not used the Nano for Canbus but this example runs on a Mega using a MCP2525
// Mega MCP2515 CAN send/Receive Example
// Mega <> MCP2515 connections
// MCP2515 INT to Mega GPIO2
// MCP2515 SCK to Mega GPIO52 CLK
// MCP2515 SI to Mega GPIO51 MOSI
// MCP2515 SO to Mega GPIO50 MISO
// MCP2515 CS to Mega GPIO53 CS
// MCP2515 GND to Mega GND
// MCP2515 VCC to Mega 5V
#include <mcp_can.h>
#include <SPI.h>
long unsigned int rxId;
unsigned char len = 0;
unsigned char rxBuf[8];
char msgString[128]; // Array to store serial string
#define CAN0_INT 2 // for Mega
MCP_CAN CAN0(10);//53); //
delay(2000);
Serial.println("\n\nMega- CAN MCP2515 shield Send/Receive test - MCP2515 Initialize");
Serial.print("MOSI: ");
Serial.println(MOSI);
Serial.print("MISO: ");
Serial.println(MISO);
Serial.print("SCK: ");
Serial.println(SCK);
Serial.print("SS: ");
Serial.println(SS);
// Initialize MCP2515 baudrate of 250kb/s and the masks and filters disabled.
// check crystal frequency!! e.g. Canbus shield is 16MHz MCP2515 is 8MHz
if (CAN0.begin(MCP_ANY, CAN_125KBPS, MCP_8MHZ) == CAN_OK)
Serial.println("CAN Receive - MCP2515 Initialized Successfully!");
Serial.println("Error Initializing MCP2515...");
CAN0.setMode(MCP_NORMAL); // Set operation mode to normal so the MCP2515 sends acks to received data.
pinMode(CAN0_INT, INPUT_PULLUP); // Configuring pin for /INT input *** added PULLUP ***
Serial.println("MCP2515 Library CAN Send/Receive Example\n enter space to send a frame");
// check for data received
if (!digitalRead(CAN0_INT)) // If CAN0_INT pin is low, read receive buffer
CAN0.readMsgBuf(&rxId, &len, rxBuf); // Read data: len = data length, buf = data byte(s)
if ((rxId & 0x80000000) == 0x80000000) // Determine if ID is standard (11 bits) or extended (29 bits)
sprintf(msgString, "Extended ID: 0x%.8lX DLC: %1d Data:", (rxId & 0x1FFFFFFF), len);
sprintf(msgString, "Standard ID: 0x%.3lX DLC: %1d Data:", rxId, len);
Serial.print(msgString);
if ((rxId & 0x40000000) == 0x40000000) { // Determine if message is a remote request frame.
sprintf(msgString, " REMOTE REQUEST FRAME");
for (byte i = 0; i < len; i++) {
sprintf(msgString, " 0x%.2X", rxBuf[i]);
// transmit data when space entered on keyboard
if(Serial.available()){
if (Serial.read() != ' ') return;
static byte data[8] = { 0x00, 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07 };
for (byte i = 0; i < 8; i++) {
sprintf(msgString, " 0x%.2X", data[i]);
// send data: ID = 0x100, Standard CAN Frame, Data length = 8 bytes, 'data' = array of data bytes to send
byte sndStat = CAN0.sendMsgBuf(0x100, 0, 8, data);
if (sndStat == CAN_OK) {
Serial.println(" Message Sent Successfully!");
Serial.println(" Error Sending Message...");
data[0]++; // increment first byte of data
Mega Serial monitor output sending/receiving canbus frames
MOSI: 51
MISO: 50
SCK: 52
SS: 53
Entering Configuration Mode Successful!
Setting Baudrate Successful!
0x00 0x01 0x02 0x03 0x04 0x05 0x06 0x07 Message Sent Successfully!
0x01 0x01 0x02 0x03 0x04 0x05 0x06 0x07 Message Sent Successfully!
Standard ID: 0x100 DLC: 8 Data: 0x00 0x4D 0x45 0x47 0x41 0x00 0x07 0x08
Standard ID: 0x100 DLC: 8 Data: 0x01 0x4D 0x45 0x47 0x41 0x00 0x07 0x08
Standard ID: 0x100 DLC: 8 Data: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Extended ID: 0x000FF100 DLC: 8 Data: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Standard ID: 0x100 DLC: 8 Data: 0x02 0x4D 0x45 0x47 0x41 0x00 0x07 0x08
0x02 0x01 0x02 0x03 0x04 0x05 0x06 0x07 Message Sent Successfully!
0x03 0x01 0x02 0x03 0x04 0x05 0x06 0x07 Message Sent Successfully!
UNO Serial monitor output sending/receiving canbus frames
UNO CAN MCP2515 shield Send/Receive test - MCP2515 Initialize
Standard ID: 0x100 DLC: 8 Data: 0x00 0x01 0x02 0x03 0x04 0x05 0x06 0x07
Standard ID: 0x100 DLC: 8 Data: 0x01 0x01 0x02 0x03 0x04 0x05 0x06 0x07
0x00 0x4D 0x45 0x47 0x41 0x00 0x07 0x08 Message Sent Successfully!
0x01 0x4D 0x45 0x47 0x41 0x00 0x07 0x08 Message Sent Successfully!
Extended ID: 0x000FF100 DLC: 8 Data:0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
0x02 0x4D 0x45 0x47 0x41 0x00 0x07 0x08 Message Sent Successfully!
Standard ID: 0x100 DLC: 8 Data: 0x02 0x01 0x02 0x03 0x04 0x05 0x06 0x07
Standard ID: 0x100 DLC: 8 Data: 0x03 0x01 0x02 0x03 0x04 0x05 0x06 0x07
don't forget Canbus is a peer-to-peer network - all devices are equal - all can transmit and all receive every message
it is a priority based protocol with the CAN IDs determining priority - if you have a number of nodes exchanging messages set the message IDs so high priority messages get thru first
receivers can use filters to filter out the messages which are of interest or for simplicity use if statements, e.g. a can module controlling the lights will accept only messages controlling light settings
unless you are using devices with preassigned Can IDs you assign each Can node on your vehicle a CAN ID - 11bit is probably sufficient
design a protocol which can be very simple - each CAN message can be up to 8ytes
I find when testing Can networks a USB-CAN dongle which plugs into a PC and displays traffic etc very useful for monitoring and debugging the network
