Some DHT22 temperatures are being sold (Ebay) that are not genuine. Genuine sensors will read temperatures down to -50degC. The defective types measure temperature OK above zero but return large and incorrect values when the temperature drops below zero. This has been a topic of discussion before:
I have investigated this and discovered that the sensor will produce a reading of -3276.8 at the point that the temperature drops below zero. The readings do change with temperature: e.g at -0.4 degC the reading is -3276.4; at -0.8 degC the reading is - -3276.0. So it is possible to correct for this error using the following code:
float t = dht.readTemperature();
// Read temperature as degC
Add this code to make the correction if required.
if (t < -50) { // The correction will not be applied if a genuine DHT22 is used
t = -3276.8 - t ; // correct value if t< 0
This will return negative temperatures correctly
