MrAl:
Hello there,
[Edit: Note the frequency may be 9.5MHz instead of 19MHz]
I have a Nano i have been using today for some tests on i/o pulse timing. I was looking for specific timing so i decided to do a few measurements.
What was surprising, to say the least, was that two different tests i had performed seem to show that the crystal or whatever is used on this board to generate the clock frequency for the CPU must be around 19MHz not 16MHz.
Is this even possible?
The first measurement was with a timing program that outputs a 250kHz square wave pulse. i have read other posts on this site that specify the timing when using the PORTB= instruction and PORTB|=B00100000 and the like, and have inserted several of these instructions that create a high and low signal which when measured on digital pin 13 measures really close to 250kHz. In fact, on two different meters it reads 250.0kHz.
On the CRT scope (old guy) it measures close to 250kHz but the time axis is not that accurate so i trust the meter readings more in this case, although the scope should not be off by more than about 10 percent, plus or minus.
The second measurement was using a short wave radio which quiets very noticeably when the radio is tuned to exactly 19.005MHz and stays a little quiet at 19.010MHz, but does not quiet anywhere near 16MHz as my Nano does. My Nano was quiet at 15.800MHz or something like that, which is understandable, but 19MHz seems way too far off.
Could it be that the manufacturer (probably Chinese) put in the wrong crystal or resonator?
Also, would the serial communications still work even if the crystal was the wrong frequency?
Thanks.
An Arduino board from the "factory" (whether it be genuine Arduino or cheapo-clone) will have a 16 mhz. resonator for the clock. A few are sold with a 20 mhz resonator or crystal, but the majority are 16.
Trying to measure the crystal frequency with an oscilloscope may or may not work, depending on the probe's input impedance and capacitance. My particular scope shows a nice, clear sine wave with a slight "hump" in the positive going part, but the scope says "16.000" for the frequency (or 22.1184 for my "custom" boards).
I can't imagine that anyone put a 19-something oscillator on your Arduino. As far as using a shortwave radio to try to hear the oscillator as a radio signal, that will certainly work... and usually you will hear a really strong "carrier" at 16.0 and some spurs at predictable places above and below.
Where "19" comes from is beyond me.
Another way to test it is to setup a timer in "CTC mode, Toggle Pin" and set the divider for a known frequency and then use the silly-scope to see if it's right. Since it seems like you already did that and came out with 250 khz (which is I suspect what you expected to see), I would trust that reading more than the scope which may have been triggering poorly and getting a wrong reading.
As far as frequencies you can use... anything you want from the khz range up to the chip's rated speed. Atmel makes 20 mhz parts, and these (heck even the 16 mhz parts) run fine at 22.1184, 27.125, etc... (I've run them up to 30+ mhz and they worked fine). They work much better if you set the oscillator fuse bits to "full swing" crystal as opposed to the standard "low power" crystal.
Have fun.
