[CLOSED] An ESC start delay and slow response
Hi!! I've finished my old Drone project. The code is on my github: GitHub - PIKUT0/Drone-on-Arduino-Nano: My old project (firmware/RXV.ino for the drone). There's no problem in code, it works fine. Motors work fine too.
There's problem with 1 esc.
Long time ago I've bought 4 similar esc's and 4 similar Brushless motors from one shop on AliExpress sale, e.g. (1 propeller + 1 motor + 1 ESC)x4. They used to work perfectly!
Then I put the drone on shelf for a long time . Now only 1 esc (on photo marked as "x") acts weirdly. As seen on video (https://youtu.be/2V0I7MOlc14) it has a strange delay at start [marked as 4 and pointed blue arrow on the motor] and quick stop (https://youtu.be/36q1Z64jGXU). I've tried switching pins, motors, etc., checked arduino wiring, nothing. Everything works properly except that ESC. Then checked only its on-board capacitors and resistors = they're fine. I have no idea what happened to it. So I'm here looking for help.:joy:
Any ideas what happened ?
ESC, motors and propellers: https://aliexpress.ru/item/4000330189092.html?srcSns=sns_WhatsApp&businessType=ProductDetail&spreadType=socialShare&tt=MG&utm_medium=sharing&sku_id=10000001352503687
(1045 XXD30A 1000KV, that yellow one)
Photos of properly working ESC (on photo marked as "P") and and that one ("x").
P.S. I cant send videos here, so uploaded them on my YT channel and you can watch them only via link. (Screenshots as proof). Sorry for bad quality video, edited them via telegram which eats quality :slight_smile:
pic-selected-240809-1340-13
P.P. S. Ahh, sorry if my message contains grammatical mistakes, English is my second language and my still practicing :smiley:
Here's RX code that I copied from my github (it has 2 languages - Russian and English):
//------------------- CREDITS ------------------//
// Author: Pikuto
// GitHub: https://github.com/PIKUT0
// Project GitHUb: https://github.com/PIKUT0/Drone-on-Arduino-Nano
// 12.06.20 Started
// 08.08.24 Finished
// Yeah, I was lazy.
// This code is for Drone = Receiver
//-------------------- CODE -------------------//
//------------ LIBRARIES ------------//
#include <SPI.h>
#include "nRF24L01.h"
#include "RF24.h"
#include <Servo.h>
#include "I2Cdev.h"
#include "MPU6050_6Axis_MotionApps20.h"
#if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE
    #include "Wire.h"
#endif
//------------ "DEFINES" ------------//
MPU6050 mpu;
//#define OUTPUT_READABLE_WORLDACCEL
// uncomment "OUTPUT_READABLE_YAWPITCHROLL" and "PID_YPR" if you want to see the yaw/
// pitch/roll angles (in degrees) calculated from the quaternions coming
// from the FIFO and if you want to controll your drone via YPR PID.
// Note this also requires gravity vector calculations.
// Also note that yaw/pitch/roll angles suffer from gimbal lock (for
// more info, see: http://en.wikipedia.org/wiki/Gimbal_lock)
#define OUTPUT_READABLE_YAWPITCHROLL
#define PID_YPR
// uncomment "OUTPUT_READABLE_EULER" and "PID_EULER" if you want to see Euler angles
// (in degrees) calculated from the quaternions coming from the FIFO
// and if you want to controll your drone via Euler PID.
// Note that Euler angles suffer from gimbal lock (for more info, see
// http://en.wikipedia.org/wiki/Gimbal_lock)
//#define OUTPUT_READABLE_EULER
//#define PID_EULER
#define MAX_SPEED 2000  // Motor Max speed = Dangerous
#define IDLE_SPEED 1100 // Motor Idling speed = min_speed
#define NO_SPEED 1000   // No Rotation = No speed
Servo Motor1, Motor2, Motor3, Motor4;
RF24 radio(8, 10);      // Make sure you connected radio module correctly. Can change this numbers.
