Cheap Hot Air Station With Arduino
Buongiorno a tutti,vorrei realizzare questo piccolo proggetto trovato in rete con arduino nano,termocoppia max6675,lcd 16,2.
Ho acquistato una nano cinese per iniziare,o provato con il blik tutto ok,
Poi o caricato questo sketch che e dentro all progetto ma non ne vengo a capo,per me che sono all inizio e troppo.
Questo e l'errore.
error: no matching function for call to 'MAX6675::MAX6675(int&, int&, const uint8_t&, int&)'
Questo lo sketch
#include <max6675.h>
#include <Wire.h>
#include <MAX6675.h>
// Initialize the MAX6675 Library for our chip
LiquidCrystal_I2C lcd(0x27,16,2);  // set the LCD address to 0x27 for a 16 chars and 2 line display
int chauffe;
int vent;
int plus;
int moins;
int led;
int temperature;
int etatboutonplus;
int etatboutonmoins;
int reed;
int CS = 5;             // CS pin on MAX6675
int SO = 4;              // SO pin of MAX6675
int aSCK = 6;             // SCK pin of MAX6675
int units = 1;            // Units to readout temp (0 = raw, 1 = ˚C, 2 = ˚F)
float temperaturemesure = 0.0;  // Temperature output variable
MAX6675 temp(CS, SO, SCK, units);
  temperature=200;
  chauffe= 13;
  vent=12;
  plus=11;
  moins=7;
  led=3;
  reed=2;
  pinMode(chauffe, OUTPUT);
  pinMode(vent, OUTPUT);
  pinMode(plus, INPUT_PULLUP);
  pinMode(moins, INPUT_PULLUP);
  pinMode(led, OUTPUT);
  pinMode(reed, INPUT_PULLUP);
  lcd.init();                      // initialize the lcd
  lcd.backlight();
  lcd.setCursor(3,0);
  lcd.print("Station a ");
  lcd.setCursor(3,1);
  lcd.print("air chaud ");
  delay(1500);
  lcd.clear();
  lcd.setCursor(1,0);
  lcd.print("Marmotte 2017");
  lcd.setCursor(3,1);
  lcd.print("Version 1 ");
  delay(1500);
  temperaturemesure = temp.read_temp();
   lcd.clear();
   lcd.setCursor(0,0);
   lcd.print("Reglage: ");
  lcd.print(temperature);
  lcd.print(" C");
   lcd.setCursor(0,1);
   lcd.print(temperaturemesure);
  if (digitalRead (5) == LOW)
   digitalWrite(led, LOW);
    lcd.setCursor(0,1);
   lcd.print("Station en pause");
else {
  if (temperaturemesure <= temperature)
  digitalWrite(chauffe, HIGH);
  digitalWrite(led, HIGH);
  digitalWrite(vent, HIGH);
  else {
    digitalWrite(chauffe, LOW);
  if (digitalRead (11) == LOW)
    temperature=temperature+10;
else {
  if (digitalRead (7) == LOW)
    temperature=temperature-10;
else {
  delay(100);
Buongiorno, scai75
Benvenuto nella sezione Italiana del forum :slight_smile:
Cortesemente, leggi attentamente QUESTO STESSO MESSAGGIO e il REGOLAMENTO di detta sezione:
[REGOLAMENTO] Come usare questa sezione del forum
(... e, per evitare future possibili discussioni/incomprensioni, prestando molta attenzione al punto 15)
e poi, come da suddetto regolamento (punto 16.7), fai la tua presentazione IN CODA ALL'APPOSITA DISCUSSIONE:
Presentazioni nuovi iscritti: fatevi conoscere da tutti! (Part 2)
spiegando bene quali esperienze hai in elettronica e in programmazione, affinché noi possiamo conoscere la tua esperienza ed esprimerci con termini adeguati.
Come da regolamento, per cortesia, metti un titolo che permetta di capire l'argomento e che possa essere facilmente ritrovato in seguito. La domanda, dettagliata, va posta nel corpo del messaggio. Abituati a fare tutto con ordine: è la base per ottenere buoni risultati.
