// Définition des notes
#define NOTE_B0 31
#define NOTE_C1 33
#define NOTE_CS1 35
#define NOTE_D1 37
#define NOTE_DS1 39
#define NOTE_E1 41
#define NOTE_F1 44
#define NOTE_FS1 46
#define NOTE_G1 49
#define NOTE_GS1 52
#define NOTE_A1 55
#define NOTE_AS1 58
#define NOTE_B1 62
#define NOTE_C2 65
#define NOTE_CS2 69
#define NOTE_D2 73
#define NOTE_DS2 78
#define NOTE_E2 82
#define NOTE_F2 87
#define NOTE_FS2 93
#define NOTE_G2 98
#define NOTE_GS2 104
#define NOTE_A2 110
#define NOTE_AS2 117
#define NOTE_B2 123
#define NOTE_C3 131
#define NOTE_CS3 139
#define NOTE_D3 147
#define NOTE_DS3 156
#define NOTE_E3 165
#define NOTE_F3 175
#define NOTE_FS3 185
#define NOTE_G3 196
#define NOTE_GS3 208
#define NOTE_A3 220
#define NOTE_AS3 233
#define NOTE_B3 247
#define NOTE_C4 262
#define NOTE_CS4 277
#define NOTE_D4 294
#define NOTE_DS4 311
#define NOTE_E4 330
#define NOTE_F4 349
#define NOTE_FS4 370
#define NOTE_G4 392
#define NOTE_GS4 415
#define NOTE_A4 440
#define NOTE_AS4 466
#define NOTE_B4 494
#define NOTE_C5 523
#define NOTE_CS5 554
#define NOTE_D5 587
#define NOTE_DS5 622
#define NOTE_E5 659
#define NOTE_F5 698
#define NOTE_FS5 740
#define NOTE_G5 784
#define NOTE_GS5 831
#define NOTE_A5 880
#define NOTE_AS5 932
#define NOTE_B5 988
#define NOTE_C6 1047
#define NOTE_CS6 1109
#define NOTE_D6 1175
#define NOTE_DS6 1245
#define NOTE_E6 1319
#define NOTE_F6 1397
#define NOTE_FS6 1480
#define NOTE_G6 1568
#define NOTE_GS6 1661
#define NOTE_A6 1760
#define NOTE_AS6 1865
#define NOTE_B6 1976
#define NOTE_C7 2093
#define NOTE_CS7 2217
#define NOTE_D7 2349
#define NOTE_DS7 2489
#define NOTE_E7 2637
#define NOTE_F7 2794
#define NOTE_FS7 2960
#define NOTE_G7 3136
#define NOTE_GS7 3322
#define NOTE_A7 3520
#define NOTE_AS7 3729
#define NOTE_B7 3951
#define NOTE_C8 4186
#define NOTE_CS8 4435
#define NOTE_D8 4699
#define NOTE_DS8 4978
#define REST 0
int buzzer = 7; // Broche + du buzzer
int metro = 100; //temporisation de la mélodie
int melody;
int melody_tetris[] = {
NOTE_E5, 4, NOTE_B4,8, NOTE_C5,8, NOTE_D5,4, NOTE_C5,8, NOTE_B4,8,
NOTE_A4, 4, NOTE_A4,8, NOTE_C5,8, NOTE_E5,4, NOTE_D5,8, NOTE_C5,8,
NOTE_B4, -4, NOTE_C5,8, NOTE_D5,4, NOTE_E5,4,
NOTE_C5, 4, NOTE_A4,4, NOTE_A4,8, NOTE_A4,4, NOTE_B4,8, NOTE_C5,8,
NOTE_D5, -4, NOTE_F5,8, NOTE_A5,4, NOTE_G5,8, NOTE_F5,8,
NOTE_E5, -4, NOTE_C5,8, NOTE_E5,4, NOTE_D5,8, NOTE_C5,8,
NOTE_B4, 4, NOTE_B4,8, NOTE_C5,8, NOTE_D5,4, NOTE_E5,4,
NOTE_C5, 4, NOTE_A4,4, NOTE_A4,4, REST, 4,
int melody_zelda[] = {
NOTE_AS4,4, NOTE_F4,-4, NOTE_AS4,8, NOTE_AS4,16, NOTE_C5,16, NOTE_D5,16, NOTE_DS5,16,//7
NOTE_F5,2, NOTE_F5,8, NOTE_F5,8, NOTE_F5,8, NOTE_FS5,16, NOTE_GS5,16,
NOTE_AS5,-2, NOTE_AS5,8, NOTE_AS5,8, NOTE_GS5,8, NOTE_FS5,16,
NOTE_GS5,-8, NOTE_FS5,16, NOTE_F5,2, NOTE_F5,4,
NOTE_DS5,-8, NOTE_F5,16, NOTE_FS5,2, NOTE_F5,8, NOTE_DS5,8, //11
