With an array like this.....
char* myStrings[]={"This is string 1", "This is string 2", "This is string 3",
"This is string 4", "This is string 5","This is string 6"};
What is the correct way to get the length of "myStrings[x]" to give the number of characters?
Will it require adding string.h to the sketch?
I am sure it's simple, but I have searched for hours now and still no answer!
Thanks if you can help!
size_t l = strlen(myString[0]);
On the arduino, you can almost certainly use int instead of size_t.
string.h is automagically added.
char* myStrings[] = {"This is string 1", "This is string 2", "This is string 3",
          "This is string 4", "This is string 5", "This is string 6"
 int totalLength = sizeof(myStrings);
 Serial.print(F("Size of the array is "));
 Serial.println(totalLength);
 for (byte idx = 0; idx < sizeof(myStrings) / sizeof(myStrings[0]); idx++) {
  int thisLength = strlen(myStrings[idx]) + 1;
  Serial.print(F("Size of element "));
  Serial.print(idx);
  Serial.print(F(" is "));
  Serial.println(thisLength);
  totalLength += thisLength;
 Serial.print(F("Total size of the array and the strings is "));
void loop() {}
Size of the array is 12
Size of element 0 is 17
Size of element 1 is 17
Size of element 2 is 17
Size of element 3 is 17
Size of element 4 is 17
Size of element 5 is 17
Total size of the array and the strings is 114
He wanted the number of characters, so I assume that that does not include the '\0', though I guess that is technically a character. 8^)
For me a '\0' is a character.
I knew it would be easy
Thank you both for the help!
Now I only have one other thing to sort out and the project is done!
