Code:
// Enigma Visual version 1.3 dated 03/10/2019 @2110
// written by Mark J Culross, KD5RXT (kd5rxt@arrl.net)
// HARDWARE:
// SparkFun RedBoard - Programmed with Arduino (DEV-13975)
// https://www.sparkfun.com/products/13975
// Adafruit 2.8" TFT Touch Shield for Arduino with Resistive Touch Screen (1651)
// https://www.adafruit.com/product/1651
// Uses touchscreen input & color display to create a visual (graphical) version of the Enigma machine
// Uses the Adafruit Touch Shield V2 library for its display output & touchpad input
// The design of the encode/decode processing in this sketch is based upon the original encode/decode engine from
// the EnigmaSerial.ino sketch (w/ cleanup, optimization, & enhancements, all w/ no apparent adverse effects on
// equivalent/correct operation)
// The versions of the Enigma machine that are simulated in this sketch were verified to operate correctly using
// the excellent/versatile HTML-code utility titled "Universal Enigma Simulator v2.0" by Daniel Palloks
// ( http://people.physik.hu-berlin.de/~palloks/js/enigma/index_en.html )
// See text at the bottom of this file for sample Enigma messages (http://franklinheath.co.uk) for testing/verification
// COMPILER/LIBRARY NOTE:
// If this version is built using older versions of the IDE and/or aome versions of the Adafruit TFT library,
// the resulting compiled code could exceed the available program space. When this version is built with IDE
// version 1.8.7, the resulting code is efficient enough that it fits within the available program space. If
// you find that the available program space is exceeded when this program is built, then simply comment out
// the line "#define SERIAL_MODE" (which appears immediately following this note), essentially removing the
// calls for run-time serial input & output, which should thus avoid exceeding the available program space
// until the IDE and/or Adafruit TFT library can be updated to newer versions. Of course, doing so also
// results in the loss of the otherwise available serial capabiltity for processing Enigma messages & the
// ability to display the intricate details of the internal mechanical operations of the Enigma machine over
// the serial port.
#define SERIAL_MODE
// The following pins are used in this project:
// PIN D2 = (not used)
// PIN D3 = TFT backlight control (optional - solder jumper to activate)
// PIN D4 = microSD chip select
// PIN D5 = (not used)
// PIN D6 = (not used)
// PIN D7 = (not used)
// PIN D8 = Resistive TouchScreen chip select
// PIN D9 = TFT data/command select
// PIN D10 = TFT chip select
// PIN D11 = SPI data pin - used for TFT, microSD, & TouchScreen data/command
// PIN D12 = SPI data pin - used for TFT, microSD, & TouchScreen data/command
// PIN D13 = SPI serial clock pin - used for TFT, microSD, & TouchScreen clock
// PIN A0 = (not used)
// PIN A1 = (not used)
// PIN A2 = (not used)
// PIN A3 = (not used)
// PIN A4 = (not used)
// PIN A5 = (not used)
#include <SPI.h>
#include <Wire.h> // this is needed even though we aren't using it directly
#include <Adafruit_TFTLCD.h>
#include <TouchScreen.h>
#include <Adafruit_GFX.h> // Core graphics library
// This is calibration data for the raw touch data to the screen coordinates
// (NOTE: run the TFTcal-Adafruit.ino sketch to determine the calibration values
// for your specific touchscreen display)
const int TS_MINX = 150;
const int TS_MINY = 200;
const int TS_MAXX = 3830;
const int TS_MAXY = 3750;
// The STMPE610 uses hardware SPI on the shield, and pin #8 for ChipSelect
const int STMPE_CHIP_SELECT = 8;
#define YP A1 // must be an analog pin, use "An" notation!
#define XM A2 // must be an analog pin, use "An" notation!
#define YM 7 // can be a digital pin
#define XP 6 // can be a digital pin
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 350);
// The display also uses hardware SPI, plus pin #9 as DataCommand & pin #10 as ChipSelect
const int TFT_CHIP_SELECT = 10;
const int TFT_DATA_COMMAND = 9;
Adafruit_TFTLCD tft;
// define constant display strings
#define TITLE F(" Visual Simulator ")
#define VERSION0 F(" v1.3 ")
#define VERSION1 F("written by: \n MarkCulross KD5RXT")
#define TAPSTART F("Tap the Enigma touchscreen to begin...")
#define CREDIT1 F(" Many thanks to Daniel Palloks for his\n\n excellent/versatile HTML-code utility\n\n Universal Enigma Simulator v2.0 which\n\n was used to validate proper operation\n\n\n Also, thanks & credit to the authors\n\n of EnigmaSerial, whose encode/decode\n\n engine was used as a model to design\n\n my sketch's encode/decode processing")
#define STARTNOERROR F("Starting...")
