Hi everyone,
I am trying to make a clock with RTC(DS1302) and setting via Wi-Fi / buttons(if wifi is not available). I would like to use arduino as main chip and esp8266 to set rtc over ntp server. (esp8266 would only turn on when setting the clock); I don't know how to send the time from esp8266 to arduino so that it is stored in three variables [hours, minutes, seconds]. I thought to use Serial or I2C. by the way, the code for operating the RTC and setting it using buttons is complete.
Take a look at Serial input basics - updated for ideas on how to deal with serial data and parse once it has been received
Thank you very much, it helped me.
I solved it lt like this (probably not the most elegantly
#include <SoftwareSerial.h>
SoftwareSerial serial(12, 13);
const byte numChars = 32;
char receivedChars[numChars]; // an array to store the received data
boolean newData = false;
int h;
int m;
int s;
int x;
serial.begin(9600);
Serial.println("Receiver is ready");
recvWithEndMarker();
showNewData();
void recvWithEndMarker() {
static byte ndx = 0;
char rc;
while (serial.available() > 0 && newData == false) {
rc = serial.read();
if (rc != '\r' && rc != '\n') {
receivedChars[ndx] = rc;
ndx++;
/*if (ndx >= numChars) {
ndx = numChars - 1;
else if (rc == '\r') {
x++;
if (x == 1) {
h = atoi(receivedChars);
else {
m = atoi(receivedChars);
receivedChars[ndx] = '\0';
ndx = 0;
else if (rc == '\n') {
s = atoi(receivedChars);
ndx = 0;
newData = true;
x = 0;
void showNewData() {
if (newData == true) {
Serial.print("This just in ... ");
//Serial.println(receivedChars);
Serial.print(h);
Serial.print(':');
Serial.print(m);
Serial.print(':');
Serial.println(s);
newData = false;
