I'm looking for a MicroSD card socket like:
It seems rather expensive for what you get. If anyone has found a cheap source of a component like this I would gladly hear of it!
Cheers,
Jack
Cheers,
Jack
ebay 131132034753
micro-sd, no regular, with voltage converter
or regular sd without the voltage converter
111318718028
word of caution. not all SD sleeves can be soldered with a hot iron. some have the connectors burred under the housing and need more delicate attention
also, some have a switch to signal when a card is installed
some have a push-in, pop out mechanism.
most you see for $1.00 are totally manual. you push in and you pull out.
the link was to a push in-pop out, much more mechanical than the manual ones.
In qtys of 1000 they are cheap! http://uk.farnell.com/global-connector-technology/mem2060-01-190-00-a/memory-card-connector-microsd-8pos/dp/2413815
@dave-in-nj: that first one (131132034753) is spot on ! What a beautiful find ! I can't replicate them for that price, thank you so much. I see I should use ebay more often as a place to look for good and cheap electronics. Apart from ebay (and dx.com), would you recommend any other site to check out before inquiring here at the forums?
@markT: hahaha, I wish my project would need a 1000, that would mean a 1000-person lasertag game, that would be epic ^^ I'll settle for the above from ebay, but your input is appreciated, thanks
Cheers,
Jack
I had used a micro SD Card Adapter like this.
I had soldered some pins to the adapter.
Nabe
... wow ... that is also a very elegant solution. It might not beat the added 3v3 regulator and the 4050 chip on the smd board, but I might use this for another project, cheers !
and schematic
http://homepage3.nifty.com/two_legs/neo/project/Arduino_LCD/LCD10.jpg
I used it in this work.
Nabe
Thanks for sharing, that is quite an impressive project !
Cheers, Jack
