Bitte um Hilfe mit meinem Tiefziehgerät
Hallo.
Ich bin neu hier und mache meine Esten Schritte mit dem Arduino Uno .
Ich baue mir gerade ein Tiefzieherät und habe. Das Sketch habe ich bekommen. Beim Instatieren bekomme ich die Fehlermeldung
H:\Tiefzieher\VacuumFormer\VacuumFormer.ino:13:10: fatal error: max6675.h: No such file or directory
#include <max6675.h>
compilation terminated.
exit status 1
Compilation error: max6675.h: No such file or directory
Das ist der Sketch den ich bekommen habe.
Kann mir da jemand helfen?
//= M A K E & T I N K E R =
//= Vacuum Former v1.0 =
//= March 2020 =
//= http://www.youtube.com/makeandtinker/ =
// INITIALIZATION
#include <Wire.h>
#include <LiquidCrystal.h>
LiquidCrystal lcd(8, 9, 4, 5, 6, 7); // Parameters: (rs, enable, d4, d5, d6, d7)
const int maxTemp = 290; // Stores the maximum temperature that the coils are allowed to reach (in Celsius)
const int maxWarn = 49; // Stores the temperature that triggers a warning for dangerous hot surface (in Celsius)
// Custom thermometer icon for the LCD display:
byte thermo[8] = {
B00100,
B01010,
B01010,
B01110,
B01110,
B11111,
B11111,
B01110
// Custom heating element icon for the LCD display:
byte coil[8] = {
B11111,
B00000,
B01001,
B10010,
B10010,
B01001,
B01001,
B10010
//Asign pin numbers for connections to sensors and parts
const byte pinRelay = 2; //Pin for relay data
const byte ledPinR = 10; // Red value for RGB LED
const byte ledPinG = 12; // Green value for RGB LED
const byte ledPinB = 13; // Blue value for RGB LED
const byte pinBuzzer = A3; // Pin data for piezo buzzer
const byte pinSwitch = A4; // Pin data for safety switch
const long runTime = 1000; //Read time every 1 second
unsigned long prev_runTime = 0; // Previous run time
bool heatStarted = false; // Holds the value for the heating coil power status
bool switchStatus = false; // Holds the value for the safety switch
int heatTimer = 0; // Set milliseconds for alarm timer to 0
const int maxRunTime = 40; // Minutes to max running time before shutdown
const int maxTime = 1500; // Set seconds to run before alarm sounds (1500 = 25 mins)
int mins = 0; // Minutes elapsed
int secs = 0; // Seconds elapsed
String tempNow = ""; // Holds value of current temperature
//Thermocouple setup:
#define CONFIG_TCSCK_PIN A0
#define CONFIG_TCCS_PIN A1
#define CONFIG_TCDO_PIN A2
MAX6675 thermocouple(CONFIG_TCSCK_PIN, CONFIG_TCCS_PIN, CONFIG_TCDO_PIN);
// SETUP
lcd.begin(20, 4); // Display is 20 characters long x 4 lines
lcd.createChar(0, thermo); //Creates custom char for thermometer
lcd.createChar(1, coil); //Creates custom char for heating coil
String tempNow; //Creates a string variable to hold the text value of the current temperature
// Setup pins on Arduino board:
pinMode(pinRelay, OUTPUT);
pinMode(pinSwitch, INPUT);
pinMode(pinBuzzer, OUTPUT);
pinMode(ledPinR, OUTPUT); // Red LED pin
pinMode(ledPinG, OUTPUT); // Green LED pin
pinMode(ledPinB, OUTPUT); // Blue LED pin
digitalWrite(pinRelay, HIGH); //To be safe, start with the relay turned off (power cut to coils)
//Turn on the LED in blue:
analogWrite(ledPinR, 0);
analogWrite(ledPinG, 0);
analogWrite(ledPinB, 255);
//Display splash screen information on LCD:
lcd.setCursor(2, 0);
lcd.print("MAKE & TINKER");
lcd.setCursor(3, 2);
lcd.print("Vacuum Former");
lcd.setCursor(7, 3);
lcd.print("v 1.0");
// Play the startup tune:
tone(pinBuzzer, 1000, 250);
delay(250);
tone(pinBuzzer,500, 250);
delay(250);
tone(pinBuzzer, 2000, 500);
delay(2000);
lcd.clear(); // Clear the LCD screen:
// EMERGENCY SHUTDOWN LOOP
void doShutDown() {
// This is an ENDLESS LOOP for emergency shutdown
// The machine has to be turned off and on again to restart
digitalWrite(pinRelay, HIGH); //First, turn off relay to cut power to heating coils
lcd.clear(); // Display info about emergency shutdown on LCD:
lcd.setCursor(0,0);
lcd.print("");
lcd.setCursor(1,1);
lcd.print(" SAFETY SHUTDOWN ");
lcd.setCursor(0,2);
lcd.print("<-- RESTART REQUIRED");
lcd.setCursor(0,3);
lcd.print("
while (1>0) { // Blink the LED and sound alarm:
analogWrite(ledPinR, 255); // Turn on the LED red
analogWrite(ledPinB, 0);
tone(pinBuzzer, 300, 500); // Sound the alarm
delay(600);
analogWrite(ledPinR, 0); //Turn off the LED
delay(600);
// MAIN LOOP
unsigned long currTime = millis(); // Time elapsed in milliseconds
lcd.setCursor(0, 1);
lcd.write(byte(0)); //Draws the thermometer icon