                        // {RU} ["создать" модуль на пинах 9 и 10 Для Уно]
//------------ VARIABLES ------------//
//-------- For MPU6050 --------//
bool dmpReady = false;  // set true if DMP init was successful
uint8_t mpuIntStatus;   // holds actual interrupt status byte from MPU
uint8_t devStatus;      // return status after each device operation (0 = success, !0 = error)
uint16_t packetSize;    // expected DMP packet size (default is 42 bytes)
uint16_t fifoCount;     // count of all bytes currently in FIFO
uint8_t fifoBuffer[64]; // FIFO Buffer, Here we store all data
Quaternion q;           // [w, x, y, z]         quaternion container
VectorInt16 aa;         // [x, y, z]            accel sensor measurements
VectorInt16 aaReal;     // [x, y, z]            gravity-free accel sensor measurements
VectorInt16 aaWorld;    // [x, y, z]            world-frame accel sensor measurements
VectorFloat gravity;    // [x, y, z]            gravity vector
float euler[3];         // [psi, theta, phi]    Euler angle container
float ypr[3];           // [yaw, pitch, roll]   yaw/pitch/roll container and gravity vector
int yaw, pitch, roll;   // our yaw pitch and roll and other shit from GY521
//int e_psi;            // Euler Psi angle in degrees   ["e" stands for Euler]
//int e_theta;          // Euler Theta angle in degrees ["e" stands for Euler]
//int e_phi;            // Euler Phi angle in degrees   ["e" stands for Euler]
//--------- For PID ---------//
float PIDReturn[]={0, 0, 0}; //PID output
//Angle
int des_AngleRoll;      // Desired Roll angle
int des_AnglePitch;     // Desired pitch angle
int des_AngleYaw;       // Desired yaw angle
float er_AngleRoll = 0; // Error for roll angle in degrees
float er_AnglePitch= 0; // Error for pitch angle in degress
float er_AngleYaw = 0;  // Error for yaw angle in degrees
float p_a_AngleRoll=0;  // p_e{..} = Previous Angle [Roll]
float p_a_AnglePitch=0; // p_e{..} = Previous Angle [Pitch]
float p_a_AngleYaw=0;   // p_e{..} = Previous Angle [Yaw]
float S_I_AngleRoll = 0;// p_e{..} = Previous Integral sum of Error for roll angle
float S_I_AnglePitch =0;// p_e{..} = Previous Integral sum of Error for pitch angle
float S_I_AngleYaw = 0; // p_e{..} = Previous Integral sum of Error for Yaw angle
//--- For MOTORS and Radio ---//
unsigned long OldTimer; // Counter for some Logic
int x1,y1,x2,y2;        // Our radio joystick variables
int RollPID, PitchPID, YawPID;
int FL, FR, BL, BR = 0; // Motor Inputs
      // [FL - Front Left  Motor-4 (передний левый  (4 мотор))]
      // [FR - Front Right Motor-1 (передний правый (1 мотоР))]
      // [BL - Back Left   Motor-3 (задний левый    (3 мотор))]
      // [BR - Back Right  Motor-2 (задний правый   (2 мотор))]
byte SAFETY = 0;        // Safety goes first
byte address[][6] = {"1Node", "2Node", "3Node", "4Node", "5Node", "6Node"}; //Tube address
unsigned long gotByte;     // Radio data
//--------------- FUNCTIONS ---------------//
// This Function will return joystick angles [Rate, Yaw, pitch] [Psi, Theta, Phi]
// I'm Still not sure how to use it correctly, need to check in reality
void desiredAngle(){
  // -- Yaw -- //
  des_AngleYaw = map(x2, 0, 255, 1000,2000);
