Hello.
I'm using the synchronisation of things feature in the arduino IoT Cloud. The synchronisation is always between 2 variables (things) that are so synchronised. I works fine when only 1 variable of the 2 is updated by the sketch I have loaded on the board (variable 1 is updated by the sktech and the 2nd variable is updated throught the synchronisation process).
BUT the problem I'm facing is when the updates done with the sketch are done on the 2 variables : example variable 1 is updated by the sketch and variable 2 is updated via the synchronsation and other times that is the variable 2 that is updated by the sktech and the variable 1 is updated with the synchronisation.
The problem is appearing on a regular basis. It means that around every week, variable 2 is not updated via the synchronisation process when variable 1 is updated by the sketch. The problem is solved when I restart the board that is associated the the variable 1.
The variables that are not synchronised are :
- variable 1 = GdonneeMAJOUT (80762d76-2c9d-4c00-8853-1559df5325f6) - associated device = 6cdd24f2-710e-4c78-b939-2ccf87c588f7
and
- variable 2 = GFEdonneeMAJIN (ee9be093-50c1-4006-a6ba-d7639cfaaaf1) - associated device = 7751cba4-9904-4afe-8d6e-0fce67c07b2e
The question is so : how to avoid that desynchronisation ?
Is there something wrong in my script ?
My script is quite simple (running in the device associated to the variable 1) :
// Energie Mairie - Gway ALL - 20241230.02 - tracking des relais.txt
file = Energie Mairie - Gway LORA - ESP32 - 20240xxx---
Sketch pour Gway / LORA & OLED / Gateway centrale
P2P Lora - scenario Gway / Emission & reception
// !!!!!!!!!!!!!! DEBUT CONFIGURATION DE LA SOLUTION
// Qd ajout de capteur : chercher // ---- AJOUT de sonde
// 1) definir la Gway
#define GATEWAY_FE
// #define GATEWAY_FD
// 2) - type de carte
// #define ESP32_TTGO
#define ESP32 -LILYGOT31_6_1
// 3) DEBUG
//#define DEBUG_SERIAL
//#define DEBUG_OLED
#define OLED_LITE
// 4) - outil de compimation
// #define COMPILATION_CLOUD_IoT
#define COMPILATION_CLOUD_IDE
// #define COMPILATION_IDE
// 5)
#define BANDWITH433
// #define BANDWITH868
// ************* Donnees arduino
// 6) - Données Lora
const byte Header1 = 0x06; // pour reconnaire la trame Mairie
const byte Header2 = 0x07; // pour reconnaire la trame Mairie
const byte Adresse_Broadcast = 0xFF;
const byte Version_du_protocole_lora = 0x01; // version envoyée ds la trame Lora - prevu pour evolutions futures
const byte Message_de_donnee = 0x01;
const byte Message_de_keepalive = 0x02;
// 5) Connection Cloud ou non & Wifi
// #define DEVELOPPEMENT_NO_CLOUD_CONNEXION
#ifndef COMPILATION_CLOUD_IoT // // On exclut cette ligne en Cloud IoT car c'est déja inclu avec le Wifi etc...
#define WIFI_SSID "freecd9b4box8"
#define WIFI_PASSWORD "7869078690786"
#define SECRET_SSID WIFI_SSID
#define SECRET_OPTIONAL_PASS WIFI_PASSWORD
#endif
#ifdef GATEWAY_FE
int const Nbre_de_capteurs_configures = 8; // sur cette Gway - pour contrôle des adresses recues // ---- AJOUT de capteur
int const ID_premier_capteurs_configure = 1;
#define SECRET_DEVICE_KEY "Uxe3l5kmFfx3VM?daa5EBiYGv" // Ruches Connectees
const byte Adresse_Device = 0xFE; // address of this device / CH = that is the Gateway - uniquement en reception
#if defined COMPILATION_CLOUD_IoT || defined COMPILATION_CLOUD_IDE // Pour differencier complilation IDE & CLOUD
#include "thingProperties-Ruches-Connectees-GwayFE.h"
#endif
#endif
#ifdef GATEWAY_FD
int const Nbre_de_capteurs_configures = xxxx; // sur cette Gway - pour contrôle des adresses recues
int const ID_premier_capteurs_configure = xxxx;
const byte Adresse_Device = 0xFD; // address of this device / CH = that is the Gateway - uniquement en reception
#define SECRET_DEVICE_KEY "bJRc!2S#vVjap01YLGcRr#5H@"
#include "thingProperties-Energie-GwayFD.h"
#endif
#endif
float *Gway_donnee1OUT = &Gdonnee1OUT;
float *Gway_donnee2OUT = &Gdonnee2OUT;
float *Gway_donnee3OUT = &Gdonnee3OUT; // 29/12/2024
bool *Gway_donnee4OUT = &Gdonnee4OUT; // 29/12/2024
int *Gway_capteurIDOUT = &GcapteurIDOUT;
bool *Gway_donneeMAJOUT = &GdonneeMAJOUT;
String *PORTAIL_gateway_texte = >EXTE;
// 7) - Autres mesures
const int Duree_pour_MAJ_status_Gway_mn = 15;
// 8) - Données du PORTAIL non configurées - pour test avant déploiement IoT Mairie - DEBUT
#if not defined COMPILATION_CLOUD_IoT && not defined COMPILATION_CLOUD_IDE
float Gdonnee1OUT;
float Gdonnee2OUT;
float Gdonnee3OUT; // 29/12/2024
bool Gdonnee4OUT; // 29/12/2024
int GcapteurIDOUT;
bool GdonneeMAJOUT;
String Gtexte;
bool GSTATDEV;
#endif
//*** CONTEXT/CONSTANTES * TO BE UPDATED/FIN **********************************************************
#include <WiFi.h>
#endif
#include <SPI.h> // include libraries
#include <LoRa.h>
//Libraries for OLED Display
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#ifdef BANDWITH433
#define BAND 433E6
#endif
#ifdef BANDWITH868
#define BAND 868E6
#endif