// create a universal definition for the internal reference
// (UNO includes standard definition for INTERNAL)
// (MEGA does not have INTERNAL defined, but uses INTERNAL1V1 as same thing)
#ifndef INTERNAL
#define INTERNAL INTERNAL1V1
#endif
//protected?
const int SHADOW_GRAY = 0x1923;
const int DARK_GRAY = 0x29C5;
const int MEDIUM_GRAY = 0x4A89;
const int LIGHT_GRAY = 0x8410;
const int BRASS = 0xBC20;
const int PAPER = 0xFDE7;
const int ORANGE = 0xFC00;
#define STR_EXPAND(tok) #tok
#define STR(tok) STR_EXPAND(tok)
typedef enum
USE_ROTOR_NONE=0, USE_ROTOR_ETW, USE_ROTOR_1, USE_ROTOR_2, USE_ROTOR_3, USE_ROTOR_4, USE_ROTOR_5, USE_ROTOR_6, USE_ROTOR_7, USE_ROTOR_8,
USE_ROTOR_UKWA, USE_ROTOR_UKWB, USE_ROTOR_UKWC, USE_ROTOR_B, USE_ROTOR_G, USE_ROTOR_UKWBD, USE_ROTOR_UKWCD,
USE_ROTOR_ETWD, USE_ROTOR_D1, USE_ROTOR_D2, USE_ROTOR_D3, USE_ROTOR_UKWD,
USE_ROTOR_ETWR, USE_ROTOR_R1, USE_ROTOR_R2, USE_ROTOR_R3, USE_ROTOR_UKWR,
USE_ROTOR_ETWS, USE_ROTOR_S1, USE_ROTOR_S2, USE_ROTOR_S3, USE_ROTOR_UKWS,
} ROTORS;
typedef enum
MACHINE_TYPE_M3=0, // Standard model Enigma M3
MACHINE_TYPE_M4, // Standard model Enigma M4
MACHINE_TYPE_ENIGMA_D, // Business model Enigma D
MACHINE_TYPE_ROCKET_K, // Enigma Rocket K Railway
MACHINE_TYPE_SWISS_K // Enigma Swiss K
} MACHINE_TYPE;
typedef enum
CONFIG_M3_1939 = 0,
CONFIG_EXAMPLE_1930,
CONFIG_ENIGMA_D,
CONFIG_ROCKET_K_RAILWAY,
CONFIG_SWISS_K,
CONFIG_TURING_1940,
CONFIG_BARBAROSA_1941,
CONFIG_M4_1942,
CONFIG_U264_1942,
CONFIG_SCHARNHORST_1943
} CONFIG;
int config_setup = CONFIG_M3_1939;
// Rotor definitions, first two letters are the letter at which they rotate the one to the left,
// the rest are the output given an input letter
// Standard Enigma - rotor definitions from Crypto Museum
// ABCDEFGHIJKLMNOPQRSTUVWXYZ
#define ETW --ABCDEFGHIJKLMNOPQRSTUVWXYZ
#define ROTOR1 R-EKMFLGDQVZNTOWYHXUSPAIBRCJ
#define ROTOR2 F-AJDKSIRUXBLHWTMCQGZNPYFVOE
#define ROTOR3 W-BDFHJLCPRTXVZNYEIWGAKMUSQO
#define ROTOR4 K-ESOVPZJAYQUIRHXLNFTGKDCMWB
#define ROTOR5 A-VZBRGITYUPSDNHLXAWMJQOFECK
#define ROTOR6 ANJPGVOUMFYQBENHZRDKASXLICTW
#define ROTOR7 ANNZJHGRCXMYSWBOUFAIVLPEKQDT
#define ROTOR8 ANFKQHTLXOCBJSPDZRAMEWNIUYGV
#define UKWA --EJMZALYXVBWFCRQUONTSPIKHGD
#define UKWB --YRUHQSLDPXNGOKMIEBFZCWVJAT
#define UKWC --FVPJIAOYEDRZXWGCTKUQSBNMHL
#define ROTORB --LEYJVCNIXWPBQMDRTAKZGFUHOS
#define ROTORG --FSOKANUERHMBTIYCWLQPZXVGJD
#define UKWBD --ENKQAUYWJICOPBLMDXZVFTHRGS
#define UKWCD --RDOBJNTKVEHMLFCWZAXGYIPSUQ
// Business Enigma D - rotor definitions from Universal Enigma Simulator by Daniel Palloks
#define ETWD --JWULCMNOHPQZYXIRADKEGVBTSF
#define ROTORD1 Z-LPGSZMHAEOQKVXRFYBUTNICJDW
#define ROTORD2 F-SLVGBTFXJQOHEWIRZYAMKPCNDU
#define ROTORD3 O-CJGDPSHKTURAWZXFMYNQOBVLIE
#define UKWD --IMETCGFRAYSQBZXWLHKDVUPOJN
// German Rocket K Railway - rotor definitions from Universal Enigma Simulator by Daniel Palloks
#define ETWR --JWULCMNOHPQZYXIRADKEGVBTSF
#define ROTORR1 O-JGDQOXUSCAMIFRVTPNEWKBLZYH
#define ROTORR2 F-NTZPSFBOKMWRCJDIVLAEYUXHGQ
#define ROTORR3 Z-JVIUBHTCDYAKEQZPOSGXNRMWFL
#define UKWR --QYHOGNECVPUZTFDJAXWMKISRBL
