I'm looking into automating my chicken coop.
I was going to use a basic timer and motor to open\close the door but this looks like a great opportunity to visit the Arduino platform
To begin with I was hoping to start with the basic door opening\closing. What hardware should I get?
I think I need:
Arduino Uno - R3
Light Sensor (LDR)
A motor control board? I guess it needs to take 12V? Is there such a thing?
Some kind of 12V motor & gearbox.
The door is attached to a long vertical bolt that needs to be turned 180 degrees to open\close (It’s an Eglu Classic). I will make an arm to attach to the handle on top of the coop to do this.
It’s going to need to reverse the voltage to close the door, is that possible with a motor control board?
With the timing, would it be better to use a clock with an offset to work out sunset\sunrise or rely on the LDR? (Or maybe both?) I guess it could be programmed to check the amount of light of a set period to stop false closure from shadows\clouds etc?
I have some .net programming experience so C might be a learning curve - my main weakness is the electronics side.
Thanks for your advice!
I was hoping for a slow gradual movement, to stop any heads from being removed! Will a servo have this ability when controlled from the board?
I have a 12V solar panel and battery so hoping to use a 12V motor.
Here’s an example of a fellow owners setup.
I don't have anything above the coop, the only mounting points are the coop itself or a fence post nearby.
I was thinking of a long threaded bolt connected to a 12V motor and some kind of mechanism that rotates as the thread turns (connected to the handle)
Yes, that's one of the things they do - search here for H bridge to find out more
Likely easier to use a clock. There was a thread on this topic by SouthernAtHeart a while back, where the system was going to be programmed to calculate sunrise & sunset based on latitude. The code for it is in that thread if you can find it.
For chicken coop purposes, I wouldn't think you need the accuracy of the radio time signal.
That motor controller is apparently rated for 2 Amps - you could certainly use it for testing, but you might want to hold off on that purchase until you have selected (and tested) the motor you'll use in the project - it may need more juice than that.
I'm not sure if I should use an RTC with a calculation or an LDR?
How accurate is the below over a period of time? (i.e will it require weekly adjustments?)
Could someone double check my calculations?
Sunrise Sunset Daylight
23 June: 04:41 21:25 16 h, 44 min
23 Dec: 08:07 15:53 7 h, 46 min
Sunrise @23 june = 4:41 = 60 * 4 + 41 = 281
Sunrise @23 dec = 8:07 = 60 * 8 + 7 = 487
delta = 487 - 281 = 206 => divide by 2 makes 103
average = (487 + 281)/2 = 384
Sunset @23 jun = 21:25 = 60 * 21 + 25 = 1285
Sunset @23 dec = 15:53 = 60 * 15 + 53 = 953
delta = 1285 - 953 = 332 => divide by 2 makes 166
average = (1285 + 953)/2 = 1119
madlan:
I suppose it depends on your chicken's bedtime routine but if it were me I'd ditch the RTC and just go with a simple (and cheap) LDR. As the other thread says, you could detect 15 minutes of light and call that sunrise and open the door. Then detect 15 minutes of darkness and close the door. This would allow the system to ignore quick dark storms, solar eclipses(!) etc. and the electronics and programming would be simpler. The other thread shows some pics of the final installation (using RTC chip) - you would need half the components going the LDR route (no need for keypad or LCD). And I don't think the chickens would care.
I have cheated and bought an automatic coop opener that is a commercial product. It relies solely on an LDR and it has worked faultlessly for over a year now. Basically, it waits for dark for maybe 30-45 minutes after sunset before the door is closed, likewise, it waits for daylight approx 30-45 mins after sunrise before opening. The motor is a simple dc 3v model with a low ratio gearbox such that it turns a shaft probably no more than 2mm in diameter. This gives it a tremendous torque and powers the door with ease. I guess it senses motor current and turns off when a preset level is reached and the door is snug against the stop. To release, motor is powered down for a set period of time, gravity bringing the door down. When the door reaches the floor the motor continues to turn and does leave some string loose in the motor compartment but this doesn't matter as it is soon taken up on the close stroke. Additional buttons to open/close manually, a led or two to confirm what's going on and a beeper to signal it's in manual mode. It runs on 3 x AA re-chargeables with a small solar panel to keep them topped up. I relocated the solar panel to a position that is more suitable and have had no problems to date. Without the solar panel, the AA's lasted over 3 months without any top up at all. I use Eneloops.
I don't think you need to worry about an RTC as the chicken's routine is governed by light levels, not time. Egg production is proportional to daylight hours so this beauty earns it's keep and I get to have a lie in too!
I just re-read your post and realise that your door opener is different. The same principal could apply. Tension the door handle shaft with a spring to power it closed and use the motor to pull against it. When the door is fully open, sense the extra current and stop the motor. The friction of your low gearing is your "brake" and will hold open indefinitely. 3v motor with a low ratio gearbox powered by AA cells is all you really need. Mine takes about 10 - 15 seconds to fully open. The chickens don't mind.
Thanks for your reply. The mechanics are actually the biggest headache for me – I don’t want to damage the coop.
What type of motor should I use? (I’m a programmer, the hardware is a mystery to me!)
Here's the door\handle:
If the motor assembly is behind the coop, I could attach a sprint to on end of the handle and some string to the other. Is that what you mean?
madlan:
I believe this is your coop? Their pictures make it pretty clear what's going on (not to make fun of your skills with MS Paint
If you were to attach a weight scale to the handle about 1" from the center of rotation, how many pounds of force would be required to open the door? That's the question you need to answer in order to get the inch-pounds of torque that you require.
If your result is only a few inch-lbs of torque then your mechanism and electronics would be a lot simpler if you used a large RC servo for it. You can find servos that will give 10 inch-lbs for less than $20. You would no longer need the motor driver board but would need a 5V source for the servo which will cost less than $10.
The door turns very easily, just some light force and it's moving. The handle pushes down to lock it in place so I will need to spring load it to keep the handle up.
Will a servo have enough resistance to keep the door shut\open - even if the chickens try and push it?
When servos are powered off they are still quite difficult to turn because of the high gear ratio. Granted chickens are pretty tough and they have a lot of leverage pushing open the door; you might want to use a second servo to control the latch if you're concerned.
You're on target with the servo you have linked. Notably the metal gear types are preferred. The 15kg rating refers to the force at 1cm from axis of rotation. That same seller also sells devices that will handle your 12V to 5V conversion for the servo -- an Arduino alone can't supply enough amperage and is also less efficient.
With respect to using "two stiff rods" I assume you're thinking of a setup like this. Logically though you only need one rod (push/pull) or two strings/cables (pull/pull) like in the picture. I'd recommend using a stiff wire (like piano wire) though -- if something breaks you want it to be something cheap to replace.
madlan:
I noticed the Arduino can take up to 20V - would it not be better to power it directly from the (12V) battery?
It would be simpler, yes, and probably appropriate in most situations. The Arduino uses a linear voltage regulator which burns off the difference between the 12V and 5V as heat and thus is less efficient than a switching voltage regulator, however.
Hello I've started this thread and still am looking for some help. Can you please help find a door solution for my coop? Here's the link to the thread ----> http://forum.arduino.cc/index.php?topic=311018.0
