I am using a CNC Shield as pictured below with a DRV8825 driver attached.
I tuned the current limiter on the DRV8825 to about .2A as specified by my motor's spec sheet.
When I turn on the 12V power supply, the motor makes a beeping sound but does not move.
I am currently using no jumpers and am on standard stepping (no microstepping).
I know this motor works because I have a different driver that it will work on but makes quite a lot of noise with, hence the reason I am trying the CNC shield with DRV8825.
Thank you for setting me on the right track with the delay time. Seems this driver has a much different delay time that will make it move.
I settled on a range of delayMicroseconds(1000) - delayMicroseconds(450).
There is one caveat however: To make the motor move at all fast I had to tune the DRV8825's current limiter much higher than the spec sheet said to do.
Spec sheet says .2A, but I had to increase the DRV8825 limiter to .21VDC (which means the current limiter is .42A).
AndrewKamp:
Sorry, but that does not make sense. And you have not answered my question about what other driver you were using.
The setting depends on the value of the current-sense resistor. Maybe the module you have has a different resistor? The Pololu DRV8825 web page has a lot of info about setting the current limit and other things.