// Swiss K - rotor definitions from Universal Enigma Simulator by Daniel Palloks
#define ETWS --JWULCMNOHPQZYXIRADKEGVBTSF
#define ROTORS1 O-PEZUOHXSCVFMTBGLRINQJWAYDK
#define ROTORS2 F-ZOUESYDKFWPCIQXHMVBLGNJRAT
#define ROTORS3 Z-EHRVXGAOBQUSIMZFLYNWKTPDJC
#define UKWS --IMETCGFRAYSQBZXWLHKDVUPOJN
static const __FlashStringHelper * WHEELSF;
const __FlashStringHelper * LOGOX1;
const __FlashStringHelper * LOGOX2;
char EffSTECKER[] = "ABCDEFGHIJKLMNOPQRSTUVWXYZ";
char KeyPressed = 0;
char EncodedKey = 0;
boolean SerialRead = false;
typedef struct
MACHINE_TYPE machine_type;
char STECKER[27];
byte WHEELTYPE[6]; // WHEELTYPE[0] REPRESENTS ENTRY CONTACTS (ETW)
// WHEELTYPE[1] REPRESENTS RIGHT ROTOR (NOTE THE REVERSED ORDER VS THE OTHER ARRAYS !!)
// WHEELTYPE[2] REPRESENTS MIDDLE ROTOR (NOTE THE REVERSED ORDER VS THE OTHER ARRAYS !!)
// WHEELTYPE[3] REPRESENTS LEFT ROTOR (NOTE THE REVERSED ORDER VS THE OTHER ARRAYS !!)
// WHEELTYPE[4] REPRESENTS ADDITIONAL WHEEL (M4 ONLY, OTHERWISE USE_ROTOR_NONE)
// WHEELTYPE[5] REPRESENTS REFLECTOR (UKW)
byte WHEELPOS[4]; // WHEELPOS[0] REPRESENTS LEFTMOST LETTER, ONLY ON M4, OTHERWISE UKW ON ROCKET, D, & SWISS K
// WHEELPOS[1] REPRESENTS LEFTMOST LETTER ON M3
// WHEELPOS[2] REPRESENTS MIDDLE LETTER
// WHEELPOS[3] REPRESENTS RIGHTMOST LETTER
byte ROTORPOS[4]; // ROTORPOS[0] REPRESENTS LEFTMOST ROTOR SETTING, ONLY ON M4, OTHERWISE UKW ON ROCKET, D, & SWISS K
// ROTORPOS[1] REPRESENTS LEFTMOST ROTOR SETTING ON M3
// ROTORPOS[2] REPRESENTS MIDDLE ROTOR SETTING
// ROTORPOS[3] REPRESENTS RIGHTMOST ROTOR SETTING
} EnigmaData;
EnigmaData EnigmaConfigData;
EnigmaData EnigmaCurrentData;
typedef enum
SPLASH_STATE = 0, OPERATE_STATE, CONFIG_STATE
} ENIGMA_STATE;
ENIGMA_STATE enigma_state = SPLASH_STATE;
#define IS_PRESSED true
#define NOT_PRESSED false
const int BASE_X = 11; // the x-value origin of the top-left corner of the
// brass-colored rectangle containing the rotor letter
// - used for rotor-relative location calculations
const int BASE_Y = 37; // the y-value origin of the top-left corner of the
const int KEY_ROW_1 = 225;
const int KEY_ROW_2 = 255;
const int KEY_ROW_3 = 285;
const int LIGHT_ROW_1 = 135;
const int LIGHT_ROW_2 = 165;
const int LIGHT_ROW_3 = 195;
const int TAPE_LENGTH = 40; // number of characters printed on tape
char tape_data[TAPE_LENGTH];
int tape_group_size = 5;
int tape_group_counter = 0;
char start_plug = 0;
const int locs_x[] =
31, // A
144, // B
94, // C
81, // D
69, // E
106, // F
131, // G
156, // H
194, // I
181, // J
206, // K
219, // L
194, // M
169, // N
219, // O
19, // P
19, // Q
94, // R
56, // S
119, // T
169, // U
119, // V
44, // W
69, // X
44, // Y
144 // Z
// add a character to the tape
void add_char_to_tape(char ch)
for (int i = 1; i < TAPE_LENGTH; i++)
tape_data[i-1] = tape_data[i];
tape_data[TAPE_LENGTH-1] = ch;
if (tape_group_size > 0)
tape_group_counter++;
if ((tape_group_size != 0) && (tape_group_counter == tape_group_size))
tape_data[TAPE_LENGTH-1] = ' ';
draw_tape();
} // add_char_to_tape()
// add a plug wire in config
