The specifications for the Nano Every state that it has a 20MHz clock frequency, but the boards.txt file shows it as 16 MHz.
Running the Blink sketch with a 30 second ON / 30 second OFF delay operates properly with the 16MHz setting in the boards.txt file, and is appropriately longer when changing to 20MHz, so it appears the clock is running at 16MHz.
There is no obvious crystal on the PC board, and the schematic in not yet available, so hard to verify.
Relevant section from the boards.txt file:
nona4809.name=Arduino Nano Every
nona4809.vid.0=0x2341
nona4809.pid.0=0x0058
nona4809.upload.tool=avrdude
nona4809.upload.protocol=jtag2updi
nona4809.upload.maximum_size=49152
nona4809.upload.maximum_data_size=6144
nona4809.upload.speed=115200
nona4809.upload.use_1200bps_touch=true
nona4809.upload.extra_params=-P{serial.port}
nona4809.build.mcu=atmega4809
nona4809.build.f_cpu=16000000L //***************** f_cpu of 16,000,000 Hz *******************************
nona4809.build.board=AVR_NANO_EVERY
nona4809.build.core=arduino
nona4809.build.variant=nona4809
nona4809.build.text_section_start=.text=0x0
nona4809.build.extra_flags={build.328emulation} -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP
#nona4809.build.extra_flags=-B{runtime.tools.atpack.path}/gcc/dev/{build.mcu}
nona4809.bootloader.tool=avrdude
nona4809.bootloader.file=atmega4809_uart_bl.hex
nona4809.bootloader.SYSCFG0=0xC9
nona4809.bootloader.BOOTEND=0x00
nona4809.bootloader.OSCCFG=0x01
nona4809.fuses.file=fuses_4809.bin
menu.mode=Registers emulation
nona4809.menu.mode.on=ATMEGA328
nona4809.menu.mode.on.build.328emulation=-DAVR_NANO_4809_328MODE
nona4809.menu.mode.off=None (ATMEGA4809)
nona4809.menu.mode.off.build.328emulation=
