I am building a project that requires precise location data (< 2 meters). I am thinking that the best way to do this would be by using GPS, but I would like it to be less than 15 USD. Any ideas for GPS module that could accomplish this? Is there a better way to do this than GPS? If there are no cheap options, what is a module that I could use?
Unfortunately, that is the very best that standard GPS modules can do when outdoors, with a clear view of the sky and lots of satellites visible.
Under less than ideal conditions errors of up to 50 m are common, if the module manages to get a fix. If not, the module informs you that no valid position estimate is possible.