void add_config_plug(char PlugKey1, char PlugKey2)
EnigmaConfigData.STECKER[PlugKey1 - 65] = PlugKey2;
EnigmaConfigData.STECKER[PlugKey2 - 65] = PlugKey1;
draw_config_plugboard();
} // add_config_plug()
// handle the stecker
void calculate_stecker(void)
for (byte i = 0; i < 26; i++)
EffSTECKER[i] = EnigmaCurrentData.STECKER[i];
// this is a "convenient" place to print the machine type to the serial monitor port
// right before printing out the contents of all of the wheels
#ifdef SERIAL_MODE
show_machine_over_serial();
#endif
} // calculate_stecker()
// clear the tape data
void clear_tape(void)
for (int i=0; i < TAPE_LENGTH; i++)
tape_data[i] = ' ';
draw_tape();
} // clear_tape()
// decrement a wheel position
void decrement_wheel(int wheel)
EnigmaCurrentData.WHEELPOS[wheel]--;
if ((EnigmaCurrentData.WHEELPOS[wheel] < 'A') || (EnigmaCurrentData.WHEELPOS[wheel] > 'Z'))
EnigmaCurrentData.WHEELPOS[wheel] = 'Z';
draw_rotor_letters();
} // decrement_wheel()
// draw the variable portions of the config display
void draw_config_display(void)
// draw config machine type
tft.fillRect(170, 85, 70, 15, CYAN);
tft.setTextSize(1);
tft.setCursor(178, 89);
tft.setTextColor( BLACK);
print_machine_type();
draw_config_reflector();
draw_config_tape_group_size();
draw_config_wheels();
draw_config_rings();
draw_config_setup();
} // draw_config_display()
// draw the plugboard in config
void draw_config_plugboard(void)
char ch = 'A';
if ((EnigmaConfigData.machine_type == MACHINE_TYPE_M3) || (EnigmaConfigData.machine_type == MACHINE_TYPE_M4))
tft.setTextSize(2);
for (int i = 0; i < 13; i++)
if (EnigmaConfigData.STECKER[i] != ch)
tft.fillRect((i * 18) + 5, 195, 14, 18, MAGENTA);
tft.fillRect((i * 18) + 5, 215, 14, 18, MAGENTA);
if (start_plug == ch)
tft.fillRect((i * 18) + 5, 195, 14, 18, ORANGE);
tft.fillRect((i * 18) + 5, 195, 14, 18, CYAN);
tft.fillRect((i * 18) + 5, 215, 14, 18, MEDIUM_GRAY);
tft.setCursor((i * 18) + 7, 197);
tft.print(ch);
tft.setCursor((i * 18) + 7, 217);
tft.print(EnigmaConfigData.STECKER[i]);
ch++;
for (int i = 13; i < 26; i++)
tft.fillRect(((i - 13) * 18) + 5, 240, 14, 18, MAGENTA);
tft.fillRect(((i - 13) * 18) + 5, 260, 14, 18, MAGENTA);
tft.fillRect(((i - 13) * 18) + 5, 240, 14, 18, ORANGE);
tft.fillRect(((i - 13) * 18) + 5, 240, 14, 18, CYAN);
tft.fillRect(((i - 13) * 18) + 5, 260, 14, 18, MEDIUM_GRAY);
tft.setCursor(((i - 13) * 18) + 7, 242);
tft.print(ch);
tft.setCursor(((i - 13) * 18) + 7, 262);
ch++;
// erase plugboard area
for (int y = 190; y < 280; y++)
tft.drawFastHLine(0, y, 240, BLACK);
for (int x = random(7); x < 240; x+=random(7)+1)
int r = random(10);
if (r < 2)
tft.drawPixel(x, y, SHADOW_GRAY);
if (r < 4)
tft.drawPixel(x, y, DARK_GRAY);
if (r < 7)
tft.drawPixel(x, y, MEDIUM_GRAY);
} // draw_config_plugboard()
// draw the reflector in config
void draw_config_reflector(void)
tft.fillRect(170, 105, 70, 15, CYAN);
tft.setTextSize(1);
tft.setCursor(178, 109);
switch (EnigmaConfigData.WHEELTYPE[5])
case USE_ROTOR_UKWA:
case USE_ROTOR_UKWD:
case USE_ROTOR_UKWR:
case USE_ROTOR_UKWS:
tft.print(" A");
case USE_ROTOR_UKWB:
tft.print(" B");
case USE_ROTOR_UKWC:
tft.print(" C");
case USE_ROTOR_UKWBD:
tft.print(" Thin B");
case USE_ROTOR_UKWCD:
tft.print(" Thin C");
} // draw_config_reflector()
// draw the rings in config
void draw_config_rings(void)
tft.setTextSize(1);
if (EnigmaConfigData.machine_type == MACHINE_TYPE_M3)
tft.fillRect(110, 170, 25, 15, MEDIUM_GRAY);
tft.fillRect(110, 170, 25, 15, CYAN);
tft.fillRect(140, 170, 25, 15, CYAN);
tft.fillRect(170, 170, 25, 15, CYAN);
tft.fillRect(200, 170, 25, 15, CYAN);
if (EnigmaConfigData.machine_type != MACHINE_TYPE_M3)
tft.setCursor(117, 174);
tft.print(EnigmaConfigData.ROTORPOS[0] / 10);
tft.print(EnigmaConfigData.ROTORPOS[0] % 10);
tft.setCursor(147, 174);
tft.print(EnigmaConfigData.ROTORPOS[1] / 10);
tft.print(EnigmaConfigData.ROTORPOS[1] % 10);
tft.setCursor(177, 174);
tft.print(EnigmaConfigData.ROTORPOS[2] / 10);
tft.print(EnigmaConfigData.ROTORPOS[2] % 10);
tft.setCursor(207, 174);
tft.print(EnigmaConfigData.ROTORPOS[3] / 10);
tft.print(EnigmaConfigData.ROTORPOS[3] % 10);
} // draw_config_rings()
// draw the rotor numbers in config
void draw_config_rotor_numbers(void)
byte rotor;
int base_x = 120;
for (int i = 0; i < 4; i++, base_x += 30)
rotor = EnigmaConfigData.WHEELTYPE[4 - i];
switch (rotor)
case USE_ROTOR_1:
tft.setCursor(base_x, 154);
tft.print("I");
case USE_ROTOR_D1:
tft.setCursor(base_x - 3, 154);
tft.print("ID");
case USE_ROTOR_R1:
tft.print("IR");
case USE_ROTOR_S1:
tft.print("IS");
case USE_ROTOR_2:
tft.print("II");
case USE_ROTOR_D2:
tft.setCursor(base_x - 6, 154);
tft.print("IID");
case USE_ROTOR_R2:
tft.print("IIR");
case USE_ROTOR_S2:
tft.print("IIS");
case USE_ROTOR_3:
tft.print("III");
case USE_ROTOR_D3:
tft.setCursor(base_x - 9, 154);
tft.print("IIID");
case USE_ROTOR_R3:
tft.print("IIIR");
case USE_ROTOR_S3:
tft.print("IIIS");
case USE_ROTOR_4:
tft.print("IV");
case USE_ROTOR_5:
tft.print("V");
case USE_ROTOR_6:
tft.print("VI");
case USE_ROTOR_7:
tft.print("VII");
case USE_ROTOR_8:
tft.print("VIII");
case USE_ROTOR_B:
if (EnigmaConfigData.machine_type == MACHINE_TYPE_M4)
tft.print("B");
case USE_ROTOR_G:
tft.print("G");
} // draw_config_rotor_numbers()
// draw pre-defined setups in config
void draw_config_setup(void)
tft.fillRect(80, 40, 102, 30, CYAN);
tft.setTextSize(1);
tft.setCursor(83, 51);
switch (config_setup)
case CONFIG_M3_1939:
tft.print("STANDARD M3 1939");
case CONFIG_EXAMPLE_1930:
tft.print(" EXAMPLE 1930");
case CONFIG_ENIGMA_D:
tft.print(" ENIGMA D");
case CONFIG_ROCKET_K_RAILWAY:
tft.print("ROCKET K RAILWAY");
case CONFIG_SWISS_K:
tft.print(" SWISS K");
case CONFIG_TURING_1940:
tft.print(" TURING 1940");
case CONFIG_BARBAROSA_1941:
tft.print(" BARBAROSA 1941");
case CONFIG_M4_1942:
tft.print("STANDARD M4 1942");
case CONFIG_U264_1942:
tft.print(" U-264 1942");
case CONFIG_SCHARNHORST_1943:
tft.print("SCHARNHORST 1943");
} // draw_config_setup()
// draw the tape groups in config
void draw_config_tape_group_size(void)
tft.fillRect(170, 125, 70, 15, CYAN);
tft.setTextSize(1);
tft.setCursor(178, 129);
if (tape_group_size == 0)
tft.print(" NONE");
tft.print(" ");
