I parse a SMS (String) to substrings, so i can't avoid Strings.
The (sub)String is called StringFoo and is "1".
I want to write that 1 into a struct. The scruct contains chars[]
and booleans, like
typedef struct {
boolean booleanBar;
char charBar[20];
} userstruct;
userstruct owner;
StringFoo.toCharArray(owner.charBar, 20);
works perfect.
I search for an elegant way for the boolean, something like:
StringFoo.toBool(owner.booleanBar, 1);
Do i have to build a (if then) thing ? Do i just don't see the obvious? It' kind of ugly anyway...
Thx for hints!
intstarep:
That may be true, but possibly not
Please post a complete sketch rather than just an isolated snippet so that we can see what you are doing in context
J-M-L
January 26, 2022, 2:24pm
3
if you get 0 when you want false and 1 (or any other number) when true, then Try
owner.booleanBar = StringFoo.toInt();
C++ has a rule that implicitly converts 0 into false and any other integer into true.
owner.booleanBar = StringFoo != "0";
J-M-L
January 26, 2022, 2:29pm
5
this offers better type coherence so I like the idea, but it's costly.
Same idea but cheaper
owner.booleanBar = *(StringFoo.c_str()) != '0';
J-M-L
January 26, 2022, 2:33pm
7
yes that works too or charAt(0) . (but more costly because of the bound check )
J-M-L
January 26, 2022, 4:16pm
9
that's costly too in terms of compute time.
the fastest is probably
that means "take the first character from the string and compare it to '0')
system
Closed
July 25, 2022, 4:16pm
10
