Along with this, I also use the processing sketch which gives me the time.
// DateTime.pde
// example sketch for the DateTime library
#include <DateTime.h>
#include <DateTimeStrings.h>
#define TIME_MSG_LEN 11 // time sync to PC is HEADER followed by unix time_t as ten ascii digits
#define TIME_HEADER 'T' // Header tag for serial time sync message
void setup(){
Serial.begin(19200);
pinMode(13,OUTPUT); // we flash the LED each second
void loop(){
unsigned long prevtime;
if( getPCtime()) { // try to get time sync from pc
Serial.print("Clock synced at: ");
Serial.println(DateTime.now(),DEC);
if(DateTime.available()) { // update clocks if time has been synced
digitalWrite(13,LOW); // first flash the LED
prevtime = DateTime.now();
while( prevtime == DateTime.now() ) // wait for the second to rollover
DateTime.available(); //refresh the Date and time properties
digitalClockDisplay( ); // update digital clock
// send our time to any app at the other end of the serial port
Serial.print( TIME_HEADER,BYTE); // this is the header for the current time
Serial.println(DateTime.now());
digitalWrite(13,HIGH);
delay(100);
boolean getPCtime() {
// if time sync available from serial port, update time and return true
while(Serial.available() >= TIME_MSG_LEN ){ // time message consists of a header and ten ascii digits
if( Serial.read() == TIME_HEADER ) {
time_t pctime = 0;
for(int i=0; i < TIME_MSG_LEN -1; i++){
char c= Serial.read();
if( c >= '0' && c <= '9'){
pctime = (10 * pctime) + (c - '0') ; // convert digits to a number
DateTime.sync(pctime); // Sync Arduino clock to the time received on the serial port
return true; // return true if time message received on the serial port
return false; //if no message return false
void digitalClockDisplay(){
// digital clock display of current date and time
Serial.print(DateTime.Hour,DEC);
printDigits(DateTime.Minute);
printDigits(DateTime.Second);
Serial.print(" ");
Serial.print(DateTimeStrings.dayStr(DateTime.DayofWeek));
Serial.print(" ");
Serial.print(DateTimeStrings.monthStr(DateTime.Month));
Serial.print(" ");
Serial.println(DateTime.Day,DEC);
void printDigits(byte digits){
// utility function for digital clock display: prints preceding colon and leading 0
Serial.print(":");
if(digits < 10)
Serial.print('0');
Serial.print(digits,DEC);
And here is the segment code
#define ANODE_F 9 // anode F as pin 9
#define ANODE_G 8 // anode G as pin 8
#define ANODE_E 7 // anode E as pin 7
#define ANODE_D 6 // anode D as pin 6
#define ANODE_C 2 // anode C as pin 2
#define ANODE_RHDP 3 // anonde RHDP as pin 3
#define ANODE_B 4 // anode B as pin 4
#define ANODE_A 5 // anode A as pin 5
#define Screen_1 13 // 1st digit as pin 13
#define Screen_2 12 // 2nd digit as pin 12
#define Screen_3 11 // 3rd digit as pin 11
#define Screen_4 10 // 4th digit as pin 10
void setup(){
Serial.begin (9600);
pinMode(ANODE_F, OUTPUT);
pinMode(ANODE_G, OUTPUT);
pinMode(ANODE_E, OUTPUT);
pinMode(ANODE_D, OUTPUT);
pinMode(ANODE_C, OUTPUT);
pinMode(ANODE_RHDP, OUTPUT);
pinMode(ANODE_B, OUTPUT);
pinMode(ANODE_A, OUTPUT);
pinMode(Screen_1, OUTPUT);
pinMode(Screen_2, OUTPUT);
pinMode(Screen_3, OUTPUT);
pinMode(Screen_4, OUTPUT);
void loop(){
screenon();
one();
delay(4);
two();
delay(4);
three();
delay(4);
four();
delay(4);
void zero(){
clearall();
digitalWrite(ANODE_F, HIGH);
digitalWrite(ANODE_A, HIGH);
digitalWrite(ANODE_B, HIGH);
digitalWrite(ANODE_C, HIGH);
digitalWrite(ANODE_D, HIGH);
digitalWrite(ANODE_E, HIGH);
void one(){
clearall();
void two() {
clearall();
digitalWrite(ANODE_G, HIGH);
void three() {
clearall();
void four(){
clearall();
void five(){
clearall();
void six(){
clearall();
void seven(){
clearall();
void eight(){
clearall();
void nine(){
clearall();
void clearall() {
digitalWrite(ANODE_F, LOW);
digitalWrite(ANODE_A, LOW);
digitalWrite(ANODE_G, LOW);
digitalWrite(ANODE_D, LOW);
digitalWrite(ANODE_C, LOW);
digitalWrite(ANODE_E, LOW);
digitalWrite(ANODE_B, LOW);