tft.print(tape_group_size);
} // draw_config_tape_group_size()
// draw the wheels in config
void draw_config_wheels(void)
if (EnigmaConfigData.machine_type != MACHINE_TYPE_M4)
tft.fillRect(110, 150, 25, 15, MEDIUM_GRAY);
tft.fillRect(110, 150, 25, 15, CYAN);
tft.fillRect(140, 150, 25, 15, CYAN);
tft.fillRect(170, 150, 25, 15, CYAN);
tft.fillRect(200, 150, 25, 15, CYAN);
tft.setTextSize(1);
draw_config_rotor_numbers();
} // draw_config_wheels()
// draw the entire operational display
void draw_display(void)
switch (enigma_state)
case SPLASH_STATE:
erase_background();
// draw the Enigma logo (2x size)
const char *logobptr PROGMEM = (const char PROGMEM *)LOGOX2;
int pixel_x, pixel_y, px, ndx = 0;
for (byte y = 0; y < 50; y++)
for (byte x = 0; x < 15; x++)
pixel_x = 60 + x * 8;
pixel_y = 5 + y;
px = pgm_read_byte(logobptr + ndx);
for (byte i = 0; i < 8; i++)
if ((px >> (7 - i)) & 0x01)
tft.drawPixel(pixel_x + i, pixel_y, WHITE);
ndx++;
tft.setTextColor( YELLOW);
tft.setTextSize(2);
tft.setCursor(15, 70);
tft.println(TITLE);
tft.setTextColor( GREEN);
tft.setCursor(15, 100);
tft.print(VERSION0);
tft.println(VERSION1);
// tft.setCursor(15, 120);
// tft.println(VERSION2);
tft.setTextColor( CYAN);
tft.setTextSize(1);
tft.setCursor(1, 150);
tft.println(CREDIT1);
tft.setTextColor( ORANGE);
tft.setCursor(5, 295);
tft.println(TAPSTART);
#ifdef SERIAL_MODE
show_init_over_serial();
#endif
case OPERATE_STATE:
erase_background();
tft.setTextSize(1);
tft.setCursor(182, 10);
// draw the rotors
for (int i = 0; i < 4; i++)
if (!((EnigmaCurrentData.machine_type == MACHINE_TYPE_M3) && (i == 0)))
tft.fillRect(BASE_X - 11 + (i * 40), BASE_Y - 12, 36, 44, LIGHT_GRAY);
tft.drawRect(BASE_X - 2 + (i * 40), BASE_Y - 1, 18, 22, BLACK);
tft.drawRect(BASE_X - 3 + (i * 40), BASE_Y - 2, 20, 24, BLACK);
tft.drawRect(BASE_X - 4 + (i * 40), BASE_Y - 3, 22, 26, LIGHT_GRAY);
tft.drawRect(BASE_X - 5 + (i * 40), BASE_Y - 4, 24, 28, LIGHT_GRAY);
tft.drawRect(BASE_X - 6 + (i * 40), BASE_Y - 5, 26, 30, DARK_GRAY);
tft.drawRect(BASE_X - 7 + (i * 40), BASE_Y - 6, 28, 32, DARK_GRAY);
tft.drawRect(BASE_X - 8 + (i * 40), BASE_Y - 7, 30, 34, DARK_GRAY);
tft.fillCircle(BASE_X + 6 + (i * 40), BASE_Y - 25, 12, LIGHT_GRAY);
tft.fillCircle(BASE_X + 6 + (i * 40), BASE_Y + 44, 12, LIGHT_GRAY);
for (int x = 0; x < 14; x++)
tft.drawLine(BASE_X - 7 + (i * 40), BASE_Y - 26, BASE_X - 10 + x + (i * 40), BASE_Y - 13, LIGHT_GRAY);
tft.drawLine(BASE_X + 19 + (i * 40), BASE_Y - 26, BASE_X + 10 + x + (i * 40), BASE_Y - 13, LIGHT_GRAY);
tft.drawLine(BASE_X - 7 + (i * 40), BASE_Y + 45, BASE_X - 10 + x + (i * 40), BASE_Y + 32, LIGHT_GRAY);
tft.drawLine(BASE_X + 19 + (i * 40), BASE_Y + 45, BASE_X + 10 + x + (i * 40), BASE_Y + 32, LIGHT_GRAY);
tft.drawCircle(BASE_X + 6 + (i * 40), BASE_Y - 29, 6, BLACK);
tft.fillCircle(BASE_X + 6 + (i * 40), BASE_Y - 29, 5, DARK_GRAY);
tft.fillCircle(BASE_X + 6 + (i * 40), BASE_Y - 29, 3, MEDIUM_GRAY);
tft.drawCircle(BASE_X + 6 + (i * 40), BASE_Y + 48, 6, BLACK);
tft.fillCircle(BASE_X + 6 + (i * 40), BASE_Y + 48, 5, DARK_GRAY);
