char array length
SOLVED:
used strLen(cmd)
OK...
This should be simple.
What am I missing?
   while (!Serial);
   transmit("getUid");
 void loop(){} // Empty, but necessary
 void transmit(char cmd[]){
    // check if data arrives ok
      Serial.print(":");  Serial.print(cmd);  Serial.println(":");  // :getUid: input OK.
    // get the arrays size
      byte size_1= sizeof(cmd);
      Serial.print("size_1 :");Serial.print(size_1);Serial.println(":");  // :2:
      byte size_2= sizeof(cmd)/sizeof(cmd[0]);
      Serial.print("size_2 :");Serial.print(size_2);Serial.println(":");  // :2:
      byte size_3= sizeof(cmd)/sizeof(byte);
      Serial.print("size_3 :");Serial.print(size_3);Serial.println(":");  // :2:
sizeof(cmd);will always return a value of 2 as what you passed to the transmit() function is a pointer to the char array not the char array itself.
using a * gives the same result.
void transmit(char *cmd){...}
so how, than, do I get the lenght?
Calculate it and pass it to the function
What do you want to do with the length in the function ?