  des_AngleYaw = int(0.1*(des_AngleYaw - 1500));
  if(des_AngleYaw == -1) des_AngleYaw = 0;
  // -- Picth -- //
  des_AnglePitch = map(y1, 0, 255, 1000,2000);
  des_AnglePitch = int(0.1*(des_AnglePitch - 1500));
  if(des_AnglePitch == -1) des_AnglePitch = 0;
  // -- Roll -- //
  des_AngleRoll = map(x1, 0, 255, 1000,2000);
  des_AngleRoll = int(0.1*(des_AngleRoll - 1500));
  if(des_AngleRoll == -1.) des_AngleRoll = 0;
//This Function is PID function
void pid_equation(float Error, float KP, float KI, float KD, float PrevData, float ISum, byte k){
  int Data = 0;
  float uP, uI, uD, PID;
  uP = KP * Error;
  ISum = ISum + Error;
  if(Error == 0) ISum = 0;
  if(ISum < -200)ISum = -200;
  if(ISum > 200)ISum = 200;
  uI = KI * ISum;
  gyro_signals();
  if(k == 0) Data = roll;
  if(k == 1) Data = pitch;
  if(k == 2) Data = yaw;
  uD = KD * (Data - PrevData);
  PID = uP + uI + uD;
  if (PID>200) PID=200;
  else if (PID <-200) PID=-200;
  PIDReturn[0] = PID;
  PIDReturn[1] = Data;
  PIDReturn[2] = ISum;
//This Function will calculate Roll, Yawm and Pitch PID
void pid_calculate(){
  // --- ROLL --- //
  er_AngleRoll = des_AngleRoll - roll;
  p_a_AngleRoll = roll;
  pid_equation(er_AngleRoll, 0.35, 0.3, 0.04, p_a_AngleRoll, S_I_AngleRoll, 0);
  p_a_AngleRoll = PIDReturn[1];
  S_I_AngleRoll = PIDReturn[2];
  RollPID = int(PIDReturn[0]);
  // --- YAW --- //
  //No Need
  // --- PITCH --- //
  er_AnglePitch = des_AnglePitch - pitch;
  p_a_AnglePitch = pitch;
  pid_equation(er_AnglePitch, 0.35, 0.3, 0.04, p_a_AnglePitch,S_I_AnglePitch, 1);
  p_a_AnglePitch = PIDReturn[1];
  S_I_AnglePitch = PIDReturn[2];
  PitchPID = int(PIDReturn[0]);
//This Function will calculate Roll, Yawm and Pitch PID to "Return Home"
void pid_Home(){
  // --- ROLL --- //
  er_AngleRoll = 0 - roll;
  // --- YAW --- //
  er_AngleYaw = 0 - yaw;
  p_a_AngleYaw = yaw;
  pid_equation(er_AngleYaw, 0.35, 0.3, 0.02 ,p_a_AngleYaw,S_I_AngleYaw, 2);
  p_a_AngleYaw = PIDReturn[1];
  S_I_AngleYaw = PIDReturn[2];
  YawPID = int(PIDReturn[0]);
  // --- PITCH --- //
  er_AnglePitch = 0 - pitch;
//This Function is PID error reset function
void reset_pid(){
  p_a_AngleRoll = 0; p_a_AnglePitch = 0;  p_a_AngleYaw = 0;
  S_I_AngleRoll = 0; S_I_AnglePitch = 0;  S_I_AngleYaw = 0;
  des_AngleRoll = 0; des_AnglePitch = 0;  des_AngleYaw = 0;
//This Function will return the angle(yaw, pitch, roll)[Wire], Euler angles(DMP) = pure shit
void gyro_signals(void) {
  if (!dmpReady) return;
    // read a packet from FIFO
    if (mpu.dmpGetCurrentFIFOPacket(fifoBuffer)) { // Get the Latest packet
        #ifdef OUTPUT_READABLE_EULER
          #ifdef PID_EULER
            // display Euler angles in degrees
             mpu.dmpGetQuaternion(&q, fifoBuffer);
             mpu.dmpGetEuler(euler, &q);
             e_psi = int(euler[0] * 180/M_PI);
             e_theta = int(euler[1] * 180/M_PI);
             e_phi = (-1)* int(euler[2] * 180/M_PI);
          #endif
        #endif
        #ifdef OUTPUT_READABLE_YAWPITCHROLL
          #ifdef PID_YPR
             mpu.dmpGetGravity(&gravity, &q);
             mpu.dmpGetYawPitchRoll(ypr, &q, &gravity);
