Code cannot be uploaded
Hi, what does this mean and what can I do for now?
Hi @jovincyc0825. This is caused by a bug recently introduced into Arduino Cloud that affects uploading IoT Thing, and dashboards sketches to serial ports of ESP32 and ESP8266 boards. The Arduino Cloud developers are aware of the bug and are already working on a fix. I will report back here if I have any news to share regarding a resolution.
For now, please use Arduino IDE when you need to upload Arduino Cloud IoT Thing sketches to ESP32 and ESP8266 boards via the serial port. You can install support for the ESP8266 boards in Arduino IDE by following these instructions.
You can use the Arduino Cloud sketchbook integration feature of Arduino IDE 2.x to get convenient access to all your Arduino Cloud sketches (including Thing sketches) for use in Arduino IDE:
https://docs.arduino.cc/software/ide-v2/tutorials/ide-v2-cloud-sketch-sync
You can continue to use Arduino Cloud to set up IoT Devices, Things, and dashboards, to write and compile sketches, and to interact with the Thing via dashboards. The only problem is the inability to upload to the board via the serial port. The bug does not occur when using a non-IoT sketch so you can work with non-IoT sketches in Arduino Cloud, including uploading them to ESP32 and ESP8266 boards, just as always.
Hello again @jovincyc0825. The bug that caused Cloud Editor to not recognize the serial ports of ESP32 and ESP8266 boards has now been fixed. I apologize for any inconvenience this has caused you.
There is one remaining problem you should be aware of: if you have multiple Arduino boards (or other devices that produce serial ports) connected to your computer, Cloud Editor might pick the wrong port to use. I have submitted a report about this problem to the developers. For now, please disconnect any additional Arduino boards from your computer before opening an Arduino Cloud IoT Thing sketch in Cloud Editor when using a serial port to upload to the board.
Please give it a try and let us know if you still have any problems.
