jkonze
January 5, 2023, 6:40am
1
Hi there,
I'm trying to connect a wiegand 26bit reader to my arduino uno - but I can just not make it work.
My wiring looks like this:
The back of the reader tells me that the orange wire is D0 and the brown one is D1.
And my code like this:
#include <Arduino.h>
// Wiegand lib https://github.com/monkeyboard/Wiegand-Protocol-Library-for-Arduino
#include <Wiegand.h>
WIEGAND wg;
int wiegandD0 = 2;
int wiegandD1 = 3;
wg.begin(wiegandD0, wiegandD1);
if(wg.available()) {
Serial.println("Got wiegand input");
long input = wg.getCode();
Serial.print("Pressed: ");
Serial.println(input);
Serial.print("No wiegand input detected");
What I want is that when I press a button, I get the output printed to serial.
But no matter what I do I will not get output to my Arduino.
Are there any obvious things that I'm missing?
Can someone help me with this?
Please let me know if you need more information.
Do you have a link to the reader datasheet ?
Also, just for completeness, I suspect your D0 and D1 are in fact DO and DI
(data out and data in)
Here’s hoping those signals are TTL levels, and not RS232
jkonze
January 5, 2023, 7:00am
3
Sadly I have no datasheet - what I do have is the manual.
Does that help in any capacity?
PaulRB
January 5, 2023, 7:26am
4
Yes, it tells you which connectors inside the unit are to D0 and D1 connectors. That's the only help it gives.
Based on that document I would say it is not safe to connect this unit to an Arduino.
That PDF’s a lot of use - but not much use !
You were right, D0 & D1 are certainly zero and one, but they appear from the scant notes to be for adding a second reader… ?
I would have hoped COM to be for COMms, but their schematic shows it is a relay COMmon pin, along with NC/NO and CPEN (Push button?)
I do appreciate the use of a BellEnd … never seen that before !
Along with the wifing line makes you appreciate chinese documentation and translation.
It doesn’t look like there are any references for serial control options.
jkonze
January 5, 2023, 9:19am
6
Thank you @PaulRB & @lastchancename
I've now tried another device and as soon as I tried it - it worked.
So the old one is going back to the vendor.
jkonze
January 5, 2023, 9:20am
7
Avoid this if you want to use wiegand 26
HFeng IP68 Waterproof RFID Access Control Keyboard Wiegand 26 Door Access Control System Outdoor Rainproof 125kHz with 10pcs EM4100 Key Chain Tags
Produktmerkmal1) Hergestellt aus hochwertigem ABS-Material. Hartplastikbehandlung. Feuerhemmend, schlagfest und verschleißfest!2) Wasserdichte IP68-Tastatur, Kann im Freien installiert werden3) Unterstützung von RFID-Karte, Passwort, RFID-Karte +...
19,79€
ve2dsk
June 30, 2023, 12:31pm
8
i'm interested to this project...
simple
ardiono pro micro
wiegand reader (D0 D1)
got this error with compiler
Compilation error: 'WIEGAND' does not name a type
Any idea.. ve2dsk