             yaw = int(ypr[0] * 180/M_PI);
             pitch =(-1)*int(ypr[1] * 180/M_PI);
             roll = int(ypr[2] * 180/M_PI);
          #endif
        #endif
//This Function will rise drone smootly
void smooth_rise(){
  SAFETY = 0;
  FL = 1000;
  OldTimer = millis();
  while(SAFETY == 0){
    Motor1.writeMicroseconds(FL);
    Motor2.writeMicroseconds(FL);
    Motor3.writeMicroseconds(FL);
    Motor4.writeMicroseconds(FL);
    if(millis() - OldTimer >= 500){
      FL = FL + 25;
    if(FL>1500){
      FL = 1500;
      SAFETY = 1;
  FL = 0;
//------------ SETUP TIME ------------//
  //------------ MOTOR INITIALIZATION ------------//
  Motor1.attach(5, 0, 2000); // Front Right
  Motor2.attach(6, 0, 2000); // Back Right
  Motor3.attach(9, 0, 2000); // Back Left
  Motor4.attach(3, 0, 2000); // Front Right
  //------------ MPU6050 INITIALIZATION ------------//
  mpu.initialize();
  mpu.testConnection() ? digitalWrite(LED_BUILTIN,1) : digitalWrite(LED_BUILTIN,0);
  devStatus = mpu.dmpInitialize();
  // supply your own gyro offsets here, scaled for min sensitivity
  mpu.setXGyroOffset(328);
  mpu.setYGyroOffset(24);
  mpu.setZGyroOffset(-558);
  mpu.setXAccelOffset(-1669);
  mpu.setYAccelOffset(-1430);
  mpu.setZAccelOffset(1553);
  if (devStatus == 0) {
    // Calibration Time: generate offsets and calibrate our MPU6050
    mpu.CalibrateAccel(6);
    mpu.CalibrateGyro(6);
    mpu.PrintActiveOffsets();
    // turn on the DMP, now that it's ready
    mpu.setDMPEnabled(true);
    // enable Arduino interrupt detection
    mpuIntStatus = mpu.getIntStatus();
    // set our DMP Ready flag so the main loop() function knows it's okay to use it
    dmpReady = true;
    // get expected DMP packet size for later comparison
    packetSize = mpu.dmpGetFIFOPacketSize();
  else {
    Motor1.write(1000);//FR
    Motor2.write(1000);//BR
    Motor3.write(1000);//BL
    Motor4.write(1000);//FL
    // ERROR!
    // 1 = initial memory load failed
    // 2 = DMP configuration updates failed
    // (if it's going to break, usually the code will be 1)
    B:for(byte L = 0; L<devStatus; L++){
      digitalWrite(LED_BUILTIN,HIGH);
      digitalWrite(LED_BUILTIN,LOW);
   delay(5000);
   goto B;
  //------------ RADIO INITIALIZATION ------------//
  radio.begin();              // Activate module [активировать модуль]
  radio.setAutoAck(1);        // [режим подтверждения приёма, 1 вкл 0 выкл]
  radio.setRetries(0, 15);    // (Time between attempts, attempts amount)[(время между попыткой достучаться, число попыток]
  radio.enableAckPayload();   // разрешить отсылку данных в ответ на входящий сигнал
  radio.setPayloadSize(4);    // размер пакета, в байтах
  radio.openReadingPipe(1, address[0]);   // хотим слушать трубу 0
  radio.setChannel(0x60);     // выбираем канал (в котором нет шумов!)
  radio.setPALevel (RF24_PA_MAX);   // уровень мощности передатчика. На выбор RF24_PA_MIN, RF24_PA_LOW, RF24_PA_HIGH, RF24_PA_MAX
  radio.setDataRate (RF24_250KBPS); // скорость обмена. На выбор RF24_2MBPS, RF24_1MBPS, RF24_250KBPS
  //должна быть одинакова на приёмнике и передатчике!
  //при самой низкой скорости имеем самую высокую чувствительность и дальность!!
