Hello All
This code is being run on 1 of 10 arduinos, controlling 320 relays on a Monster Truck.
The standard code takes input from Vixen 3 (Light Control Software) via serial, and does the relevant outputs.
Additionally on this particular arduino I need two additional functions, and I suck at writing additional code, as I'm an auto sparky by trade.
Feature 1:) If serial data is coming in, turn output on. (used for status monitor in cab)
Feature 2:) If input is high, turn output on. (These are used for manual overrides for work lighting / strobes etc whilst not in show mode). I am taking 12v inputs down to 5v using an optoisolator board to sense the input. eBay Link to Optoisolators
The code base has been borrowed from DIY Christmas forum and works perfectly. I've initialled my edits in the comments with DS.
I'm not going to lie, I've tried reading various pages and guides and coming up blank. Can someone help me out.
cheers
// This code was written by Victor Perez for doityourselfchristmas.com based on the code from Zparticle, Si_champion and Neil Tapp.
// To adapt the code to your case, just change this top section, with the #define lines.
// Includes the watchdog timer library
#include <avr/wdt.h>
// This sets how many channels will vixen be sending. Can be set to any number from 1 to 48 for Arduino Mega, and 1 to 18 for Arduino Uno.
#define CHANNEL_COUNT 32
// speed for the com port for talking with vixen. From 9600 to 115200. Use the same speed as set in Vixen.
#define VIXEN_COM_SPEED 57600
// Timeout waiting for serial input before going to random mode (in milliseconds).
#define TIME_OUT 1000
// If the relays turn On and Off opposite to Vixen sequence, change "#define MODE NOT_INVERTED" for "#define MODE INVERTED"
#define NOT_INVERTED 0
#define INVERTED 1
// which pins control which channels
// You can change these assignment to use different pins, but be very careful to not repeat the same pin number for 2 channels.
// DO NOT use pings 0 and 1, as those are for the serial port to talk to the computer.
#define CH01 22
#define CH02 23
#define CH03 24
#define CH04 25
#define CH05 26
#define CH06 27
#define CH07 28
#define CH08 29
#define CH09 30
#define CH10 31
#define CH11 32
#define CH12 33
#define CH13 34
#define CH14 35
#define CH15 36
#define CH16 37
#define CH17 38
#define CH18 39
// Up to here for Arduino uno.
#define CH19 40
#define CH20 41
#define CH21 42
#define CH22 43
#define CH23 44
#define CH24 45
#define CH25 46
#define CH26 47
#define CH27 48
#define CH28 49
#define CH29 50
#define CH30 51
#define CH31 52
#define CH32 53
int channels[] = {CH01,CH02,CH03,CH04,CH05 ,CH06,CH07,CH08,CH09,
CH10,CH11,CH12,CH13,CH14,CH15,CH16,CH17,CH18,CH19,CH20,CH21,CH22,
CH23,CH24,CH25,CH26,CH27,CH28,CH29,CH30,CH31,CH32};
int incomingByte[CHANNEL_COUNT];
int i = 0; // Loop counter
volatile unsigned long timer_a = 0; // new line
//setup the pins/ inputs & outputs
void setup(){
// enable the watchdog timer with a time of 1 second. If the board freezes, it will reset itself after 1 second.
wdt_enable(WDTO_1S);
// specifically for the UNO
sei();
// initalize PWM Channels / Pins
for (i=0; i < CHANNEL_COUNT; i++){
pinMode(channels[i], OUTPUT);
// DS ATTEMPTING TO SETUP INPUT PIN MODES
pinMode(2, INPUT); // SWITCHING OUTPUT PIN 33
pinMode(3, INPUT); // SWITCHING OUTPUT PIN 34
pinMode(4, INPUT); // SWITCHING OUTPUT PIN 35
pinMode(5, INPUT); // SWITCHING OUTPUT PIN 36
pinMode(6, INPUT); // SWITCHING OUTPUT PIN 37
pinMode(7, INPUT); // SWITCHING OUTPUT PIN 38
pinMode(8, INPUT); // SWITCHING OUTPUT PIN 30
pinMode(9, INPUT); // SWITCHING OUTPUT PIN 31&32
// set all the realys to off to start with
if (MODE == NOT_INVERTED) {
digitalWrite(channels[i], LOW);
else {
digitalWrite(channels[i], HIGH);
testSequence();
// set up Serial according to the speed defined above.
Serial.begin(VIXEN_COM_SPEED);
if (Serial.available() >= (CHANNEL_COUNT+2)) {
wdt_reset(); // resets the watchdog
timer_a = millis (); // new line
int uno = Serial.read();
if (uno == 126){
int dos = Serial.read();
if (dos == 33){
for (i=0; i < CHANNEL_COUNT; i++) {
// read each byte
incomingByte[i] = Serial.read();
int value = incomingByte[i];
if (value <= 127) {
else {
else {
if (value < 127) {
else {
// DS Setting Switch modes for output. Additional lines for other switches needing added.
if (digitalRead(8) == HIGH)
{digitalWrite(30, LOW);
//DS Setting relay output for Green indicator
digitalWrite (channels[CH16], LOW); }
// Random mode code. Random mode starts if no serial input has been received in TIME_OUT millisenconds
else {
unsigned long diff = millis() - timer_a;
if (diff >= TIME_OUT) {
int random_a = 0;
random_a = random(0, 2);
if (random_a == 0) {
else {
void testSequence(){
delay (500);
else {
delay (500);