// version TTGO ESP32
#ifdef ESP32_TTGO
//define the pins used by the LoRa transceiver module
#define SCK 5
#define MISO 19
#define MOSI 27
#define SS 18
#define RST 14 // Changed CH - OLD = 16; NEW = 14
#define DIO0 26
#define DIO1 33
#define DIO2 32
//OLED pins
#define OLED_SDA 4
#define OLED_SCL 15
#define OLED_RST 16
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#endif
// version 2 ESP32 LillyGo [from Bidouilleurs https://www.youtube.com/watch?v=o8Pd-hZDYwc]
#ifdef ESP32 - LILYGOT31_6_1
#define SCK 5
#define MISO 19
#define MOSI 27
#define SS 18
#define RST 23 // OLD = 16
#define DIO0 26
//OLED pins LiLYGo / T3 version 1.6.1
#define OLED_SDA 21
#define OLED_SCL 22
#define OLED_RST 2 // n'est peut être pas le 2 mais e, tout cas, pas le 16
#endif
// Initialisation ecran OLED
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RST);
// constante OLED
const int debut_ligne_status = 0;
const int debut_ligne_received = 9;
const int debut_ligne_sent = 36;
const int increment_ligne = 9;
const int Clear_ecran_OLED = 1; //25/11/2024
const int Pas_clear_ecran_OLED = 0; //25/11/2024
const int Clear_ligne_OLED = 1; //25/11/2024
const int Pas_clear_ligne_OLED = 0; //25/11/2024
const int Couleur_OLED_blanc = 1; //25/11/2024
String *PORTAIL_gateway_text;
// enregistrement des numeros de essage reçus pour éviter le traitement en double de messages relayés par les relais
const int taille_tab_messages_recus = 6; // taille de la table de suivi de smessages reçus pour éviter les doublons
int index_courant_tab_messages_recus = 0; // index de remplissage du suivi de smessages reçus pour éviter les doublons
int tab_messages_recus[taille_tab_messages_recus]; // table qui garde les numéros des msg reçus pour éviter doublon
unsigned long tab_messages_recus_tempo_t0[taille_tab_messages_recus]; // table qui garde le moment "CurrentTime" où le message a été reçu
const float messages_recus_tempo_duree = 60 * 1000; // durée durant laquelle on garde les messages pour éviter les répets - en milisecondes
// Autres variables
unsigned long currentTime = 0;
const int MaxCurrentTime_Jour = 50;
unsigned long status_Gway_alive_tempo_t0;
unsigned long status_Gway_alive_tempo_duree = Duree_pour_MAJ_status_Gway_mn * 60 * 1000;
int nombre_de_fois_current_time_reached = 0;
int currentTimeJour = 0;
int currentTimeJourCumule = 0;
int currentTimeHeure = 0;
int currentTimeMinute = 0;
unsigned long keepalive_tempo_t0;
const int Duree_entre_keepalive_gateway_mn = 30;
const unsigned long keepalive_tempo_duree = Duree_entre_keepalive_gateway_mn * 60 * 1000;
unsigned long clean_portail_msg_text_t0 = 0;
unsigned long clean_portail_msg_text_duree = 3 * 24 * 60 * 60 * 1000; // changé valeur : passé à 48
unsigned long impression_variable_delais = 60 * 60 * 1000; // 08/01/2025
unsigned long impression_variable_t0 = 0; // 02/01/2025
#if defined DEBUG_OLED || defined OLED_LITE // 03/04/2025
// clignotement surt ecran //Ajputé 30/10/2024
unsigned long clignotement_OLED_t0 = 0;
unsigned long clignotement_OLED_duree = 3000; // 03/04/2025
int clignotement_OLED_horizontal = 120;
int clignotement_OLED_vertical = 60;
int clignotement_OLED_taille = 2;
#endif
// Structure relais - 27/11/2024
const int Nbre_de_relais = 3;
struct __attribute__((packed)) suivi_relais {
byte adresse_du_relais;
bool status_relais_Up;
bool *LED_status_relais_Up; // info fournie par paquest de mesures recus & keepalive du relais
bool donnee_de_travail_relais_Up;
bool status_relais_used;
bool *LED_relais_used; // info fournie par paquest de mesures recus
bool donnee_de_travail_relais_used;
suivi_relais tableau_de_suivi_des_relais[Nbre_de_relais] = { // 27/11/2024
{ 0xA0, false, &r01STATDEV, false, false, &r01USED, false },
{ 0xA1, false, &r02STATDEV, false, false, &r02USED, false },
{ 0xA2, false, &r03STATDEV, false, false, &r03USED, false }
unsigned long suivi_MAJ_relais_t0 = 0;
unsigned long suivi_MAJ_relais_duree_mn = 60 * 24 * 3;
unsigned long suivi_MAJ_relais_duree = suivi_MAJ_relais_duree_mn * 60 * 1000;
unsigned long clignotement_LED_relais_t0 = 0;
unsigned long clignotement_LED_relais_duree = 1 * 1000;
const int Check_if_relais_used = 1; // 27/11/2024
const int Check_if_relais_Up = 2; // 29/12/2024
String message_du_portail;
int numero_device = 0;
bool message_valable = false;
int index_numero_device = 0;
int message_status = 0;
int message_ERR = 0;
int n = 0;
bool bool_donnee_de_travail;
int suivi_automate = 0;
int phase_de_setup = 1;
const int debut_numero_du_message = 254; // pour les msg envoyés par la gateway
// LORA - Donnees pour traitement des infos reçues
byte header1_du_message;
byte header2_du_message;
byte version_du_message;
byte emetteur_du_message;
byte destinataire_du_message;
byte relais1_du_message;
byte relais2_du_message;
byte relais3_du_message;
int numero_du_message = 0;
byte type_du_message;
float donnee1_du_message;
const float Donnee1_MAX = 100000; //14/03/2025
