Code modification for esp8266 with rtc ds1307
i have a code of esp8266 with ntp time clock. but now i want to remove wifi time and use ds1307 rtc for timekeeping but using its original clock fonts and animation. anyone can help me?
#include "Arduino.h"
#include <ESP8266WiFi.h>
WiFiClient client;
String date;
#define NUM_MAX 4
#define LINE_WIDTH 16
#define ROTATE  90
// for NodeMCU 1.0
#define DIN_PIN 15  // D8
#define CS_PIN  13  // D7
#define CLK_PIN 12  // D6
#include "max7219.h"
#include "fonts.h"
// CHANGE YOUR CONFIG HERE:
const char* ssid     = "D-Link_DIR-615";     // SSID of local network
const char* password = "TusharWifi";   // Password on network
float utcOffset = 5.5; // Time Zone setting
  initMAX7219();
  sendCmdAll(CMD_SHUTDOWN, 1);
  // sendCmdAll(CMD_INTENSITY,10); // Adjust the brightness between 0 and 15
  Serial.print("Connecting WiFi ");
  WiFi.begin(ssid, password);
  printStringWithShift("Connecting ", 16);
    Serial.print(".");
  Serial.println("");
  Serial.print("Connected: "); Serial.println(WiFi.localIP());
#define MAX_DIGITS 16
byte dig[MAX_DIGITS] = {0};
byte digold[MAX_DIGITS] = {0};
byte digtrans[MAX_DIGITS] = {0};
int updCnt = 0;
int dots = 0;
long dotTime = 0;
long clkTime = 0;
int dx = 0;
int dy = 0;
byte del = 0;
int h, m, s;
long localEpoc = 0;
long localMillisAtUpdate = 0;
  if (updCnt <= 0) { // every 10 scrolls, ~450s=7.5m
    updCnt = 10;
    Serial.println("Getting data ...");
    printStringWithShift("  Getting data", 15);
    getTime();
    Serial.println("Data loaded");
    clkTime = millis();
  if (millis() - clkTime > 20000 && !del && dots) { // clock for 15s, then scrolls for about 30s
    printStringWithShift(date.c_str(), 40);
    delay(7000);
    updCnt--;
    clkTime = millis();
  if (millis() - dotTime > 500) {
    dotTime = millis();
    dots = !dots;
  updateTime();
  showAnimClock();
  // Adjusting LED intensity.
  // 12am to 6am, lowest intensity 0
  if ( (h == 0) || ((h >= 1) && (h <= 6)) ) sendCmdAll(CMD_INTENSITY, 0);
  // 6pm to 11pm, intensity = 2
  else if ( (h >= 18) && (h <= 23) ) sendCmdAll(CMD_INTENSITY, 2);
  // max brightness during bright daylight
  else sendCmdAll(CMD_INTENSITY, 10);
void showSimpleClock()
  dx = dy = 0;
  clr();
  showDigit(h / 10,  4, dig6x8);
  showDigit(h % 10, 12, dig6x8);
  showDigit(m / 10, 21, dig6x8);
  showDigit(m % 10, 29, dig6x8);
  showDigit(s / 10, 38, dig6x8);
  showDigit(s % 10, 46, dig6x8);
  setCol(19, dots ? B00100100 : 0);
  setCol(36, dots ? B00100100 : 0);
  refreshAll();
void showAnimClock()
  byte digPos[4] = {1, 8, 17, 25};
  int digHt = 12;
  int num = 4;
  int i;
  if (del == 0) {
    del = digHt;
    for (i = 0; i < num; i++) digold[i] = dig[i];
    dig[0] = h / 10 ? h / 10 : 10;
    dig[1] = h % 10;
    dig[2] = m / 10;
    dig[3] = m % 10;
    for (i = 0; i < num; i++)  digtrans[i] = (dig[i] == digold[i]) ? 0 : digHt;
  } else
    del--;
  clr();
  for (i = 0; i < num; i++) {
    if (digtrans[i] == 0) {
      dy = 0;
      showDigit(dig[i], digPos[i], dig6x8);
      dy = digHt - digtrans[i];
      showDigit(digold[i], digPos[i], dig6x8);
      dy = -digtrans[i];
      digtrans[i]--;
  dy = 0;
  setCol(15, dots ? B00100100 : 0);
  refreshAll();
  delay(30);
void showDigit(char ch, int col, const uint8_t *data)
  if (dy < -8 | dy > 8) return;
  int len = pgm_read_byte(data);
  int w = pgm_read_byte(data + 1 + ch * len);
  col += dx;
  for (int i = 0; i < w; i++)
    if (col + i >= 0 && col + i < 8 * NUM_MAX) {
      byte v = pgm_read_byte(data + 1 + ch * len + 1 + i);
      if (!dy) scr[col + i] = v; else scr[col + i] |= dy > 0 ? v >> dy : v << -dy;
void setCol(int col, byte v)
  col += dx;
  if (col >= 0 && col < 8 * NUM_MAX)
      if (!dy) scr[col] = v; else scr[col] |= dy > 0 ? v >> dy : v << -dy;
int showChar(char ch, const uint8_t *data)
  int i, w = pgm_read_byte(data + 1 + ch * len);
  for (i = 0; i < w; i++)
    scr[NUM_MAX * 8 + i] = pgm_read_byte(data + 1 + ch * len + 1 + i);
  scr[NUM_MAX * 8 + i] = 0;
  return w;
void printCharWithShift(unsigned char c, int shiftDelay) {
  if (c < ' ' || c > '~' + 25) return;
  c -= 32;
  int w = showChar(c, font);
  for (int i = 0; i < w + 1; i++) {
