CmdMessenger and a 48 item array
hey people,
i've been working on an interface for 3 TLC5940s using Max and CmdMessenger (aka messenger, simplemessagesystem)
I finally got it working to the point of taking full advantage of the 12 bit duty cycle of a general red green and blue variables, but now I'm looking to expand to a full 48 (16 RGB) channel control system.
A switch statement took care of parsing and atoi for those 3 variables from the earlier sketch, but now that i've upsized nothing seems to happen. everything on the max side is fine, but I think I'm missing something from my sketch.
I'm using ben's callback method only, I'm pretty positive it's from the buffer length, but i have no clue what to put it at for the number of bytes I need to parse.
void bens_msg()
  int seq;
  long value;
  // Message data is any ASCII bytes (0-255 value). But can't contain the field
  // separator, command separator chars you decide (eg ',' and ';')
  cmdMessenger.sendCmd(kACK,"bens cmd recieved");
  for (seq = 0; cmdMessenger.available(); seq ++ )
    char buf[64] = { '\0' };
    cmdMessenger.copyString(buf, 350);
    if(buf[0])
      cmdMessenger.sendCmd(kACK, buf);
    value = strtol(buf, NULL, 10);
    switch (seq) {
         case 0:
               r1 = value;
         case 1:
               g1 = value;
         case 2:
               b1 = value;
         case 3:
               r2 = value;
         case 4:
               g2 = value;
         case 5:
               b2 = value;
         case 6:
               r3 = value;
         case 7:
               g3 = value;
         case 8:
               b3 = value;
         case 9:
               r4 = value;
         case 10:
               g4 = value;
         case 11:
               b4 = value;
         case 12:
               r5 = value;
         case 13:
               g5 = value;
         case 14:
               b5 = value;
         case 15:
               r6 = value;
         case 16:
               g6 = value;
         case 17:
               b6 = value;
         case 18:
               r7 = value;
         case 19:
               g7 = value;
         case 20:
               b7 = value;
         case 21:
               r8 = value;
         case 22:
               g8 = value;
         case 23:
               b8 = value;
         case 24:
               r9 = value;
         case 25:
               g9 = value;
         case 26:
               b9 = value;
         case 27:
               r10 = value;
         case 28:
               g10 = value;
         case 29:
               b10 = value;
         case 30:
               r11 = value;
         case 31:
               g11 = value;
         case 32:
               b11 = value;
         case 33:
               r12 = value;
         case 34:
               g12 = value;
         case 35:
               b12 = value;
         case 36:
               r13 = value;
         case 37:
               g13 = value;
         case 38:
               b13 = value;
         case 39:
               r14 = value;
         case 40:
               g14 = value;
         case 41:
               b14 = value;
         case 42:
               r15 = value;
         case 43:
               g15 = value;
         case 44:
               b15 = value;
         case 45:
               r16 = value;
         case 46:
               g16 = value;
         case 47:
               b16 = value;
everything compiles fine btw.
best,
zeef
also, at most the packet I would be sending would be 240 bytes (4 bytes per value with one after each for delimiters on 48 values)
somehow a giant switch statement doesn't seem like the most efficient way to go about this.
You don't show what your r, g and b variables are but I would suggest an array of them so that entire switch is more like
byte myRGBarray[48*3];
myRGBarray [seq] = value;
Rob
From messenger.h:
#define MESSENGERBUFFERSIZE 64
private:
  char buffer[MESSENGERBUFFERSIZE]; // Buffer that holds the data
So, no, the maximum packet size you send will not be 240 bytes.
alas. thanks for pointing that out.
would changing that number be a bad idea? should I find some way to split the message and re-combine?
I've tried some different solutions using an array with strtok but i get serial freezes (unresponsiveness) even on a much simplified set of data. such is not the case with cmdMessenger.
i've looked around the forum but I can't find a similar example of PC-Arduino communication with as many values. If someone could point me to one / show me a bit a path to follow i'd be very appreciative.
I think you do need to find a way to split the message. I don't though, see a need to re-combine them. Send however many values fit a 64 byte message, with a message number. Based on the message number, the values go somewhere in the array.
