felic
#1
I found this piece of code:
bool check_whitelist(uint8_t *macAdress){
unsigned int i=0;
for (i=0; i<WHITELIST_LENGTH; i++) {
if (! memcmp(macAdress, whitelist[i], ETH_MAC_LEN)) return true;
return false;
in this file.
And I’d like to change it so that instead of returning true if macAdress
is in whitelist[]
, it returns true if macAdress
starts with certain digits.
So I’d like to change it to something like this:
bool check_blacklist(uint8_t *macAdress){
if (macAdress.startsWith("BE:EF:99")) {
return true;
return false;
How could I achieve that?
blh64
#2
Typically, macAddress would be an array of 6 bytes. It appears you only want to check the first 3 so change the comparison to test the first 3 bytes
if (macAdress[0] ==0xBE && macAddress[1] == 0xEF && macAddress[2] == 0x99)) {
return true;
return false;
felic
#3
It's not an array though or is it? The type is uint8_t *
from what I can tell. Wouldn't it be something like uint8_t[] *
if it was an array?
gfvalvo
#4
Nope, macAdress is being treated as an array. Arrays and pointers are very closely related in C / C++. For example: https://codeforwin.org/2017/10/c-pointers-array-relationship-use.html
felic
#5
Thank you, that article was very helpful! And also thanks to blh64!