const float Donnee1_MIN = 0; //14/03/2025
const float Donnee2_MAX = 0; //14/03/2025
const float Donnee2_MIN = 0; //14/03/2025
float donnee2_du_message;
float donnee3_du_message;
boolean donnee4_du_message;
float checksum_du_message;
char text_du_message[30];
int taille_du_message;
// Structure Lora
struct __attribute__((packed)) MessageLora {
byte header1; // pour reconnaitre trame ruche
byte header2; // pour reconnaitre trame ruche
byte version; // pour évolutions future
byte emetteur;
byte destinataire;
byte relais1;
byte relais2;
byte relais3;
int32_t numero_du_message;
float donnee1; // poids de la ruche
float donnee2; // pour évolution future
float donnee3; // pour évolution future
boolean donnee4; // pour évolution future
float checksum; // pour évolution future
char text[30];
MessageLora messageLora;
MessageLora messageLoraINIT; //03/04/2025
// Msg d'erreur
char *tab_message_ERR[10] = { "", "1)hd/ver KO", "2)emet. KO", "3)dest. KO", "4)broad.", "5)type KO", "6)d1/d2 KO", "7)check KO", "8)Dup. msg", "" };
// Initialize serial and wait for port to open:
#ifdef DEBUG_SERIAL
// This delay gives the chance to wait for a Serial Monitor without blocking if none is found
delay(10000);
Serial.println("Entree / setup...");
#endif
initProperties();
// Connect to Arduino IoT Cloud
ArduinoCloud.begin(ArduinoIoTPreferredConnection);
// Mise en commentaire pour compilation IDE
setDebugMessageLevel(2);
ArduinoCloud.printDebugInfo();
#endif
#ifdef DEBUG_SERIAL
Serial.println("Arduino initialisé");
#endif
//reset OLED display via software
pinMode(OLED_RST, OUTPUT);
digitalWrite(OLED_RST, 0);
delay(20);
digitalWrite(OLED_RST, HIGH);
//initialize OLED
Wire.begin(OLED_SDA, OLED_SCL);
if (!display.begin(SSD1306_SWITCHCAPVCC, 0x3c, false, false)) { // Address 0x3C for 128x32
Serial.println(F("SSD1306 allocation failed"));
for (;;)
; // Don't proceed, loop forever
Serial.println("OLED ready");
#endif
// override the default CS, reset, and IRQ pins (optional)
//SPI LoRa pins
SPI.begin(SCK, MISO, MOSI, SS);
//setup LoRa transceiver module
LoRa.setPins(SS, RST, DIO0);
if (!LoRa.begin(BAND)) { // initialize ratio for Europe
displayOLED(Clear_ecran_OLED, Pas_clear_ligne_OLED, 0, debut_ligne_status, 1, "LoRa init failed. Check your connections", 1);
#endif
while (true)
; // if failed, do nothing
displayOLED(Clear_ecran_OLED, Pas_clear_ligne_OLED, 0, debut_ligne_status, 1, "LoRa OK - Gway", 1);
#endif
#ifdef DEBUG_SERIAL
Serial.println("LoRa init succeeded");
#endif
LoRa.setSpreadingFactor(12);
LoRa.setSignalBandwidth(62.5E3);
LoRa.setCodingRate4(5); //min 5- max 8
currentTime = millis();
// MAJ_des_donnees_ms_t0 = currentTime;
*Gway_donneeMAJOUT = false;
*Gway_donnee1OUT = 0;
*Gway_donnee2OUT = 0;
*Gway_donnee3OUT = 0; // 29/12/2024
*Gway_donnee4OUT = false; // 29/12/2024
*Gway_capteurIDOUT = 0;
Serial.print("Gateway demarree - ");
Serial.println("GATEWAY_" + String(Adresse_Device) + " - ");
Serial.println("Données après initiaisation - ");
Serial.print("GFxdonneeMAJOUT = " + String(*Gway_donneeMAJOUT) + " /");
Serial.print("GFxcapteurIDOUT = " + String(*Gway_capteurIDOUT) + " /");
Serial.print("GFxdonnee1OUT = " + String(*Gway_donnee1OUT) + " /");
Serial.println("GFxdonnee2OUT = " + String(*Gway_donnee2OUT));
Serial.print("GFxdonnee3OUT = " + String(*Gway_donnee3OUT) + " /"); // 29/12/2024
Serial.println("GFxdonnee4OUT = " + String(*Gway_donnee4OUT)); // 29/12/2024
keepalive_tempo_t0 = currentTime;
status_Gway_alive_tempo_t0 = currentTime;
clean_portail_msg_text_t0 = currentTime;
suivi_MAJ_relais_t0 = currentTime; // 26/11/2024
clignotement_LED_relais_t0 = currentTime; // 27/11/2024
impression_variable_t0 = currentTime; // 02/01/2025
init_structure_lora(); // 03/04/2025
for (n = 0; n < taille_tab_messages_recus; n++) // 27/11/2024
tab_messages_recus[n] = 0; //27/11/2024
tab_messages_recus_tempo_t0[n] = 0;
for (n = 0; n < Nbre_de_relais; n++) // 26/12/2024
tableau_de_suivi_des_relais[n].status_relais_Up = false;
*tableau_de_suivi_des_relais[n].LED_status_relais_Up = false;
tableau_de_suivi_des_relais[n].donnee_de_travail_relais_Up = false;
tableau_de_suivi_des_relais[n].status_relais_used = false;
*tableau_de_suivi_des_relais[n].LED_relais_used = false; // info fournie par paquest de mesures recus
tableau_de_suivi_des_relais[n].donnee_de_travail_relais_used = false;
clignotement_OLED_t0 = currentTime; //30/10/2024
#endif
// Traitement des données de l'application ruche
#ifdef DEBUG_SERIAL
Serial.println("Sortie / setup");
Serial.print("Arduino Stack was set to bytes " + String(getArduinoLoopTaskStackSize()) + "bytes"); // 02/01/2025
// Print unused stack for the task that is running setup()
Serial.println(" - Free Stack Space: " + String(uxTaskGetStackHighWaterMark(NULL))); // 02/01/2025
#endif
// *PORTAIL_gateway_texte = PropertyActions::CLEAR; // on ne clean pas au depour voir si plantage - 19/01/2025 - CLEAR supprimé
