CNC Shield + Servomotor using Z+
Hello Community,
I'm trying to connect a servomotor on Z+ pin of CNC Shield but is not working.
I'm very new with arduino/cnc and I don't know what I'm doing wrong. I tried to find the answer on internet but seems that everyone is using GRBL. I will have four stepper motors in my project (X will be duplicated)
This is my code:
#include<Servo.h>
const int StepX = 2;
const int DirX = 5;
const int StepY = 3;
const int DirY = 6;
const int StepZ = 4;
const int DirZ = 7;
const int speed= 1300;
int currentStepX =0;
int currentStepY =0;
int currentStepZ =0;
//servo settings
Servo myservo;
const byte servoPin = 11; // Z+
byte pos = 0;
  Serial.begin(9600); // for monitor log.
  pinMode(StepX,OUTPUT);
  pinMode(DirX,OUTPUT);
  pinMode(StepY,OUTPUT);
  pinMode(DirY,OUTPUT);
 pinMode(StepZ,OUTPUT);
  pinMode( DirZ,OUTPUT);
 myservo.attach(11);
 myservo.write(0);
   myservo.write(180);
Thanks in advance,
Adrian
A RC-servo is not a stepper. You need +5V and GND, too. And make that delay(3000). ANd doublechack if your servo is on pin 11 or 7.
Thanks for your quick reply. Yes, I have +5V and GND from external power supply. I'm sorry that I didn't included it in my image. How can I check if servo is on pin 11 or 7? I used the same code in Arduino uno (without CNC) and servo is working as expected.
What's the pin schematics for the board? I don't have it available at the moment but other helpers have been posting it here in the past.
Yes but as @zwieblum has pointed out
The electronics in the CNC Shield are designed to drive stepping motors, so comes as no surprise that it can not drive servo.
I think that CNC shield should be able to drive also servo motors as we have multiple colleagues on this forum that are doing this, see:
CNC Shield V3 Servo Problem - Using Arduino / Motors, Mechanics, Power and CNC - Arduino Forum
Servo motor problem - Using Arduino / Motors, Mechanics, Power and CNC - Arduino Forum
DIY Pen Plotter with Automatic Tool Changer | Arduino based CNC Drawing Machine (youtube.com)
CNC Schema
My electronic schema is
Thanks, I uploaded the CNC pin schema if you have time to take a look, I will appreciate
You have to connect servo GND and arduino GND
An absolute mess and not a schematic at all.
Hi @Grumpy_Mike , I made that schema in paint.. consider that C1-C4 modules are busy with steeper motors and I want to connect to Z+ the signal wire (in orange) for a servomotor. I have an external power supplier for + in red and - in brown. I also tried to use CNC shiet for + and - but still is not working. Please let me know if you have any doubts.
as written above: you must connect servo GND to arduino GND
Thanks you all for your input. Seems that the problem is my power supplier which is too small...