    delay(shiftDelay);
    scrollLeft();
    refreshAll();
void printStringWithShift(const char* s, int shiftDelay) {
  while (*s) {
    printCharWithShift(*s, shiftDelay);
    s++;
void getTime()
  WiFiClient client;
  if (!client.connect("www.google.com", 80)) {
    Serial.println("connection to google failed");
    return;
  client.print(String("GET / HTTP/1.1\r\n") +
               String("Host: www.google.com\r\n") +
               String("Connection: close\r\n\r\n"));
  int repeatCounter = 0;
  while (!client.available() && repeatCounter < 10) {
    //Serial.println(".");
    repeatCounter++;
  String line;
  client.setNoDelay(false);
  while (client.connected() && client.available()) {
    line = client.readStringUntil('\n');
    line.toUpperCase();
    if (line.startsWith("DATE: ")) {
      date = "     " + line.substring(6, 17);
      h = line.substring(23, 25).toInt();
      m = line.substring(26, 28).toInt();
      s = line.substring(29, 31).toInt();
      localMillisAtUpdate = millis();
      localEpoc = (h * 60 * 60 + m * 60 + s);
  client.stop();
void updateTime()
  long curEpoch = localEpoc + ((millis() - localMillisAtUpdate) / 1000);
  long epoch = fmod(round(curEpoch + 3600 * utcOffset + 86400L), 86400L);
  h = ((epoch  % 86400L) / 3600) % 24;
  m = (epoch % 3600) / 60;
  s = epoch % 60;
fonts.h (11.5 KB)
max7219.h (3.0 KB)
Did you have a look at examples for the DS1307? Integration with your code should not be too difficult. With what are you stuck?
many error come when compile for nodemcu esp8266
my modified code for ds1307
#include <Wire.h>
#include <RTClib.h>
#include "fonts.h"
RTC_DS1307 rtc;
#define NUM_MAX 4
#define ROTATE 90
// for NodeMCU 1.0
const int utcOffset = 5; // Time Zone setting in hours
  initMAX7219();
  Serial.println("Initializing RTC...");
  Wire.begin();  // Initialize the I2C communication
  rtc.begin();   // Initialize the RTC
  // Check if the RTC is running. If not, set the time manually.
  if (!rtc.isrunning()) {
    Serial.println("RTC is NOT running!");
    // Set the time here using rtc.adjust() if needed
    // rtc.adjust(DateTime(__DATE__, __TIME__));
  Serial.println("Initialization complete.");
int updCnt = 0;
int dots = 0;
long dotTime = 0;
long clkTime = 0;
int dx = 0;
int dy = 0;
byte del = 0;
int h, m, s;
long localEpoc = 0;
    updCnt = 10;
    DateTime now = rtc.now();
    h = now.hour();
    m = now.minute();
    s = now.second();
    clkTime = millis();
    printStringWithShift(getFormattedTime().c_str(), 40);
    delay(7000);
    updCnt--;
    clkTime = millis();
    dotTime = millis();
    dots = !dots;
  updateTime();
  showAnimClock();
  if ((h >= 0) && (h <= 6)) sendCmdAll(CMD_INTENSITY, 0);
  else if ((h >= 18) && (h <= 23)) sendCmdAll(CMD_INTENSITY, 2);
void showAnimClock() {
  int digHt = 12;
  int num = 4;
  int i;
  if (del == 0) {
    del = digHt;
    dig[1] = h % 10;
    dig[2] = m / 10;
    dig[3] = m % 10;
  } else
    del--;
  clr();
      dy = 0;
      dy = -digtrans[i];
      digtrans[i]--;
  dy = 0;
  refreshAll();
  delay(30);
void showDigit(char ch, int col, const uint8_t *data) {
  col += dx;
void setCol(int col, byte v) {
  col += dx;
int showChar(char ch, const uint8_t *data) {
  return w;
  c -= 32;
    delay(shiftDelay);
    scrollLeft();
    refreshAll();
  while (*s) {
    s++;
String getFormattedTime() {
  String formattedTime = String(h) + ":" + (m < 10 ? "0" : "") + String(m) + ":" + (s < 10 ? "0" : "") + String(s);
  return formattedTime;
void updateTime() {
  h = now.hour();
  m = now.minute();
  s = now.second();
My suggestion is to simply update your existing NTP every few hours. That will keep your time accurate, and working when the internet fails.
But if you really want to use a RTC get a DS3231 - it is much more accurate over time.
#include <Wire.h>
#include <RTClib.h>
#include "fonts.h"
RTC_DS1307 rtc;
#define NUM_MAX 4
#define ROTATE 90
// for NodeMCU 1.0
Going by the rather odd code you have with millis() in the updateTime() function of the original code (found similar code on github for a clock sketch), I'm guessing you are getting a lot of errors from the max7219.h code, because you included it before the #define statements.