*PORTAIL_gateway_texte = String("Gateway_") + String(Adresse_Device) + String(" démarée et initialisée");
*PORTAIL_gateway_texte = "Arduino Stack was set to " + String(getArduinoLoopTaskStackSize()) + " - Free Stack Space " + String(uxTaskGetStackHighWaterMark(NULL)); // 05/01/2025
phase_de_setup = 0;
#ifdef OLED_LITE
displayOLED(Clear_ecran_OLED, Clear_ligne_OLED, 0, debut_ligne_status, 1, "Gway Ruche on-line", 1);
#endif
#if not defined DEVELOPPEMENT_NO_CLOUD_CONNEXION
if (WiFi.status() != WL_CONNECTED) // 26/11/2024
#if defined DEBUG_OLED // 03/04/2025
displayOLED(Clear_ecran_OLED, Clear_ligne_OLED, 0, debut_ligne_status, 1, "WIFI KO !!!!!", 1);
#endif
#ifdef DEBUG_SERIAL
Serial.println("WIFI KO !!!!!");
#endif
if (!ArduinoCloud.connected()) {
displayOLED(Clear_ecran_OLED, Clear_ligne_OLED, 0, debut_ligne_status, 1, "Arduino Not connected", 1);
#endif
ArduinoCloud.update();
#endif
#endif
if (currentTime - clignotement_OLED_t0 > clignotement_OLED_duree) {
GSTATUSDEV = !GSTATUSDEV;
display.fillCircle(clignotement_OLED_horizontal, clignotement_OLED_vertical, clignotement_OLED_taille, INVERSE);
display.display(); // Update screen with each newly-drawn circle
#endif
if (suivi_automate != 1) {
#ifdef DEBUG_SERIAL
Serial.println("Gway #" + String(Adresse_Device) + " - attente msg.");
#endif
#ifdef DEBUG_OLED
displayOLED(Pas_clear_ecran_OLED, Clear_ligne_OLED, 0, debut_ligne_status, 1, "Gway/attente msg", 1);
#endif
suivi_automate = 1;
// parse for a packet, and call onReceive with the result:
message_status = 0;
onReceive(LoRa.parsePacket());
if (message_status == 1) // message recu
suivi_automate = 2;
// lecture du message recu
lecture_du_message();
// controle du message recu
message_ERR = 0;
ctrl_du_message();
if (message_ERR == 0) // pas d'erreur - message correct
suivi_automate = 3;
#ifdef DEBUG_OLED
displayOLED(Pas_clear_ecran_OLED, Clear_ligne_OLED, 0, debut_ligne_received, 1, "Msg received OK", 1);
displayOLED(Pas_clear_ecran_OLED, Clear_ligne_OLED, 0, debut_ligne_received + increment_ligne, 1, String(emetteur_du_message) + "/" + String(destinataire_du_message) + "(r" + String(relais1_du_message) + "+" + String(relais2_du_message) + "+" + String(relais3_du_message) + ")-#" + String(numero_du_message) + "-d1:" + String(donnee1_du_message), 1);
#endif
*PORTAIL_gateway_texte = "Msg received OK - #" + String(emetteur_du_message) + "/" + String(destinataire_du_message) + "(r" + String(relais1_du_message) + "+" + String(relais2_du_message) + "+" + String(relais3_du_message) + ") / Num msg = " + String(numero_du_message) + " /d1 = " + String(donnee1_du_message) + " /d2 = " + String(donnee2_du_message) + " /d3 = " + String(donnee3_du_message) + " /d4 = " + String(donnee4_du_message) + "/Rssi = " + String(LoRa.packetRssi()) + "/Snr: " + String(LoRa.packetSnr()); //13/01/2025 - correction display
traitement_des_donnees();
#ifdef DEBUG_OLED
displayOLED(Pas_clear_ecran_OLED, Clear_ligne_OLED, 0, debut_ligne_received, 1, "Msg received KO", 1);
displayOLED(Pas_clear_ecran_OLED, Clear_ligne_OLED, 0, debut_ligne_received + increment_ligne, 1, "ERR" + String(tab_message_ERR[message_ERR]) + "#" + String(numero_du_message), 1);
#endif
// message par defaut
message_du_portail = String("Msg received KO - ERR ");
// Complément de message
if (message_ERR == 1) //pb header ou version
#ifdef DEBUG_SERIAL
Serial.println(String(tab_message_ERR[message_ERR]) + " - version = " + String(version_du_message) + " / h1 = " + String(header1_du_message) + " / h2 = " + String(header2_du_message));
#endif
message_du_portail = message_du_portail + String(tab_message_ERR[message_ERR]) + " - ver = " + String(version_du_message) + " / dev# = " + String(numero_device) + " / h1 = " + String(header1_du_message) + " / h2 = " + String(header2_du_message) + " / d1 = " + String(donnee1_du_message) + " / d2 = " + String(donnee2_du_message) + " / d3 = " + String(donnee3_du_message) + " / d4 = " + String(donnee4_du_message);
if (message_ERR == 2) // pb numero de device emetteur
#ifdef DEBUG_SERIAL
Serial.println(String(tab_message_ERR[message_ERR]) + " - dev# = " + String(numero_device));
#endif
message_du_portail = message_du_portail + String(tab_message_ERR[message_ERR]) + " / dev# = " + String(numero_device) + " / d1 = " + String(donnee1_du_message) + " / d2 = " + String(donnee2_du_message) + " / d3 = " + String(donnee3_du_message) + " / d4 = " + String(donnee4_du_message);
if (message_ERR == 3) // Pb destinataire
#ifdef DEBUG_SERIAL
Serial.println(String(tab_message_ERR[message_ERR]) + " – device dest = " + String(destinataire_du_message));
#endif
message_du_portail = message_du_portail + String(tab_message_ERR[message_ERR]) + " – device dest = " + String(destinataire_du_message) + " / dev# = " + String(numero_device) + " / d1 = " + String(donnee1_du_message) + " / d2 = " + String(donnee2_du_message) + " / d3 = " + String(donnee3_du_message) + " / d4 = " + String(donnee4_du_message);
