I need to send almost a thousand 3 digit numbers through the BLE module on an Arduino Uno Wifi Rev 2. Since the BLE module is limited to 512 Bytes per BLE characteristic. it needs to be separated into multiple characteristic to fit all the data.
The plan is to make a char array of 512 characters. 3 digits plus a comma for separation makes for 128 points of data per array.
To keep things simple, I am working in the RawDataAdvertising Example sketch for the ArduinoBLE Library.
Here is my code:
#include <ArduinoBLE.h>
BLEService myService("fff0");
char stringValue[] = "nothing written yet";
BLECharacteristic myCharacteristic("fff1", BLERead | BLEBroadcast,stringValue);
// Advertising parameters should have a global scope. Do NOT define them in 'setup' or in 'loop'
const uint8_t completeRawAdvertisingData[] = {0x02,0x01,0x06,0x09,0xff,0x01,0x01,0x00,0x01,0x02,0x03,0x04,0x05};
while (!Serial);
if (!BLE.begin()) {
Serial.println("failed to initialize BLE!");
while (1);
myService.addCharacteristic(myCharacteristic);
BLE.addService(myService);
// Build advertising data packet
BLEAdvertisingData advData;
// If a packet has a raw data parameter, then all the other parameters of the packet will be ignored
advData.setRawData(completeRawAdvertisingData, sizeof(completeRawAdvertisingData));
// Copy set parameters in the actual advertising packet
BLE.setAdvertisingData(advData);
// Build scan response data packet
BLEAdvertisingData scanData;
scanData.setLocalName("Test advertising raw data");
// Copy set parameters in the actual scan response packet
BLE.setScanResponseData(scanData);
//section of interest
char crazyBigArr[512] = ""; //create array
for(int i = 0; i < 512; i++){
int theoRead = 111 * (i%10); //simulate the reading from loadsensor, not perfect, but good enough
Serial.print(theoRead);
Serial.print(",");
crazyBigArr[i] = (char)(theoRead/100); //isolate first digit
crazyBigArr[i+1] = (char)((theoRead%100)/10); // isolate second digit
crazyBigArr[i+2] = (char)(theoRead%10); //isolate third digit
crazyBigArr[i+3] = ','; //comma for separation
i+=3;
crazyBigArr[512] = '\n';
Serial.print("big Arr:");
Serial.println(crazyBigArr);
myCharacteristic.writeValue(crazyBigArr);
Serial.println("big data made");
BLE.advertise();
Serial.println("advertising ...");
BLE.poll();
I think the first issue that I'm having is that the char array is not getting written with my digits the way I want to.
previously, I tried to use a String and then convert to char array with .toCharArray(), but it caused the arduino to boot loop.
Currently the output on the serial monitor looks like this:
As you can see, the char array doesn't get filled. I'm sure there is an easy explanation, I could use an extra set of eyes here.
Your input is much appreciated!!!
