Hello!
I'm a tota "noob" coming to Arduino from a non-electronics, non-advanced-math background.
I'm confused about the following:
[1] Can I use a relatively-simple USB-->Nano-Every-->Breadboard-->ATTiny85 setup? Or do I really "need" to use an $18 to $100+ <!!!> board merely to flicker one little 0402-size LED...?
[2] If the abbreviated setup will do, can I then just use the MCU, with an appropriate battery (and resistor if necessary) to control the LED in the actual projects...?
[3] If 2 is true, do I really need to know all of the flavors of C, AND python, AND "git-speak", AND "Arduino-speak", to tell the MCU "alter the power to LED1 at pseudo-random interval X, and to LED2 at pseudo-random interval Y", or is there "one program to rule them all" so to speak...?
[4] If 3 is true, is that One Program the one that's downloaded from arduino.cc (i.e., the "IDE") - AND will that version even comminicate with the Nano and the MCU? (I saw someplace mention that I'd need "the old IDE", which I find confusing.)
The reason I ask all of that is:
I want to include the above LEDs in 1:120 up to maybe 1:100 scale miniatures. Due to the small sizes, using a commercial LED tealight to control the 0402s is completely impossible due to space constraints (since I'd also need extra battery power and extra resistors and so on just to deal with the silly relatively-gigantic commercial things). I actually tried that, and ruined the miniature I had been working on because I tried to force all the stuff to fit...
Although I can now buy pre-wired 0402s with an inline flicker widget, they're twice the cost of the parts that I (perhaps delusionally???) thought I could use for this, and to be honest, my budget is also on the miniature side, so costs matter. Plus, I'd have no control over the length of the wire leading from the flicker-unit to the LED.
Thank you for your patience in slogging through my post, and for any guidance that can be kindly given to this befuddled old "noob"...!