if (message_ERR == 4) // Adresse Broadcast
#ifdef DEBUG_SERIAL
Serial.println(String(tab_message_ERR[message_ERR]) + " – De:" + String(emetteur_du_message)); //
#endif
message_du_portail = message_du_portail + String(tab_message_ERR[message_ERR]) + " – De:" + String(emetteur_du_message) + "/Rssi = " + String(LoRa.packetRssi()) + "/Snr: " + String(LoRa.packetSnr()); // 19/03/2025
// si keepalive, alors on regarde si cela vient d'1 relais -
if (type_du_message == Message_de_keepalive) {
suivi_fonctionnement_de_un_relais(emetteur_du_message, Check_if_relais_Up); // on regarde si le msg est 1 keepalive et ds ce cas, on mentionne que le relais fonctionne. // 29/12/2024
if (message_ERR == 5) // erreur type de message
#ifdef DEBUG_SERIAL
Serial.println(String(tab_message_ERR[message_ERR]) + " - Type = " + String(type_du_message));
#endif
message_du_portail = message_du_portail + String(tab_message_ERR[message_ERR]) + " - Type = " + String(type_du_message) + " / dev# = " + String(numero_device) + " / d1 = " + String(donnee1_du_message) + " / d2 = " + String(donnee2_du_message) + " / d3 = " + String(donnee3_du_message) + " / d4 = " + String(donnee4_du_message);
if (message_ERR == 6) // Pb sur données
#ifdef DEBUG_SERIAL
Serial.println(String(tab_message_ERR[message_ERR]) + " - d1 = " + String(donnee1_du_message) + " / d2 = " + String(donnee2_du_message));
#endif
if (message_ERR == 7) // pb Checksum
#ifdef DEBUG_SERIAL
Serial.println(String(tab_message_ERR[message_ERR]));
#endif
message_du_portail = message_du_portail + String(tab_message_ERR[message_ERR]) + " / dev# = " + String(numero_device) + " / numero = " + String(numero_du_message) + " / d1 = " + String(donnee1_du_message) + " / d2 = " + String(donnee2_du_message) + " / d3 = " + String(donnee3_du_message) + " / d4 = " + String(donnee4_du_message) + " / check = " + String(checksum_du_message);
if (message_ERR == 8) // duplicate msg - on peut supposer qu'il s"agit d'1 relais
#ifdef DEBUG_SERIAL
#endif
message_du_portail = message_du_portail + String(tab_message_ERR[message_ERR]) + " - #" + String(numero_du_message) + " / dev# = " + String(numero_device) + " - r" + String(relais1_du_message) + "+" + String(relais2_du_message) + "+" + String(relais3_du_message) + "/Rssi = " + String(LoRa.packetRssi()) + "/Snr: " + String(LoRa.packetSnr()); // 14/02/2025 - ajouté rrsi
Check_etat_des_relais(Check_if_relais_Up); // 29/12/2024 - C'est 1 message dupliqu. Mais on regarde si c'est à cause d'1 relais. Et ds ce cas, on mentionne que le relais est actif - mais pas utilisé car déja recu.
// MAj du message du portail pour signaler l'erreur
*PORTAIL_gateway_texte = message_du_portail;
// nettoyage de la structure Lora
nettoyage_structure_lora();
// envoi du keepalive pour test de distance
if ((currentTime - keepalive_tempo_t0) > keepalive_tempo_duree) {
envoi_keepalive();
#ifdef DEBUG_SERIAL
Serial.println("keepalive envoyé");
#endif
// calcul du nbre de mn la Gway a été lancé
if ((currentTime - status_Gway_alive_tempo_t0) > status_Gway_alive_tempo_duree) {
MAJdonneesportailGway();
if ((currentTime - clean_portail_msg_text_t0) > clean_portail_msg_text_duree) {
// gestion des relais - 27/11/2024
// Reinitialisation du tableau de MAJ
if ((currentTime - suivi_MAJ_relais_t0) > suivi_MAJ_relais_duree) {
MAJ_des_infos_des_relais_sur_portail;
#ifdef DEBUG_SERIAL
Serial.println("MAJ du tableau des relais");
#endif
// Clignotement des LEDs associées aux relais - 27/11/2024
if ((currentTime - clignotement_LED_relais_t0) > clignotement_LED_relais_duree) {
for (int h = 0; h < Nbre_de_relais; h++) {
if (tableau_de_suivi_des_relais[h].status_relais_Up == true) {
bool_donnee_de_travail = *tableau_de_suivi_des_relais[h].LED_status_relais_Up;
*tableau_de_suivi_des_relais[h].LED_status_relais_Up = !bool_donnee_de_travail;
} else
*tableau_de_suivi_des_relais[h].LED_status_relais_Up = false;
if (tableau_de_suivi_des_relais[h].status_relais_used == true) {
bool_donnee_de_travail = *tableau_de_suivi_des_relais[h].LED_relais_used;
*tableau_de_suivi_des_relais[h].LED_relais_used = !bool_donnee_de_travail;
} else
*tableau_de_suivi_des_relais[h].LED_relais_used = false;
if ((currentTime - impression_variable_t0) > impression_variable_delais) // 02/01/2025
// Print unused stack for the task that is running loop() - the same as for setup()
#ifdef DEBUG_SERIAL
Serial.println("Free Stack Space: " + String(uxTaskGetStackHighWaterMark(NULL)) + "Bytes"); // 02/01/2025
#endif
*PORTAIL_gateway_texte = "Arduino Stack was set to " + String(getArduinoLoopTaskStackSize()) + "- Free Stack Space " + String(uxTaskGetStackHighWaterMark(NULL)); // 05/01/2025
void MAJdonneesportailGway()
#ifdef DEBUG_SERIAL
Serial.println("Entrée / MAJdonneesportailGway");
#endif
// Si le compteur currentTime a recommencé à zéro, alors on compte 1 boucle
if (currentTime < status_Gway_alive_tempo_t0)
nombre_de_fois_current_time_reached = nombre_de_fois_current_time_reached + 1;
