Here my current version:
Breadboard Arduino (Atmel 328P) with ArduinoISP software loaded
then I set:
Tools > Board >Arduino Mega or Mega2560
Tools > Programmer to Arduino as ISP
Tools > Burn Bootloader
This works fine and now the 'L' LED is flashing
so I load the Blink sketch into the Arduino software and change the delays to be able to see a difference in the flashing frequency (changed line 26 to delay(2000))
Now I upload the file with: File>Upload Using Programmer
It seems to work (avrdude output below), but now the 'L' LED just stays on.
Any suggestions on what I am doing wrong?
avrdude gives me following output (verbose mode)
avrdude: Version 6.0.1, compiled on Apr 3 2014 at 23:12:16
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino/hardware/tools/avr/etc/avrdude.conf"
Using Port : COM7
Using Programmer : stk500v1
Overriding Baud Rate : 19200
AVR Part : ATmega2560
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 8 0 no 4096 8 0 9000 9000 0x00 0x00
flash 65 10 256 0 yes 262144 256 1024 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.05s
avrdude: Device signature = 0x1e9801
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "C:\Users\Bjoern\AppData\Local\Temp\build896673534544120819.tmp/Blink.cpp.hex"
avrdude: writing flash (1518 bytes):
Writing | ################################################## | 100% 1.55s
avrdude: 1518 bytes of flash written
avrdude: verifying flash memory against C:\Users\Bjoern\AppData\Local\Temp\build896673534544120819.tmp/Blink.cpp.hex:
avrdude: load data flash data from input file C:\Users\Bjoern\AppData\Local\Temp\build896673534544120819.tmp/Blink.cpp.hex:
avrdude: input file C:\Users\Bjoern\AppData\Local\Temp\build896673534544120819.tmp/Blink.cpp.hex contains 1518 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.97s
avrdude: verifying ...
avrdude: 1518 bytes of flash verified
avrdude done. Thank you.