tft.fillCircle(BASE_X + 6 + (i * 40), BASE_Y + 48, 3, MEDIUM_GRAY);
tft.drawLine(BASE_X + 3 + (i * 40), BASE_Y - 29, BASE_X + 9 + (i * 40), BASE_Y - 29, BLACK);
tft.drawLine(BASE_X + 3 + (i * 40), BASE_Y + 48, BASE_X + 9 + (i * 40), BASE_Y + 48, BLACK);
// draw the Enigma logo (1x size)
const char *logobptr PROGMEM = (const char PROGMEM *)LOGOX1;
for (byte y = 0; y < 25; y++)
for (byte x = 0; x < 8; x++)
pixel_x = 170 + x * 8;
pixel_y = 30 + y;
ndx++;
tft.drawRect(168, 65, 64, 18, LIGHT_GRAY);
tft.drawRect(169, 66, 62, 16, LIGHT_GRAY);
tft.drawRect(170, 67, 60, 14, LIGHT_GRAY);
tft.fillRect(171, 68, 58, 12, BLACK);
tft.setTextSize(1);
tft.setCursor(174, 70);
for (int ch = 'A'; ch <= 'Z'; ch++)
draw_lights(ch, NOT_PRESSED);
draw_keys(ch, NOT_PRESSED);
clear_tape();
// draw the operational plugboard
char ch = 'A';
tft.setTextSize(1);
for (int i = 0; i < 26; i++)
if (EnigmaCurrentData.STECKER[i] != ch)
tft.fillRect((i * 9) + 3, 300, 7, 9, MAGENTA);
tft.fillRect((i * 9) + 3, 311, 7, 9, MAGENTA);
tft.fillRect((i * 9) + 3, 300, 7, 9, LIGHT_GRAY);
tft.fillRect((i * 9) + 3, 311, 7, 9, MEDIUM_GRAY);
tft.setCursor((i * 9) + 4, 301);
tft.print(ch);
tft.setCursor((i * 9) + 4, 312);
tft.print(EnigmaCurrentData.STECKER[i]);
ch++;
case CONFIG_STATE:
erase_background();
tft.setTextSize(1);
tft.setCursor(195, 10);
tft.setTextSize(2);
tft.setCursor(88, 7);
tft.print("CONFIG");
tft.drawRect(75, 1, 100, 26, RED);
tft.drawRect(76, 2, 98, 24, RED);
tft.setTextSize(2);
tft.setCursor(10, 85);
tft.print("Machine Type");
tft.setTextSize(2);
tft.setCursor(10, 105);
tft.print("Reflector");
tft.setTextSize(2);
tft.setCursor(10, 125);
tft.print("Tape Groups");
tft.setTextSize(2);
tft.setCursor(10, 150);
tft.print("Wheels");
tft.setTextSize(2);
tft.setCursor(10, 170);
tft.print("Rings");
tft.setTextSize(2);
tft.setCursor(10, 39);
tft.print("Quick");
tft.setCursor(10, 57);
tft.print("Setup");
draw_config_display();
tft.setTextSize(1);
tft.fillRect(190, 40, 50, 30, ORANGE);
tft.drawRect(192, 42, 46, 26, BLACK);
tft.setCursor(203, 51);
tft.print("LOAD");
tft.fillRect(30, 290, 60, 30, RED);
tft.drawRect(32, 292, 56, 26, BLACK);
tft.setCursor(40, 301);
tft.print("DISCARD");
tft.fillRect(150, 290, 60, 30, GREEN);
tft.drawRect(152, 292, 56, 26, BLACK);
tft.setCursor(157, 301);
tft.print("ACTIVATE");
} // draw_display()
// draw the keyboard
void draw_keys(char ch, boolean is_pressed)
int key_locs_y[26] =
KEY_ROW_2, // A
KEY_ROW_3, // B
KEY_ROW_3, // C
KEY_ROW_2, // D
KEY_ROW_1, // E
KEY_ROW_2, // F
KEY_ROW_2, // G
KEY_ROW_2, // H
KEY_ROW_1, // I
KEY_ROW_2, // J
KEY_ROW_2, // K
KEY_ROW_3, // L
KEY_ROW_3, // M
KEY_ROW_3, // N
KEY_ROW_1, // O
KEY_ROW_3, // P
KEY_ROW_1, // Q
KEY_ROW_1, // R
KEY_ROW_2, // S
KEY_ROW_1, // T
KEY_ROW_1, // U
KEY_ROW_3, // V
KEY_ROW_1, // W
KEY_ROW_3, // X
KEY_ROW_3, // Y
KEY_ROW_1 // Z
int index = ch - 'A';
if (is_pressed)
tft.fillCircle(locs_x[index], key_locs_y[index], 9, RED);
tft.drawChar(locs_x[index] - 5, key_locs_y[index] - 6, ch, WHITE, RED, 2);
tft.fillCircle(locs_x[index], key_locs_y[index], 9, BLACK);
tft.drawChar(locs_x[index] - 5, key_locs_y[index] - 6, ch, WHITE, BLACK, 2);