status_Gway_alive_tempo_t0 = currentTime; // on réinitialise t0
// calcul des données du portail
currentTimeJourCumule = nombre_de_fois_current_time_reached * MaxCurrentTime_Jour + round(currentTime / 1000 / 60 / 60 / 24);
currentTimeJour = currentTimeJourCumule - nombre_de_fois_current_time_reached * MaxCurrentTime_Jour;
currentTimeHeure = round((currentTime - currentTimeJour * 24 * 60 * 60 * 1000) / 1000 / 60 / 60);
currentTimeMinute = round(((currentTime - currentTimeHeure * 60 * 60 * 1000 - currentTimeJour * 24 * 60 * 60 * 1000) / 60 / 1000));
// MAJ des données du portail
*PORTAIL_gateway_jour = currentTimeJourCumule;
*PORTAIL_gateway_heure = currentTimeHeure;
*PORTAIL_gateway_minute = currentTimeMinute;
*PORTAIL_gateway_texte = "Gway Up&Running depuis " + String(currentTimeJour) + "j, " + String(currentTimeHeure) + "h, " + String(currentTimeMinute);
#ifdef DEBUG_SERIAL
Serial.println("currentTimeJourCumule = " + String(currentTimeJourCumule));
Serial.println("currentTimeHeure = " + String(currentTimeHeure));
Serial.println("currentTimeMinute = " + String(currentTimeMinute));
Serial.println("Sortie / Traitement_des_donnees");
#endif
void traitement_des_donnees()
#ifdef DEBUG_SERIAL
Serial.println("Entrée / Traitement_des_donnees");
#endif
Serial.println("MAJ des donnees");
*Gway_donnee1OUT = donnee1_du_message;
*Gway_donnee2OUT = donnee2_du_message;
*Gway_donnee3OUT = donnee3_du_message; //29/12/2024
*Gway_donnee4OUT = donnee4_du_message; //29/12/2024
// *Gway_donnee1OUT = random(0, 100);
// *Gway_donnee2OUT = random(0, 100);
*Gway_capteurIDOUT = index_numero_device + 1;
*Gway_donneeMAJOUT = true;
#ifdef DEBUG_SERIAL
Serial.println("AVANT - MAJ des donnees");
Serial.print("Gxxdonnee1OUT = " + String(*Gway_donnee1OUT) + " /");
Serial.print("Gxxdonnee2OUT = " + String(*Gway_donnee2OUT) + " /");
Serial.print("Gxxdonnee3OUT = " + String(*Gway_donnee3OUT) + " /"); //29/12/2024
Serial.print("Gxxdonnee4OUT = " + String(*Gway_donnee4OUT) + " /"); //29/12/2024
Serial.print("GxxdonneeMAJOUT = " + String(*Gway_donneeMAJOUT) + " /");
Serial.println("GxxcapteurIDOUT = " + String(*Gway_capteurIDOUT));
#endif
Check_etat_des_relais(Check_if_relais_used); // 27/11/2024 - c'est 1 msg correct - on regarde s'il a été retransmis par un relais, et ds ce cas, on mentionne que le relais est actif et est UTILISé
} // fin du traitement des données
void Check_etat_des_relais(int type_de_controle) { // 27/11/2024
// Analyse des données relais reçues ds la trame
if (relais1_du_message != 0)
suivi_fonctionnement_de_un_relais(relais1_du_message, type_de_controle);
if (relais2_du_message != 0)
suivi_fonctionnement_de_un_relais(relais2_du_message, type_de_controle);
if (relais3_du_message != 0)
suivi_fonctionnement_de_un_relais(relais3_du_message, type_de_controle);
void suivi_fonctionnement_de_un_relais(byte adresse_du_relais_actif, int type_de_controle) // 24/11/2024
// si seulement controle relais actif > on en met à jour que les donnees du remais actif
// si demande de controle = relais used, alors on met aussi à jour relais used
#ifdef DEBUG_SERIAL
Serial.println("Entrée suivi_fonctionnement_des_relais #" + String(adresse_du_relais_actif));
#endif
for (int z = 0; z < Nbre_de_relais; z++) {
if (tableau_de_suivi_des_relais[z].adresse_du_relais == adresse_du_relais_actif) {
#ifdef DEBUG_SERIAL
Serial.println("Relais reconnu - " + String(adresse_du_relais_actif));
#endif
tableau_de_suivi_des_relais[z].status_relais_Up = true;
tableau_de_suivi_des_relais[z].donnee_de_travail_relais_Up = true; // 29/12/2024
// *PORTAIL_gateway_texte = "Relais [" + String(tableau_de_suivi_des_relais[z].adresse_du_relais) + "] Up";
if (type_de_controle == Check_if_relais_used) {
tableau_de_suivi_des_relais[z].status_relais_used = true;
// *PORTAIL_gateway_texte = "Relais [" + String(tableau_de_suivi_des_relais[z].adresse_du_relais) + "/" + String(adresse_du_relais_actif) + "] used - capteurID [#" + String(emetteur_du_message) + "] type ctrl=" + String(type_de_controle); // 30/12/24
tableau_de_suivi_des_relais[z].donnee_de_travail_relais_used = true;
void MAJ_des_infos_des_relais_sur_portail() // 27/11/2024
// controle des relais qui ne sont plus utilisés
for (int j = 0; j < Nbre_de_relais; j++) {
if (tableau_de_suivi_des_relais[j].donnee_de_travail_relais_Up == true) {
tableau_de_suivi_des_relais[j].status_relais_Up = true;
tableau_de_suivi_des_relais[j].status_relais_Up = false;
if (tableau_de_suivi_des_relais[j].donnee_de_travail_relais_used == true) {
tableau_de_suivi_des_relais[j].status_relais_used = true;
tableau_de_suivi_des_relais[j].status_relais_used = false;
// reinitialisation des données de travai
tableau_de_suivi_des_relais[j].donnee_de_travail_relais_Up = false;
tableau_de_suivi_des_relais[j].donnee_de_travail_relais_used = false;
void preparation_du_message_keepalive()
#ifdef DEBUG_SERIAL
Serial.println("Entree / preparation_du_message_keepalive");