lcd.setCursor(2, 1);
// DISPLAY INFO ON THE SCREEN AND STATUS LED /////////////////////////////////////////////////////////////////////
lcd.print(String(int(thermocouple.readCelsius())) + ((char)223) + "C " + String(int(thermocouple.readFarenheit())) + ((char)223) + "F "); // Show the temperature in ºC and ºF
tempNow = (String(int(thermocouple.readCelsius()))); // Store the current temp reading from thermocouple
if (tempNow.toInt() > maxWarn) { //If temperature is higher than the max safe value:
lcd.setCursor(0, 0); // Sets the curson on the first row
lcd.print ("** CAUTION! HOT! "); //Display the warning message on the screen
lcd.setCursor(0, 3); // Sets the curson on the 4th row
lcd.print ("
CAUTION! HOT! **"); //Display the warning message on the screen
analogWrite(ledPinR, 255); //Turn on the LED in Red
else {
lcd.setCursor(0, 0); // Sets the cursor on the first row
lcd.print (" "); //Erase the warning message on the screen
lcd.setCursor(0, 3); // Sets the cursor on the first row
analogWrite(ledPinR, 0); //Turn on the LED in Green
analogWrite(ledPinG, 255);
// SAFETY TIMER AND ALARM /////////////////////////////////////////////////////////////////////////////////////////
switchStatus = String(digitalRead(pinSwitch)) == "1";
if (!heatStarted) { //If timer has not started, check if the button is pressed:
if (switchStatus) { //If the button is pressed, start the timer
heatStarted = true;
else { //If the safety switch is not pressed, reset the timer:
heatTimer = 0;
else {
if (switchStatus) { //If the safety switch is pressed, add a second and check the time:
if (currTime - prev_runTime >= runTime){
heatTimer++; // Increase the timer
secs++; // Add 1 second to the seconds counter
    if (secs == 60) { // If seconds are at 60:
      mins++; // Add 1 minute
      secs = 0; // Reset seconds to 0
    // Convert time values to text:
    String tmins = String(mins);
    String tsecs = String(secs);
    if (mins < 10) { // If minutes are less than 10, add a zero to the left
      tmins = "0" + tmins;
    if (secs < 10) { // If seconds are less than 10, add a zero to the left
      tsecs = "0" + tsecs;
    lcd.setCursor(8,1);
    lcd.print(tmins + ":" + tsecs); //Display the elapsed operation time
    if (heatTimer >= maxTime) { // If max time has been reached or exceeded, sound the alarm:
    prev_runTime = currTime; // Set the current time as previous time
    if (mins >= maxRunTime) { // If the heating coils have been working for more time than the max run time:
      doShutDown(); // Go to the emergency shutdown function
else { //If timer is running but the safety switch is not pressed, turn off the alarm and reset the flag the timer:
  noTone(pinBuzzer);
  heatTimer = 0; // Reset timer to 0
  mins=0; // Reset minutes to 0
  secs=0; // Reset seconds to 0
  lcd.setCursor(8,1);
  lcd.print("     "); // Erase the time on LCD
// CONTROL THE HEATING COILS WITH THE RELAY DEPENDING ON SENSOR AND/OR SWITCH INPUT ////////////////////////////////
if (switchStatus) { //If the safety switch is pressed (frame is up and ready to work):
//Check if the temperature of the heating elements is under the safe limit:
if (tempNow.toInt() > maxTemp) { //If coil temperature exceeds the value set for maxTemp, disconect the relay to turn it off
lcd.setCursor(0,2);
lcd.write(byte(1)); //Draws the heating element icon
lcd.setCursor(2,2);
lcd.print ("OFF "); //Display the heating coil's status on the screen
else {
//If coil temperature is under the set value for maxTemp, engage the relay to turn it on
digitalWrite(pinRelay, LOW);
lcd.setCursor(0,2);
lcd.setCursor(2,2);
lcd.print ("ON FOR:"); //Display the heating coil's status on the screen
else { //If the safety switch is not pressed (frame is down, not ready to work):
digitalWrite(pinRelay, HIGH); //Turn off the heating element, regardless of actual temperature
lcd.setCursor(0,2);
lcd.setCursor(2,2);
delay(500); // Milliseconds to wait before restarting loop
Dir fehlt die Programm-Bibliothek MAX6675-library.
In der Arduino-IDE werden mehrere angeboten, da mußt Du in der Dokumentation mal nachsehen, welche die richtige ist. Beliebt sind die von Adafruit.
Du musst den max6675 installieren!
In der IDE Werkzeuge, Bibliotheken verwalten ´,im Suchfeld max6675 eintippen
DANKE agmue danke fony . Hat funktioniert. :heart_eyes:
Danke für Deine Rückmeldung!