  radio.powerUp();        // начать работу
  radio.startListening(); // начинаем слушать эфир, мы приёмный модуль
  //------------ MOTORS MUSN'T WORK ------------//
//------------ SETUP ENDS ------------//
//------------ LOOP TIME ------------//
  byte pipeNo;
  unsigned int n = 1400;
  //------------ IF WE WANT TO EASILY LOWER OUR HEIGHT------------//
  while(SAFETY == 2){
    if(FR == 0) n = 1000;
    FR = n;
    Motor1.writeMicroseconds(FR);
    Motor2.writeMicroseconds(FR);
    Motor3.writeMicroseconds(FR);
    Motor4.writeMicroseconds(FR);
      n = n - 25;
    if(n < 1000){
      while(true){
        Motor1.writeMicroseconds(1000);
        Motor2.writeMicroseconds(1000);
        Motor3.writeMicroseconds(1000);
        Motor4.writeMicroseconds(1000);
  //------------ WHILE RADIO WORKS ------------//
  A:while (radio.available(&pipeNo)) {        // слушаем эфир со всех труб
    //------------ GET THE DATA ------------//
    // Here we are getting data from transmitter and playing with it
    radio.read(&gotByte, sizeof(gotByte));  // чиатем входящий сигнал
    y2 = gotByte & 255;
    gotByte = gotByte >> 8;
    x2 = gotByte & 255;
    y1 = gotByte & 255;
    x1 = gotByte & 255;
    desiredAngle();
    x2 = map(x2, 0, 255, -300, 300);
    y2 = map(y2, 0, 255, -300, 300);
    x1 = map(x1, 0, 255, -300, 300);
    y1 = map(y1, 0, 255, -300, 300);
    if(x2 == -6) x2 = 0;
    if(y2 == -6) y2 = 0;
    if(x1 == -6) x1 = 0;
    if(y1 == -6) y1 = 0;
    //------------ SAFETY GOES FIRST ------------//
    D:while(SAFETY == 0){
      FR = NO_SPEED;
      FL = NO_SPEED;
      BR = NO_SPEED;
      BL = NO_SPEED;
      Motor2.writeMicroseconds(BR);
      Motor3.writeMicroseconds(BL);
      if(y2 && y1 < 0){
        SAFETY = 1;
        smooth_rise();
      goto A;
    while(SAFETY == 2){
    //------------ GET THE MPU6050 DATA ------------//
    gyro_signals();
    //------------ USE PID CONTROLLER ------------//
    pid_calculate();
    //------------ FORMULA FOR DRONE ------------//
    FR = y2 + x2 - y1 - x1 - PitchPID - RollPID;
    FL = y2 - x2 - y1 + x1 - PitchPID + RollPID;
    BR = y2 - x2 + y1 - x1 + PitchPID - RollPID;
    BL = y2 + x2 + y1 + x1 + PitchPID + RollPID;
    FR = map(FR, -1200, 1200, 1000, 2000);
    FL = map(FL, -1200, 1200, 1000, 2000);
    BR = map(BR, -1200, 1200, 1000, 2000);
    BL = map(BL, -1200, 1200, 1000, 2000);
    //------------ SOME CONSTRAINS ------------//
    if (FR > 2000)FR = 2000;
    if (BR > 2000)BR = 2000;
    if (BL > 2000)BL = 2000;
    if (FL > 2000)FL = 2000;
    if (FR < IDLE_SPEED) FR =  IDLE_SPEED;
    if (BR < IDLE_SPEED) BR =  IDLE_SPEED;
    if (BL < IDLE_SPEED) BL =  IDLE_SPEED;
    if (FL < IDLE_SPEED) FL =  IDLE_SPEED;
    if (y2<-295 && x2<-295){
      SAFETY = 2;
    if (y2<-295) {
      FR=NO_SPEED;
      BR=NO_SPEED;
      BL=NO_SPEED;
      FL=NO_SPEED;
      reset_pid();
    //------------ APPLY VALUES TO MOTORS ------------//
  //------------ WHILE RADIO DOESN'T WORK ------------//
  // Here drone is on it's own with MPU6050.
  // Its job is to lower height every n seconds
  // while being stable in the air
  while (!radio.available(&pipeNo)){// слушаем эфир со всех труб
    while(SAFETY == 0)goto D;   //Check If safety flag is 0 = there was no activity "no rise"
    while(SAFETY == 1 && y2 <-295){ //Check If safety flag is 1 and y2 <-295 = no "firewall", but no speed;
      FR = 0;
      goto E;
    gyro_signals();
    reset_pid();
    pid_Home();
    FR = 0 + YawPID - PitchPID - RollPID;
    FL = 0 - YawPID - PitchPID + RollPID;
    BR = 0 - YawPID + PitchPID - RollPID;
    BL = 0 + YawPID + PitchPID + RollPID;
    E:if(millis() - OldTimer >= 8000){
      SAFETY = 2;
Ok, if I add this lines:
(as written here: Esc brushless motor not work exactly - #19 by dronappsemi by Billy_314
  Motor1.writeMicroseconds(2000);
  Motor2.writeMicroseconds(2000);
  Motor3.writeMicroseconds(2000);
  Motor4.writeMicroseconds(2000);
  delay(2000);
Only motor 4 will be spinning
Weird
Of course you have no clue what ESC firmware is on that Atmega8, but many of those cloners use some flavor of the Hobbywing firmware. I suspect one of your ESC's has gone into soft-startup or even super-soft startup mode.