#endif
header1_du_message = Header1;
header2_du_message = Header2;
version_du_message = Version_du_protocole_lora;
emetteur_du_message = Adresse_Device;
destinataire_du_message = Adresse_Broadcast;
relais1_du_message = 0x00;
relais2_du_message = 0x00;
relais3_du_message = 0x00;
numero_du_message = random(debut_numero_du_message, debut_numero_du_message + 99);
type_du_message = Message_de_keepalive;
donnee1_du_message = 0;
donnee2_du_message = 0;
donnee3_du_message = 0;
donnee4_du_message = 0;
checksum_du_message = numero_du_message + donnee1_du_message + donnee2_du_message + donnee3_du_message + donnee4_du_message;
// text_du_message = "";
#ifdef DEBUG_SERIAL
Serial.println("Sortie / preparation_du_message_keepalive");
#endif
void envoi_keepalive()
#ifdef DEBUG_SERIAL
Serial.println("Entree / envoi_keepalive");
#endif
preparation_du_message_keepalive();
ecriture_du_message();
sendMessage();
#ifdef DEBUG_SERIAL
Serial.println("Sortie / envoi_keepalive");
#endif
void ctrl_du_message()
#ifdef DEBUG_SERIAL
Serial.println("Entree / ctrl_du_message");
#endif
// Controle du message recu
if ((version_du_message != Version_du_protocole_lora) || (header1_du_message != Header1) || (header2_du_message != Header2)) {
message_ERR = 1;
return; // skip rest of function
// Controle du type message recu
// Modifié 25/06/24 pour contrôle type du message
if ((type_du_message != Message_de_donnee) && (type_du_message != Message_de_keepalive)) {
message_ERR = 5;
// controle du numero de device recu
if ((type_du_message == Message_de_donnee) && ((numero_device < ID_premier_capteurs_configure) || (numero_device > ID_premier_capteurs_configure + Nbre_de_capteurs_configures - 1))) //
message_ERR = 2;
index_numero_device = numero_device - 1;
// Contrôle broadcast
if (destinataire_du_message == Adresse_Broadcast) {
message_ERR = 4;
// Controle du destinataire recu
if (destinataire_du_message != Adresse_Device) {
message_ERR = 3;
// Contrôle de la valeur mesurée
// Modifié 02/07/24
if ((donnee1_du_message > Donnee1_MAX) || (donnee1_du_message < Donnee1_MIN) || (donnee2_du_message < Donnee2_MIN) || (donnee2_du_message > Donnee2_MAX)) {
message_ERR = 6;
// Ctrl Checksum
if (checksum_du_message != numero_du_message + donnee1_du_message + donnee2_du_message + donnee3_du_message + donnee4_du_message) {
message_ERR = 7;
// verifiation que le message n'a pas déja été recu / eviter réémission par relais
for (int i = 0; i < taille_tab_messages_recus; i++) {
if (numero_du_message == tab_messages_recus[i] & (currentTime - tab_messages_recus_tempo_t0[i] < messages_recus_tempo_duree)) {
message_ERR = 8;
// enregistrement du numero de message
tab_messages_recus[index_courant_tab_messages_recus] = numero_du_message;
tab_messages_recus_tempo_t0[index_courant_tab_messages_recus] = currentTime;
index_courant_tab_messages_recus++;
if (index_courant_tab_messages_recus == taille_tab_messages_recus)
// Le message est valable
#ifdef DEBUG_SERIAL
Serial.println("Message recu valable");
Serial.println("Sortie / ctrl_du_message");
#endif
!! FONCTIONS COMMUNES AUX DEVICES - SYSTEMES, RELAIS, GATEWAY
!! A recopier
void onReceive(int packetSize)
if (packetSize == 0) {
message_status = 0;
return; // if there's no packet, return
taille_du_message = packetSize;
#ifdef DEBUG_SERIAL
Serial.println("Message recu...........................................");
Serial.print("Lora receive RSSI ");
Serial.print(LoRa.packetRssi());
Serial.print(" packet size ");
Serial.println(packetSize);
#endif
message_status = 1;
void nettoyage_structure_lora()
#ifdef DEBUG_SERIAL
Serial.println("nettoyage_structure_lora");
#endif
memcpy(&messageLora, &messageLoraINIT, sizeof(messageLoraINIT));
messageLora.header1 = 0x00;
messageLora.header2 = 0x00;
messageLora.version = 0x00;
messageLora.emetteur = 0x00;
messageLora.destinataire = 0x00;
messageLora.relais1 = 0x00;
messageLora.relais2 = 0x00;
messageLora.relais3 = 0x00;
messageLora.numero_du_message = 0;
messageLora.donnee1 = 0;
messageLora.donnee2 = 0;
messageLora.donnee3 = 0;
messageLora.donnee4 = false;
messageLora.checksum = 0;
for (n = 0; n < 30; n++)
messageLora.text[n] = ' ';
void init_structure_lora() // 03/04/2025
#ifdef DEBUG_SERIAL // 03/04/2025
Serial.println("Entree / init_structure_lora");
#endif
messageLoraINIT.header1 = 0x00;
messageLoraINIT.header2 = 0x00;
messageLoraINIT.version = 0x00;
messageLoraINIT.emetteur = 0x00;
messageLoraINIT.destinataire = 0x00;
messageLoraINIT.relais1 = 0x00;
messageLoraINIT.relais2 = 0x00;
messageLoraINIT.relais3 = 0x00;
messageLoraINIT.numero_du_message = 0;
messageLoraINIT.type_du_message = 0x00;
messageLoraINIT.donnee1 = 0;
messageLoraINIT.donnee2 = 0;
messageLoraINIT.donnee3 = 0;
messageLoraINIT.donnee4 = 0;
messageLoraINIT.checksum = 0;
messageLoraINIT.text[n] = ' ';
Serial.println("Sortie / init_structure_lora");
#endif
void ecriture_du_message()
#ifdef DEBUG_SERIAL
Serial.println("ecriture_du_message");