Il programma va inserito nel corpo del messaggio, invece che allegato, in maniera che sia facilmente visibile, e deve essere scritto in maniera ordinata e correttamente indentato (puoi farlo nell'IDE con CTRL+T), in maniera che chi legge la discussione sia invogliato a comprenderlo e a rispondere.
Grazie
Gianluca
P.S.: Ti ricordo che, purtroppo, fino a quando non sarà fatta la presentazione nell’apposita discussione, nel rispetto del succitato regolamento, nessuno ti risponderà (eventuali risposte, o tuoi ulteriori post, verrebbero temporaneamente nascosti), quindi ti consiglio di farla al più presto. :wink:
P.P.S.: Evitate di utilizzare la traduzione automatica fatta dal browser ... vi impedisce di capire la lingua della sezione dove andate a scrivere ...
Ok Grazie
Sei sicuro di questa riga?
Buongiorno e grazie tanto per il tuo aiuto,sono alle prime armi seguo un corso online,quindi per me ora niente e sicuro,ricontrollo.
Grazie.
Questa e la parte dell maxx6675
Schema
ho fatto un test con display e sonda max6675 ed o caricato lo sketch,tutto ok,pero'sull altro sketch i 3 pin di controllo sonda erano in posizioni diverse.
Beh
Diverso programma diverso schema, non trovi?
Scommettiamo che alla fine troviamo un problema legato al casting di tipi inesistenti?
Buongiorno a tutti e buona domenica,ieri sera o accelerato il corso e gia sono alle variabili,bello sempre piu interessante.spigato da Paolo.O
Quale corso?
Ti ho chiesto di controllare una riga, lo hai fatto?
Buonasera il corso di Arduino, non riesco a controllare per me e ancora presto.
... scusa, come pensi che noi riusciamo a trovarlo? Hai idea di quanti ne esistono?
Spiega CHE corso, DOVE, link, ecc. ecc.
Guglielmo
Ovvero stai dicendo che non riesci a controllare se hai copiato bene una riga di pochi caratteri?
La prendo per buona e ne deduco che sia troppo presto per darti consigli
A dopo
Qui
Si infatti e cosi ancora non riesco,era solo che mi sono fidato troppo che lo sketch era corretto,ed o costruito prima tutto su pcb ora mi tocca cambiare o aspettare che si risolva.
come dire o chiamato san paolo prima che venisse il serpe...
Scai75 devi cambiare :
int aSCK = 6;
Con :
int SCK = 6;
Hai capito?
Ho deciso di controllare io se la riga era giusta
ho trovato il sito del progetto e confermato che la riga è giusta
l'errore è un poche righe dopo
ma guardando bene il sito del progetto:
temo che ci sia una piuttosto grave violazione del regolamento
in particolare dato che lo OP è chiaramente non in grado di seguire nemmeno progetti semplici
PS:
grazie al fratello, che ha deciso lui di "sbattersi" al posto dello OP
Buonasera quindi si deve chiudere?
non puoi dirmi .
... se l'OP parlasse dei collegamenti fisici e dell'hardware, ma al momento mi sembra sia solo perso nei meandri del software e non abbia fatto alcun rifermento al progetto che riporti.
Al limite, se si fa male, i problemi li ha chi a pubblicato quell'articolo ... noi qui consigli sui collegamenti NON ne diamo e che l'OP non ne parli e non chieda o ... la chiusura è assicurata :wink:
Guglielmo
Soprattutto non vedo la convenienza, considerando che l'858D su Aliexpress si trova a 33€ e il costo dello stilo e di tutto il resto...
Si buongiorno e cosi,ma avevo dell materiale di recupero da una stazione rotta .
In rete ci sono vari progetti riprovero" con qualcosa di simile anche cambiando scheda.
Pero"sull progetto della stazione con stilo e andata bene.
Buonasera a tutti,volevo chiedervi ma se posto un altro sketch dove pultroppo
ho un altro errore,potete aiutarmi?
Grazie
