Command Line Interface CLI
I made a simple "command line interface" through the USB port.
I would be interested to see if anyone has any other ideas. Uses Messenger.h
#include <Messenger.h>
#define MAX_CL_SIZE  9 //max command line interface size in # of bytes -1 for null char
#define PIN_LED 13 //led pin
Messenger message = Messenger(); // Instantiate Messenger object with the default separator (the space character)
  // Initiate Serial Communication
  // Attach the callback function to the Messenger
  message.attach(messageReady);
  char serialInByte;
  while (Serial.available()) {
    serialInByte = Serial.read ();
    if (serialInByte == '\r')  //if enter (carraige return) was pressed
      Serial.println('\0');
      Serial.print(serialInByte,BYTE);  //echo data back
    message.process(serialInByte);  //process with messenger library
// Create the callback function
void messageReady() {
  char commandIn[MAX_CL_SIZE];
  int parameterIn;
  // Loop through all the available elements of the message
  while (message.available() ) {
    message.copyString(commandIn, MAX_CL_SIZE);
    parameterIn = message.readInt();
  if(!processUserCommand(commandIn, parameterIn))
    Serial.println("Syntax Error");
  Serial.print("> ");
  return;
bool processUserCommand(char command[MAX_CL_SIZE], int parameter) {
  if (!strcmp(command, "nocommand"))
    cmdNoCommand();
  else if (!strcmp(command, "blinkled"))
    cmdBlinkLed(parameter);
  else if (!strcmp(command, "setled"))
    cmdSetLed(parameter);
    return false; //error
  return true;
void cmdNoCommand() {
  return;
void cmdBlinkLed(int blinkNumber) {
  for (int i = 0; i < blinkNumber; i++)
    setStatusLed(255);
    delay(250);
    setStatusLed(0);
    delay(250);
  return;
void cmdSetLed(int brightness) {
  setStatusLed(brightness);
  return;
void setStatusLed(int brightness) {
  pinMode(PIN_LED, OUTPUT);
  analogWrite(PIN_LED, brightness);
  return;
Nice work - reinventing the wheel gives usually a much better understanding of the wheel then buying it of the shelf. Anyway in case you want to look at the already invented wheels:
http://www.arduino.cc/playground/Interfacing/Firmata
http://biot.com/arsh/
http://blog.makezine.com/archive/2008/10/breakfast_arduino_shell.html
I think somewhere was a thread with a comparison of these shells.
May I also mention Bitlash?
-br :slight_smile:
I know I forgot at least one :wink:
