Code breaker build 911!
Need help on a code breaker puzzle build for A Geocache project, setup and running code successfully however screen isn't showing correctly
Link to screen
HiLetgo 1.3" IIC I2C Serial 128x64 SSH1106 SSD1306 OLED LCD Display LCD Module for Arduino AVR PIC STM32 Amazon.com: HiLetgo 1.3" IIC I2C Serial 128x64 SSH1106 SSD1306 OLED LCD Display LCD Module for Arduino AVR PIC STM32 : Electronics
Running on
ELEGOO uno R3
//Code Breaker
//Michael Klements
//The DIY Life
//15 May 2020
//Encoder interrupt routine adapted from Simon Merrett's example code
#include <SPI.h>                          //Import libraries to control the OLED display
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <Servo.h>                        //Import library to control the servo
Servo lockServo;                          //Create a servo object for the lock servo
#define SCREEN_WIDTH 128                  // OLED display width, in pixels
#define SCREEN_HEIGHT 32                  // OLED display height, in pixels
#define OLED_RESET -1                     // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);   // Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
static int pinA = 2;                      //Hardware interrupt digital pin 2
static int pinB = 3;                      //Hardware interrupt digital pin 3
volatile byte aFlag = 0;                  //Rising edge on pinA to signal that the encoder has arrived at a detent
volatile byte bFlag = 0;                  //Rising edge on pinB to signal that the encoder has arrived at a detent (opposite direction to when aFlag is set)
volatile byte encoderPos = 0;             //Current value of encoder position, digit being input form 0 to 9
volatile byte prevEncoderPos = 0;         //To track whether the encoder has been turned and the display needs to update
volatile byte reading = 0;                //Stores direct value from interrupt pin
const byte buttonPin = 4;                 //Pin number for encoder push button
byte oldButtonState = HIGH;               //First button state is open because of pull-up resistor
const unsigned long debounceTime = 10;    //Debounce delay time
unsigned long buttonPressTime;            //Time button has been pressed for debounce
byte correctNumLEDs[4] = {9,12,7,11};      //Pin numbers for correct number LEDs (Indicate a correct digit)
byte correctPlaceLEDs[4] = {6,10,8,13};    //Pin numbers for correct place LEDs (Indicate a correct digit in the correct place)
byte code[4] = {0,0,0,0};                  //Create an array to store the code digits
byte codeGuess[4] = {0,0,0,0};             //Create an array to store the guessed code digits
byte guessingDigit = 0;                    //Tracks the current digit being guessed
byte numGuesses = 0;                       //Tracks how many guesses it takes to crack the code
boolean correctGuess = true;               //Variable to check whether the code has been guessed correctly, true initially to generate a new code on startup
  Serial.begin(9600);                                 //Starts the Serial monitor for debugging
  if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3C))      //Connect to the OLED display
    Serial.println(F("SSD1306 allocation failed"));   //If connection fails
    for(;;);                                          //Don't proceed, loop forever
  display.clearDisplay();                             //Clear display
  lockServo.attach(5);                                //Assign the lock servo to pin 5
  for(int i=0 ; i<=3 ; i++)                           //Define pin modes for the LEDs
    pinMode(correctNumLEDs[i], OUTPUT);
    pinMode(correctPlaceLEDs[i], OUTPUT);
  pinMode(pinA, INPUT_PULLUP);                        //Set pinA as an input, pulled HIGH to the logic voltage
  pinMode(pinB, INPUT_PULLUP);                        //Set pinB as an input, pulled HIGH to the logic voltage
  attachInterrupt(0,PinA,RISING);                     //Set an interrupt on PinA
  attachInterrupt(1,PinB,RISING);                     //Set an interrupt on PinB
  pinMode (buttonPin, INPUT_PULLUP);                  //Set the encoder button as an input, pulled HIGH to the logic voltage
  randomSeed(analogRead(0));                          //Randomly choose a starting point for the random function, otherwise code pattern is predictable
  display.setTextColor(SSD1306_WHITE);                //Set the text colour to white
  startupAni();                                       //Display the startup animation
  if(correctGuess)                                            //Code between games to reset if the guess is correct, initially true to open safe and then generate new code
    lockServo.write(140);                                     //Unlock the safe
    delay(300);
    updateLEDs (0,4);                                         //Flashing LED sequence
    delay(300);
    updateLEDs (4,0);
    delay(300);
    updateLEDs (0,4);
    delay(300);
    updateLEDs (4,0);
    delay(300);
    updateLEDs (4,4);                                         //Turn all LEDs on
    if(numGuesses >= 1)                                       //Check that its not the start of the game
      display.clearDisplay();                                 //Clear the display
      display.setTextSize(1);                                 //Set the display text size to small
      display.setCursor(35,10);                               //Set the display cursor position
      display.print(F("In "));                                //Set the display text
      display.print(numGuesses);                              //Set the display text
      display.setCursor(35,20);                               //Set the display cursor position
      display.print(F("Attempts"));                           //Set the display text
      display.display();                                      //Output the display text
      delay(5000);
    display.print(F("Push To"));                              //Set the display text
    display.print(F("Lock Safe"));                            //Set the display text
    display.setTextSize(2);                                   //Set the display text size back to large
    boolean lock = false;                                     //Safe is initially not locked
    boolean pressed = false;                                  //Keeps track of button press
    while(!lock)                                              //While button is not pressed, wait for it to be pressed
      byte buttonState = digitalRead (buttonPin);
      if (buttonState != oldButtonState)
        if (millis () - buttonPressTime >= debounceTime)      //Debounce button
          buttonPressTime = millis ();                        //Time when button is pressed
          oldButtonState =  buttonState;                      //Remember button state
          if (buttonState == LOW)
            pressed = true;                                   //Records button has been pressed
            if (pressed == true)                              //Makes sure that button is pressed and then released before continuing in the code
              lockServo.write(45);                            //Lock the safe
              display.setCursor(30,10);                       //Set the display cursor position
              display.print(F("Locked"));                     //Set the display text
              lock = true;
    generateNewCode();                                        //Calls function to generate a new random code
    updateLEDs (0,0);
    correctGuess = false;                                     //The code guess is initially set to incorrect
    numGuesses = 0;                                           //Reset the number of guesses counter
  inputCodeGuess();                                           //Calls function to allow the user to input a guess
  numGuesses++;                                               //Increment the guess counter
  checkCodeGuess();                                           //Calls function to check the input guess
  encoderPos = 0;                                             //Reset the encoder position
  guessingDigit = 0;                                          //Reset the digit being guessed
  codeGuess[0] = 0;                                           //Reset the first digit of the code
  updateDisplayCode();                                        //Update the displayed code
void updateDisplayCode()                                      //Function to update the display with the input code
  String temp = "";                                           //Temporary variable to concatenate the code string
  if(!correctGuess)                                           //If the guess is not correct then update the display
    for (int i=0 ; i<guessingDigit ; i++)                     //Loops through the four digits to display them
      temp = temp + codeGuess[i];
    temp = temp + encoderPos;
    for (int i=guessingDigit+1 ; i<=3 ; i++)
      temp = temp + "0";
    Serial.println(temp);                                     //Output to Serial monitor for debugging
    display.setCursor(40,10);                                 //Set the display cursor position
    display.println(temp);                                    //Set the display text
    display.display();                                        //Update the display
void generateNewCode()                                        //Function to generate a new random code
  Serial.print("Code: ");
  for (int i=0 ; i<= 3 ; i++)                                 //Loops through the four digits and assigns a random number to each
    code[i] = random(0,9);                                    //Generate a random number for each digit
    Serial.print(code[i]);                                    //Display the code on Serial monitor for debugging
void inputCodeGuess()                                         //Function to allow the user to input a guess
  for(int i=0 ; i<=3 ; i++)                                   //User must guess all four digits
    guessingDigit = i;
    boolean confirmed = false;                                //Both used to confirm button push to assign a digit to the guess code
    encoderPos = 0;                                           //Encoder starts from 0 for each digit
    while(!confirmed)                                         //While the user has not confirmed the digit input
          buttonPressTime = millis ();                        //Time when button was pushed
          oldButtonState =  buttonState;                      //Remember button state for next time
            codeGuess[i] = encoderPos;                        //If the button is pressed, accept the current digit into the guessed code
            pressed = true;
            if (pressed == true)                              //Confirm the input once the button is released again
              updateDisplayCode();                            //Update the code being displayed
              confirmed = true;
      if(encoderPos!=prevEncoderPos)                          //Update the displayed code if the encoder position has changed
        prevEncoderPos=encoderPos;
void checkCodeGuess()                                         //Function to check the users guess against the generated code
  int correctNum = 0;                                         //Variable for the number of correct digits in the wrong place
  int correctPlace = 0;                                       //Variable for the number of correct digits in the correct place
  int usedDigits[4] = {0,0,0,0};                              //Mark off digits which have been already identified in the wrong place, avoids counting repeated digits twice
  for (int i=0 ; i<= 3 ; i++)                                 //Loop through the four digits in the guessed code
    for (int j=0 ; j<=3 ; j++)                                //Loop through the four digits in the generated code
      if (codeGuess[i]==code[j])                              //If a number is found to match
        if(usedDigits[j]!=1)                                  //Check that it hasn't been previously identified
          correctNum++;                                       //Increment the correct digits in the wrong place counter
          usedDigits[j] = 1;                                  //Mark off the digit as been identified
          break;                                              //Stop looking once the digit is found
  for (int i=0 ; i<= 3 ; i++)                                 //Compares the guess digits to the code digits for correct digits in correct place
    if (codeGuess[i]==code[i])                                //If a correct digit in the correct place is found
      correctPlace++;                                         //Increment the correct place counter
  updateLEDs(correctNum, correctPlace);                        //Calls a function to update the LEDs to reflect the guess
  if(correctPlace==4)                                          //If all 4 digits are correct then the code has been cracked
    display.setCursor(20,10);                                  //Set the display cursor position
    display.print(F("Cracked"));                               //Set the display text
void updateLEDs (int corNum, int corPla)                        //Function to update the LEDs to reflect the guess
  for(int i=0 ; i<=3 ; i++)                                     //First turn all LEDs off
    digitalWrite(correctNumLEDs[i], LOW);
    digitalWrite(correctPlaceLEDs[i], LOW);
  for(int j=0 ; j<=corNum-1 ; j++)                              //Turn on the number of correct digits in wrong place LEDs
    digitalWrite(correctNumLEDs[j], HIGH);
  for(int k=0 ; k<=corPla-1 ; k++)                              //Turn on the number of correct digits in the correct place LEDs
    digitalWrite(correctPlaceLEDs[k], HIGH);
void startupAni ()
  display.println(F("Crack"));                //Set the display text
  display.setCursor(45,10);
  display.println(F("The"));
  display.display();
  display.println(F("Code"));
  display.display();
void PinA()                               //Rotary encoder interrupt service routine for one encoder pin
  cli();                                  //Stop interrupts happening before we read pin values
  reading = PIND & 0xC;                   //Read all eight pin values then strip away all but pinA and pinB's values
  if(reading == B00001100 && aFlag)       //Check that we have both pins at detent (HIGH) and that we are expecting detent on this pin's rising edge
    if(encoderPos>0)
      encoderPos --;                      //Decrement the encoder's position count
      encoderPos = 9;                     //Go back to 9 after 0
    bFlag = 0;                            //Reset flags for the next turn
    aFlag = 0;                            //Reset flags for the next turn
  else if (reading == B00000100)          //Signal that we're expecting pinB to signal the transition to detent from free rotation
    bFlag = 1;
  sei();                                  //Restart interrupts
void PinB()                               //Rotary encoder interrupt service routine for the other encoder pin
  if (reading == B00001100 && bFlag)      //Check that we have both pins at detent (HIGH) and that we are expecting detent on this pin's rising edge
    if(encoderPos<9)
      encoderPos ++;                      //Increment the encoder's position count
      encoderPos = 0;                     //Go back to 0 after 9
  else if (reading == B00001000)          //Signal that we're expecting pinA to signal the transition to detent from free rotation
    aFlag = 1;
  • If this is a SSH1106 OLED, use the library that supports the SSH1106.
Can you rec library and changes to the code? I have tried changing and searching for applicable library but im not doing something properly.
2024-07-26_18-19-29
  • Try this sketch to see if your display works.
Click Here for Code
//  OLED_Counter.ino
//  LarryD
//  Version   YY/MM/DD     Comments
//  1.00      22/04/21     Running code
//https://lastminuteengineers.com/oled-display-arduino-tutorial/
#include <Wire.h>
//#include <Adafruit_GFX.h>
#include <Adafruit_SH110X.h>
/* Uncomment the initialize the I2C address , uncomment only one, If you get a totally blank screen try the other*/
#define i2c_Address 0x3c //initialize with the I2C addr 0x3C Typically eBay OLED's
//#define i2c_Address 0x3d //initialize with the I2C addr 0x3D Typically Adafruit OLED's
const byte heartbeatLED     = 13;
#define SCREEN_WIDTH        128  //OLED display width,  in pixels
#define SCREEN_HEIGHT       64   //OLED display height, in pixels
#define OLED_RESET -1            //QT-PY / XIAO
Adafruit_SH1106G display = Adafruit_SH1106G(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
unsigned long counter       = 0;
//timing stuff
unsigned long heartbeatTime;
unsigned long displayTime;
//                                       s e t u p ( )
  pinMode(heartbeatLED, OUTPUT);
  delay(250); // wait for the OLED to power up
  display.begin(i2c_Address, true); // Address 0x3C default
  //display.display();
  //delay(2000);
  display.setTextColor(SH110X_WHITE);
  display.setCursor(0, 0);
} //END of   setup()
//                                        l o o p ( )
  //*********************************                         heartbeat TIMER
  //is it time to toggle the heartbeatLED (every 500ms)?
  if (millis() - heartbeatTime >= 250ul)
    //restart this TIMER
    heartbeatTime = millis();
    //toggle the heartbeat LED
    digitalWrite(heartbeatLED, digitalRead(heartbeatLED) == HIGH ? LOW : HIGH);
  //*********************************                         displayTime TIMER
  //is time to update the display ?
  if (millis() - displayTime >= 1000ul)
    displayTime = millis();
    //clear SSD1306 display
    //Size 1 line  000000000111111111122
    //21 chars     123456789012345678901
    //Example      ..OLED Counter Demo..
    display.print("  OLED Counter Demo  ");
    //display.setCursor(0,9);
    //Size 1 line is  000000000111111111122
    //21 characters   123456789012345678901
    //display.print ("ABCDEFGHIJKLMNOPQRSTU");
    //2 = current text size, 16 is the pixel row we want to postion to
    display.setCursor(centering(counter, 2), 16);
    //Size 2 line     0000000001
    //10 characters   1234567890
    //Example           100000
    display.print(counter++);
    //degree symbol
    //using CP437 ASCII
    //display.cp437(true);
    //display.write(248);
    //  display.setTextSize(2);
    //  display.setCursor(0,16);
    //  display.setCursor(0,32);
    //  //temperature
    //  //Size 2 line  0000000001
    //  //10 chars     1234567890
    //  //Example      ABCDEFGHIJ
    //  display.print("ABCDEFGHIJ");
    display.display();
  //other non blocking code goes here
} //END of   loop()
//                                 c o u n t D i g i t s ( )
//return the number of digits in a number
byte countDigits(int num)
  byte count = 0;
  while (num)
    num = num / 10;
    count++;
  return count;
} //END of   countDigits()
//                                    g e t D i g i t ( )
//return the selected digit
byte getDigit(unsigned int number, int digit)
  for (int i = 0; i < digit - 1; i++)
    number = number / 10;
  return number % 10;
} //END of   getDigit()
//                                   c e n t e r i n g ( )
//return the position to print the MSD
byte centering(unsigned long number, byte textSize)
  byte count = 0;
  byte charaterCellWidth = 0;
  //a basic character is 5X7, we must scale for this text size
  charaterCellWidth = (5 * textSize) + 1;
  //number of digits in our number
  while (number)
    count++;
  //center location where the MSD character will be displayed
  return (SCREEN_WIDTH / 2 - (charaterCellWidth * count / 2));
} //END of   centering()
YES!!! DEMO COUNTER IS RUNNING!!! at least we know i wired it right lol I also made the adjustments in the code and was able to make it past the define lines all the way down to .begin and then it threw another error and i wasn't able to decipher what i need to adjust but i think im on the right path
Follow up i adjusted my code and larry D you are the man thank you for the help!!
moderator edit: language