You need to find a ESC programming manual (example) that mentions the same programming beeps that you hear when entering programming mode of the esc.
Looking at the PCB layout I think it is a "Hobbypower 30A" (clone).
https://www.optimusdigital.ro/ro/index.php?controller=attachment&id_attachment=451
I found this datasheet, programmed into normal start-up - nothing changed.
Thanks :>
I'll edit post as solved with a solution, if it solves my problem
(programming this with another nano + button :slight_smile: )
If nothing else works, you could consider loading the SimonK firmware on your ESC's. After all you are asking in the Arduino forum, so that should be a piece of cake for you :slight_smile:
At least if you have the TQFP programming adapter or have fine soldering skills. No programming pads seem exposed on your ESC.
I have fine soldering skills since I made small car pcb then soldered every component including stm32f103c8t6. :slight_smile:
Programmed that one into normal start = no changes.
Then
Programmed each into "Restore default" , nothing changes. :frowning:
Should I load SimonK firmware into every ESC, or only that one?
Hold on, I dont have usbasp. Only have 3 usb sticks "USB -> TTL" RX, TX thing.
(Going to buy) :money_mouth_face:
Ok, I'll come up with a solution once I solve it. I would be gratefull if you help.
Anyway, Thanks hmeijdam!
The problematic ESC seems to have some soldering inconsistencies, especially right in the middle of the photo showing the side with all the FETs.
Wdym? Here?
I think its ok there
Just a little bit more solder there
ok.
Hi!
Thats me again, soldered atmega8 perfectly.
My programmer is Arduino nano as ISP.
(https://docs.arduino.cc/built-in-examples/arduino-isp/ArduinoISP/)
kkMulticopterFlashTool isn't working properly.
I can't even see repositories! Anyway I still can use .hex files.
Its time to load tgy.hex firmware:
Programmer Arduino
Port: com7
firmware: tgy.hex
Loading ....
stk500_recv() timeout. ..
If I use avrdudeprog, it returns the same error n times while reading/programming
then "connection timeout" and the cycle repeats.
Ok, I found out I can use Arduino as ISP only in Arduino IDE; downloaded minicore;
This is what I've got (same output on windows):
Arduino: 1.8.19 (Linux), Board: "ATmega8, No bootloader, EEPROM retained, 19200, BOD 2.7V, LTO enabled, External 16 MHz"
/home/pikuto/.arduino15/packages/MiniCore/tools/avrdude/7.2-arduino.1/bin/avrdude -C/home/pikuto/.arduino15/packages/MiniCore/hardware/avr/3.0.2/avrdude.conf -v -patmega8 -cstk500v1 -P/dev/ttyUSB0 -b19200 -e -Ulock:w:0xff:m -Uefuse:w:{bootloader.extended_fuses}:m -Uhfuse:w:0b11000111:m -Ulfuse:w:0b10111111:m
avrdude: Version 7.2-arduino.1
         Copyright the AVRDUDE authors;
         see https://github.com/avrdudes/avrdude/blob/main/AUTHORS
         System wide configuration file is /home/pikuto/.arduino15/packages/MiniCore/hardware/avr/3.0.2/avrdude.conf
         User configuration file is /home/pikuto/.avrduderc
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/ttyUSB0
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
         AVR Part                      : ATmega8
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : possible i/o
         RETRY pulse                   : SCK
         Serial program mode           : yes
         Parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                           Block Poll               Page                       Polled
           Memory Type Alias    Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom                  4    20   128    0 no        512    4      0  9000  9000 0xff 0xff
           flash                  33    10    64    0 yes      8192   64    128  4500  4500 0xff 0x00
           lfuse                   0     0     0    0 no          1    1      0  4500  4500 0x00 0x00
           hfuse                   0     0     0    0 no          1    1      0  4500  4500 0x00 0x00
           lock                    0     0     0    0 no          1    1      0  4500  4500 0x00 0x00
           signature               0     0     0    0 no          3    1      0     0     0 0x00 0x00
           calibration             0     0     0    0 no          4    1      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 version 1.x firmware
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
avrdude: device signature = 0x000000 (retrying)
avrdude main() error: Yikes!  Invalid device signature.
