For a start, you need brackets around the else statement.
OCR2B=OCR2B-2;
Amps = (510.5 - SensorValue)*75.75757576/1023;
Serial.print("\t Current = ");
Serial.println (Amps,3);
OCR2B=OCR2B-2;
The goal is to sense the current flowing through a buck converter using a current sensor, also to sense the voltage across it using a voltage sensor that I built. Keep in mind I'm dealing with high power. But everything has to be closed loop so that when I multiply the value of resistor by the reference current I have in the code: whatever voltage value I get as output should not change even if I change the power supply value. The only time voltage change is when I change resistor. I hope this is not COMPLICATED.
Did you fix the brackets as cattledog suggests? That's definitely an error. Try that first.
Yes sir I did, but it still doesn't give me what I want
I think my major issue here is I'm not sure I understand how to write a closed loop program
Delta_G:
Seems like we already have a topic on this one...Closed loop control on arduino UNO - Programming Questions - Arduino Forum
Which is itself already a merge of two from the weekend I think.
My bad, it was a stupid thing to do
TomGeorge
Here are my voltage and current closed loop control I designed on MATLAB Simulink. You can see the feedback loop at the buttom there with gain blocks.The device I'm using to measure output voltage is a multimeter. (Practically). The current sensor I'm using is the ACS712, voltage sensor I built myself to output about 3 volts and its ground connects to arduino ground. I hope this is what you asked for.
Now, go back and put all those pics inline.
Right click one of the file names under your post and save the name (copy link address), then go to Modify the post. Click the add image icon (next to the chain) and use the saved name us the url and the pic will appear in the post.
That saves others downloading.
Oh I see what you mean
Threads merged. Again. STOP CROSS-POSTING!
Still not a schematic.
Why didn't you just say SMPS?
Tom... ![]()