NOTE_CS5,-8, NOTE_DS5,16, NOTE_F5,2, NOTE_DS5,8, NOTE_CS5,8,
NOTE_C5,-8, NOTE_D5,16, NOTE_E5,2, NOTE_G5,8,
NOTE_F5,16, NOTE_F4,16, NOTE_F4,16, NOTE_F4,16,NOTE_F4,16,NOTE_F4,16,NOTE_F4,16,NOTE_F4,16,NOTE_F4,8, NOTE_F4,16,NOTE_F4,8,
int melody_ode[] = {
NOTE_E4,4, NOTE_E4,4, NOTE_F4,4, NOTE_G4,4,//1
NOTE_G4,4, NOTE_F4,4, NOTE_E4,4, NOTE_D4,4,
NOTE_C4,4, NOTE_C4,4, NOTE_D4,4, NOTE_E4,4,
NOTE_E4,-4, NOTE_D4,8, NOTE_D4,2,
NOTE_E4,4, NOTE_E4,4, NOTE_F4,4, NOTE_G4,4,//4
NOTE_D4,-4, NOTE_C4,8, NOTE_C4,2,
int melody_godfather[] = {
REST, 4, REST, 8, REST, 8, REST, 8, NOTE_E4, 8, NOTE_A4, 8, NOTE_C5, 8, //1
NOTE_B4, 8, NOTE_A4, 8, NOTE_C5, 8, NOTE_A4, 8, NOTE_B4, 8, NOTE_A4, 8, NOTE_F4, 8, NOTE_G4, 8,
NOTE_E4, 2, NOTE_E4, 8, NOTE_A4, 8, NOTE_C5, 8,
NOTE_B4, 8, NOTE_A4, 8, NOTE_C5, 8, NOTE_A4, 8, NOTE_C5, 8, NOTE_A4, 8, NOTE_E4, 8, NOTE_DS4, 8,
NOTE_D4, 2, NOTE_D4, 8, NOTE_F4, 8, NOTE_GS4, 8, //5
NOTE_B4, 2, NOTE_D4, 8, NOTE_F4, 8, NOTE_GS4, 8,
NOTE_A4, 2, NOTE_C4, 8, NOTE_C4, 8, NOTE_G4, 8,
NOTE_F4, 8, NOTE_E4, 8, NOTE_G4, 8, NOTE_F4, 8, NOTE_F4, 8, NOTE_E4, 8, NOTE_E4, 8, NOTE_GS4, 8,
// JOUER TETRIS
void tetris() {
melody= melody_tetris; // défintion de la melodie
metro=144; // défintion du tempo
// JOUER ZELDA
void zelda() {
melody = melody_zelda; // défintion de la melodie
metro=88; // défintion du tempo
//JOUER ODE A LA JOIE
void ode(){
melody = melody_ode; // défintion de la melodie
metro=200; // défintion du tempo
// JOUER LE PARRAIN
void godfather() {
melody = melody_godfather; // défintion de la melodie
metro=80; // défintion du tempo
tetris();
delay(2000);
zelda();
delay(2000);
ode();
delay(2000);
godfather();
delay(2000);
// sizeof gives the number of bytes, each int value is composed of two bytes (16 bits)
// there are two values per note (pitch and duration), so for each note there are four bytes
int notes=sizeof(melody)/sizeof(melody[0])/2;
int wholenote = (60000 * 4) / metro; // this calculates the duration of a whole note in ms (60s/tempo)*4 beats
int divider = 0, noteDuration = 0;
// iterate over the notes of the melody.
// Remember, the array is twice the number of notes (notes + durations)
for (int thisNote = 0; thisNote < notes * 2; thisNote = thisNote + 2) {
divider = melody[thisNote + 1]; // calculates the duration of each note
if (divider > 0) {
noteDuration = (wholenote) / divider; // regular note, just proceed
} else if (divider < 0) {
noteDuration = (wholenote) / abs(divider); // dotted notes are represented with negative durations!!
noteDuration *= 1.5; // increases the duration in half for dotted notes
tone(buzzer, melody[thisNote], noteDuration*0.9); // 90% du temps de la note jouée et 10% de pause
delay(noteDuration); // durée entre 2 notes
noTone(buzzer); // arret du son entre 2 notes
// no need to repeat the melody.