avrdude main() error: expected signature for ATmega8 is 1E 93 07
        Double check connections and try again, or use -F to override
        this check.
avrdude done.  Thank you.
Error while burning bootloader.
option enabled in File -> Preferences.
I'm sure that the connections are right.
There's no short-circuit between miso, mosi, sck, vcc, gnd and RST.
Connection to an a.nano:
on chip RST --> 10
on chip GND -> GND
on chip vcc ---> 5V
on chip miso -> 12
on chip mosi -> 11
on chip sck ---> 13
The ESC itself is still working on that buggy old firmware
Maybe I should program this with RX/TX?
Ok, reason was that miso and mosi pins were mixed up.
Arduino: 1.8.19 (Linux), Board: "ATmega8, No bootloader, EEPROM retained, 19200, BOD 2.7V, LTO enabled, Internal 8 MHz"
/home/pikuto/.arduino15/packages/MiniCore/tools/avrdude/7.2-arduino.1/bin/avrdude -C/home/pikuto/.arduino15/packages/MiniCore/hardware/avr/3.0.2/avrdude.conf -v -patmega8 -cstk500v1 -P/dev/ttyUSB0 -b19200 -e -Ulock:w:0xff:m -Uefuse:w:{bootloader.extended_fuses}:m -Uhfuse:w:0b11010111:m -Ulfuse:w:0b10100100:m
         AVR Part                      : ATmega8
         PAGEL                         : PD7
         BS2                           : PC2
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         Hardware Version: 2
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: device signature = 0x0000ff
        double check chip or use -F to override this check
Sketch uses 720 bytes (8%) of program storage space. Maximum is 8192 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 1015 bytes for local variables. Maximum is 1024 bytes.
/home/pikuto/.arduino15/packages/MiniCore/tools/avrdude/7.2-arduino.1/bin/avrdude -C/home/pikuto/.arduino15/packages/MiniCore/hardware/avr/3.0.2/avrdude.conf -v -patmega8 -cstk500v1 -P/dev/ttyUSB0 -b19200 -Ueeprom:w:/tmp/arduino_build_901270/Blink.ino.eep:i -Uflash:w:/tmp/arduino_build_901270/Blink.ino.hex:i
         AVR Part                      : ATmega8
         PAGEL                         : PD7
         BS2                           : PC2
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         Hardware Version: 2
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
An error occurred while uploading the sketch
avrdude: device signature = 0xff00ff
Invalid library found in /home/pikuto/Arduino/libraries/LiveOV7670-master: no headers files (.h) found in /home/pikuto/Arduino/libraries/LiveOV7670-master
different device signature
That still does not look like a successful programming attempt according to the error you get. You get something different than 0x00, but 0xff00ff indicates some pulses come out of the miso pin.
Can you check the value of the pullup resistor on the RST pin of the Atmega8? Should be 10K (103) or you Arduino will not be able to pull the RST pin low.
Yup, its 10K (103)
avrdude: device signature = 0x0097ff
manually pull RST to low
[quote="pikuto, post:17, topic:1290140"]
[/quote] You should leave that pulling RST low to pin 10 on your Arduino as the timing of the low pulse has its limits.
This esc is dead now. Accidently short-circuited.
That was funny.
Thx everyone for helping.
Sometimes, ESCs need to be recalibrated after being stored for a while. Try recalibrating the problematic ESC to ensure it is correctly synced with the throttle range of your transmitter.
Have you seen those videos?
Anyway , recalibration didn't help. There's weird 8 - 10 seconds delay at startup and other weird things.
Okay, today I received new esc. Tested without propellers, everything seems to be okay.
≈Seems to be ok. Thx everyone, closing this post