#endif
messageLora.header1 = header1_du_message;
messageLora.header2 = header2_du_message;
messageLora.version = version_du_message;
messageLora.emetteur = emetteur_du_message;
messageLora.destinataire = destinataire_du_message;
messageLora.relais1 = relais1_du_message;
messageLora.relais2 = relais2_du_message;
messageLora.relais3 = relais3_du_message;
messageLora.numero_du_message = numero_du_message;
messageLora.donnee1 = donnee1_du_message;
messageLora.donnee2 = donnee2_du_message;
messageLora.donnee3 = donnee3_du_message;
messageLora.donnee4 = donnee4_du_message;
messageLora.checksum = checksum_du_message;
*messageLora.text = *text_du_message;
void lecture_du_message()
#ifdef DEBUG_SERIAL
Serial.println("lecture_du_message");
#endif
volatile int packetReceived = 0;
packetReceived = taille_du_message;
LoRa.readBytes((byte *)&messageLora, packetReceived);
header1_du_message = messageLora.header1;
header2_du_message = messageLora.header2;
version_du_message = messageLora.version;
emetteur_du_message = messageLora.emetteur;
// numero_device = hexTodec(String(emetteur_du_message));
numero_device = emetteur_du_message; // Correction le 05/07/26
destinataire_du_message = messageLora.destinataire;
relais1_du_message = messageLora.relais1;
relais2_du_message = messageLora.relais2;
relais3_du_message = messageLora.relais3;
numero_du_message = messageLora.numero_du_message;
type_du_message = messageLora.type_du_message;
donnee1_du_message = messageLora.donnee1;
donnee2_du_message = messageLora.donnee2;
donnee3_du_message = messageLora.donnee3;
donnee4_du_message = messageLora.donnee4;
checksum_du_message = messageLora.checksum;
*text_du_message = *messageLora.text;
#ifdef DEBUG_SERIAL
// display des données reçues
Serial.print("/h1=" + String(header1_du_message) + "/h2/=" + String(header2_du_message) + "/ver=" + String(version_du_message) + "/rel=" + String(relais1_du_message) + "-" + String(relais2_du_message) + "-" + String(relais3_du_message) + "/De=" + String(emetteur_du_message) + "/num dev=" + String(numero_device) + "/A=" + String(destinataire_du_message) + "/Num=" + String(numero_du_message));
Serial.println("/type=" + String(type_du_message) + "/d1=" + String(donnee1_du_message) + "/d2=" + String(donnee2_du_message) + "/d3=" + String(donnee3_du_message) + "/d4=" + String(donnee4_du_message) + "/check=" + String(checksum_du_message) + " text = " + String(text_du_message));
#endif
packetReceived = 0; // clear for next time
void sendMessage() {
LoRa.beginPacket(); // start packet
LoRa.write((byte *)&messageLora, sizeof(messageLora)); // transmit packet
LoRa.endPacket(true); // finish packet and send it
#ifdef DEBUG_SERIAL
Serial.print("Message envoyé : ");
Serial.print("Sent to: 0x" + String(messageLora.destinataire));
Serial.print(" - From: 0x" + String(messageLora.emetteur));
Serial.print(" - Message ID: " + String(messageLora.numero_du_message));
Serial.print("Message: " + *messageLora.text);
//Serial.println("Msg envoyé " + String(msgCount) + " destination= " + String(destination));
#endif
#ifdef DEBUG_OLED
displayOLED(Pas_clear_ecran_OLED, Clear_ligne_OLED, 0, debut_ligne_sent, 1, "Msg sent ", 1);
displayOLED(Pas_clear_ecran_OLED, Clear_ligne_OLED, 0, debut_ligne_sent + increment_ligne * 1, 1, "De=" + String(messageLora.emetteur) + "/A=" + String(messageLora.destinataire), 1);
displayOLED(Pas_clear_ecran_OLED, Clear_ligne_OLED, 0, debut_ligne_sent + increment_ligne * 2, 1, "Num=" + String(messageLora.numero_du_message), 1);
#endif
void displayOLED(int clearEcran, int ClearLigne, int positionHorizontale, int positionVerticale, int tailleText, String messageText, int couleur)
// Affichage OLED
if (clearEcran == 1) {
display.clearDisplay();
if (ClearLigne == 1)
nettoyage_ligne_OLED(positionVerticale, couleur);
display.setTextColor(couleur);
display.setTextSize(tailleText);
display.setCursor(positionHorizontale, positionVerticale);
display.print(messageText);
display.display();
#endif
void nettoyage_ligne_OLED(int ligne_a_nettoyer, int couleur_ligne)
const int largeur_ecran = 127;
const int hauteur_d_une_ligne = 7;
int couleur_inverse = 0;
if (couleur_ligne == 1)
if (couleur_ligne == 0)
couleur_inverse = 1;
for (int h = ligne_a_nettoyer; h < ligne_a_nettoyer + hauteur_d_une_ligne; h++) {
for (int l = 0; l < largeur_ecran; l++) {
display.drawPixel(l, h, couleur_inverse);
#endif
void onGdonnee1OUTChange() {
// Add your code here to act upon GFDdonnee1OUT change
void onGdonnee2OUTChange() {
// Add your code here to act upon GFDdonnee2OUT change
void onGdonnee3OUTChange() { // 29/12/2024
// Add your code here to act upon GFDdonnee3OUT change
void onGdonnee4OUTChange() { // 29/12/2024
// Add your code here to act upon GFDdonnee4OUT change
void onGcapteurIDOUTChange() {
// Add your code here to act upon GFDcapteurIDOUT change
void onGdonneeMAJOUTChange() {
// Add your code here to act upon GFDdonneeMAJOUT change
#endif
