(FileSystemEventHandler):
    def on_modified(self, event):
        if event.src_path.endswith("x_value.txt"):
            data = leer_archivo(event.src_path)
def leer_archivo(filename):
    with open(filename) as fh:
        line = fh.read()
    return line
archivo_a_ejecutar = r'C:/Users/Lara\Desktop/TFG/Control_Arduino_witmotion.py'
#archivo_a_ejecutar = r'C:/Users/Lara\Desktop/TFG/comprobar_generar_lectura.py'
ultimo_valor = '0'
event_handler = MyHandler()
observer = Observer()
observer.schedule(event_handler, path='.', recursive=False)
observer.start()
try:
    while True:
        if keyboard.is_pressed('q'):
            print("Exiting program...")
            # Terminate the subprocess
            process.terminate()
            break
        time.sleep(0.1)  # Add a small delay to reduce CPU usage
except KeyboardInterrupt:
    observer.stop()
where the Control_Arduino_witmotion simply generates the values to be read on the x_value.txt file.
The arduino code generated PWM signals depending on the received character. For both python programs, the Arduino is able to read the characters but, for the second one, it does not generate the signals.
My arduino code is the following:
/ Definición de pines
const int pwmPin1 = 6;
const int pwmPin2 = 5;
const int pinX = A0; // Para el eje X del joystick
const int pinY = A1; // Para el eje Y del joystick
const int pinControl1 = 3; // Control de dirección
const int pinControl2 = 10; // Control de dirección
// Definición de modos
enum Mode { NONE, EYE, VOICE, MOVEMENT, JOYSTICK, STOP };
Mode currentMode = STOP;
// Velocidad predeterminada
int velocidad_fija = 20;
void move_backward() {
    analogWrite(pwmPin1, velocidad_fija);
    digitalWrite(pinControl1, HIGH); // Control hacia atrás
void move_forward() {
    digitalWrite(pinControl1, LOW); // Control hacia adelante
void move_left() {
    analogWrite(pwmPin2, velocidad_fija);
    digitalWrite(pinControl2, LOW); // Control hacia la izquierda
void move_right() {
    digitalWrite(pinControl2, HIGH); // Control hacia la derecha
void move_stop() {
    analogWrite(pwmPin1, 100); // Detener PWM
    analogWrite(pwmPin2, 100);
    Serial.begin(9600); // Comunicación serial
    // Configuración de pines
    pinMode(pwmPin1, OUTPUT);
    pinMode(pwmPin2, OUTPUT);
    pinMode(pinX, INPUT);
    pinMode(pinY, INPUT);
    pinMode(pinControl1, OUTPUT);
    pinMode(pinControl2, OUTPUT);
    move_stop(); // Detener por defecto
    if (Serial.available() > 0) {
        String command = Serial.readStringUntil('\n'); // Leer comando serie
        command.trim(); // Limpiar caracteres extra
        if (command.startsWith("f")) {
            String speedValue = command.substring(1); // Obtener valor después de 'v'
            int newSpeed = speedValue.toInt(); // Convertir a número entero
            if (newSpeed >= 0 && newSpeed <= 255) { // Validar rango para PWM
                velocidad_fija = newSpeed; // Actualizar velocidad fija
                Serial.println("Velocidad establecida a " + String(velocidad_fija));
                Serial.println("Valor de velocidad fuera de rango.");
            return; // Retornar para evitar otros comandos
        // Cambiar modo según comando recibido
        char cmd = command.charAt(0);
        switch (cmd) {
            case 'j':
                currentMode = JOYSTICK;
            case 'v':
                currentMode = VOICE;
            case 'a':
              move_forward(); // Mover hacia adelante
              Serial.println("Moving Forward");
            case 'b':
              move_backward(); // Mover hacia atrás
              Serial.println("Moving Backward");
            case 'l':
              move_left(); // Mover hacia la izquierda
              Serial.println("Moving Left");
            case 'r':
              move_right(); // Mover hacia la derecha
              Serial.println("Moving Right");
            case 'p':
              Serial.println("Stop");
            case 'm': // Modo de movimiento
                currentMode = MOVEMENT;
            default:
    if (currentMode == JOYSTICK) {
        handle_joystick(); // Control por joystick
     } else if (currentMode == MOVEMENT) {
        handle_movement('p'); // Control por movimiento
    } else if (currentMode == STOP) {
        move_stop(); // Detener movimiento
void handle_joystick() {
    int xValue = analogRead(pinX);
    int yValue = analogRead(pinY);
    if (yValue > 400 && yValue < 600 && xValue < 600 && xValue > 500) {
    if (yValue > 1000 && xValue < 700 && xValue > 300) {
    } else if (yValue < 100 && xValue < 700 && xValue > 300) {
    if (xValue < 50 && yValue < 700 && yValue > 300) {
    } else if (xValue > 1000 && yValue < 700 && yValue > 300) {
void handle_movement(char command) {
    switch (command) {
        case 'a':
        case 'b':
        case 'l':
        case 'r':
        case 'p':
When you open the serial port from python, your Arduino UNO reboots. so once you are done with the first program and want to launch the second one, that will reboot the arduino.
I've written a small tutorial on interfacing with Python. See Two ways communication between Python3 and Arduino - may be that can help.
Do you really need two different programs ?
Try disabling the reset in the second python code by setting dtr false.
eg:
puerto_serial.dtr = False
I made a mistake, the way it is the port will open automatically before the reset is disabled. The following will work
puerto_serial=serial.Serial()
puerto_serial.port="COM10"
puerto_serial.baudrate=9600
puerto_serial.dtr=False
