CNC shield with A4988 and MEGA 2560
This is working stand alone but still don't work included in a much bigger sketch. 700mV for the current control. I have heatseanks and active cooling.
// Define some steppers and the pins the will use
define EN 8 // stepper motor enable , active low
define X_DIR 5 // X -axis stepper motor direction control
define Y_DIR 6 // y -axis stepper motor direction control
define Z_DIR 7 // z axis stepper motor direction control
define X_STP 2 // x -axis stepper control
define Y_STP 3 // y -axis stepper control
define Z_STP 4 // z -axis stepper control
// Function : step . function: to control the direction of the stepper motor , the number of steps .
// Parameters : dir direction control , dirPin corresponding stepper motor DIR pin , stepperPin corresponding stepper motor " step " pin , Step number of step of no return value.
void stepX (boolean dir, byte dirPin, byte stepperPin, int steps, int steplength)
digitalWrite (dirPin, dir);
delay (500);
for (int i = 0; i <steps; i++)
digitalWrite (stepperPin, HIGH);
delayMicroseconds (steplength);
digitalWrite (stepperPin, LOW);
delayMicroseconds (800);
void stepY (boolean dir, byte dirPin, byte stepperPin, int steps, int steplength)
delay (1000);
for (int j = 0; j <steps; j++)
delayMicroseconds (2000);
void stepZ (boolean dir, byte dirPin, byte stepperPin, int steps, int steplength)
delay (500);
for (int z = 0; z <steps; z++)
// The stepper motor used in the IO pin is set to output
pinMode (X_DIR, OUTPUT); pinMode (X_STP, OUTPUT);
pinMode (Y_DIR, OUTPUT); pinMode (Y_STP, OUTPUT);
pinMode (Z_DIR, OUTPUT); pinMode (Z_STP, OUTPUT);
pinMode (EN, OUTPUT);
digitalWrite (EN, LOW);
stepX (true, X_DIR, X_STP, 400, 800); // X axis motor reverse 1 ring, the 200 step is a circle.
stepY (true, Y_DIR, Y_STP, 400, 3000); // y axis motor reverse 1 ring, the 200 step is a circle.
stepZ (true, Z_DIR, Z_STP, 400, 800); // z axis motor reverse 1 ring, the 200 step is a circle.
delay(5000);
stepX (false, X_DIR, X_STP, 400, 800); // X axis motor reverse 1 ring, the 200 step is a circle.
stepY (false, Y_DIR, Y_STP, 400, 3000); // y axis motor reverse 1 ring, the 200 step is a circle.
stepZ (false, Z_DIR, Z_STP, 400, 800); // z axis motor reverse 1 ring, the 200 step is a circle.
delay(5000);