tft.drawCircle(locs_x[index], key_locs_y[index], 10, LIGHT_GRAY);
tft.drawCircle(locs_x[index], key_locs_y[index], 11, LIGHT_GRAY);
} // draw_keys()
// draw the indicator lights
void draw_lights(char ch, boolean is_pressed)
int light_locs_y[26] =
LIGHT_ROW_2, // A
LIGHT_ROW_3, // B
LIGHT_ROW_3, // C
LIGHT_ROW_2, // D
LIGHT_ROW_1, // E
LIGHT_ROW_2, // F
LIGHT_ROW_2, // G
LIGHT_ROW_2, // H
LIGHT_ROW_1, // I
LIGHT_ROW_2, // J
LIGHT_ROW_2, // K
LIGHT_ROW_3, // L
LIGHT_ROW_3, // M
LIGHT_ROW_3, // N
LIGHT_ROW_1, // O
LIGHT_ROW_3, // P
LIGHT_ROW_1, // Q
LIGHT_ROW_1, // R
LIGHT_ROW_2, // S
LIGHT_ROW_1, // T
LIGHT_ROW_1, // U
LIGHT_ROW_3, // V
LIGHT_ROW_1, // W
LIGHT_ROW_3, // X
LIGHT_ROW_3, // Y
LIGHT_ROW_1 // Z
if (is_pressed)
tft.fillCircle(locs_x[index], light_locs_y[index], 9, MEDIUM_GRAY);
tft.drawChar(locs_x[index] - 5, light_locs_y[index] - 6, ch, YELLOW, MEDIUM_GRAY, 2);
tft.fillCircle(locs_x[index], light_locs_y[index], 9, BLACK);
tft.drawChar(locs_x[index] - 5, light_locs_y[index] - 6, ch, SHADOW_GRAY, BLACK, 2);
tft.drawCircle(locs_x[index], light_locs_y[index], 10, MEDIUM_GRAY);
tft.drawCircle(locs_x[index], light_locs_y[index], 11, MEDIUM_GRAY);
} // draw_lights()
// draw the letters in the rotors
void draw_rotor_letters(void)
if (EnigmaCurrentData.machine_type != MACHINE_TYPE_M3)
tft.fillRect(BASE_X, BASE_Y, 14, 20, BRASS);
tft.drawChar(BASE_X + 2, BASE_Y + 3, EnigmaCurrentData.WHEELPOS[0], BLACK, BRASS, 2);
for (int i = 1; i < 4; i++)
tft.fillRect(BASE_X + (i * 40), BASE_Y, 14, 20, BRASS);
tft.drawChar(BASE_X + 2 + (i * 40), BASE_Y + 3, EnigmaCurrentData.WHEELPOS[i], BLACK, BRASS, 2);
} // draw_rotor_letters
// draw the tape
void draw_tape(void)
int space_counter = 0;
while (tape_data[space_counter] == ' ')
space_counter++;
tft.fillRect(0, 100, 240, 15, SHADOW_GRAY);
if (space_counter == 0)
tft.fillRect(0, 100, 240, 15, PAPER);
tft.fillRect((space_counter - 1) * 6, 100, 240, 15, PAPER);
tft.drawPixel((space_counter - 1) * 6 - 1, 102, PAPER);
tft.drawPixel((space_counter - 1) * 6 - 2, 103, PAPER);
tft.drawPixel((space_counter - 1) * 6 - 1, 105, PAPER);
tft.drawPixel((space_counter - 1) * 6 - 2, 106, PAPER);
tft.drawPixel((space_counter - 1) * 6 - 1, 108, PAPER);
tft.drawPixel((space_counter - 1) * 6 - 2, 109, PAPER);
tft.drawPixel((space_counter - 1) * 6 - 1, 111, PAPER);
tft.drawPixel((space_counter - 1) * 6 - 2, 112, PAPER);
tft.setCursor(0, 104);
tft.setTextSize(1);
tft.setTextColor( MEDIUM_GRAY);
for (int i = 0; i < TAPE_LENGTH; i++)
tft.print(tape_data[i]);
} // draw_tape()
// calculate the letter translation
char encode_key(char key)
const char *charptr PROGMEM = (const char PROGMEM *)WHEELSF;
char k, k1;
unsigned int wheeltype;
#ifdef SERIAL_MODE
serial_monitor(0);
serial_monitor(key);
#endif
k = EffSTECKER[key - 'A'];
#ifdef SERIAL_MODE
serial_monitor(k);
#endif
for (byte i = 0; i < 6; i++)
if (EnigmaCurrentData.WHEELTYPE[i] != 0)
if ((i > 0) && (i < 5))
byte p = EnigmaCurrentData.WHEELPOS[4 - i] - (EnigmaCurrentData.ROTORPOS[4 - i] - 1);
if (p < 'A')
p += 26;
k += (p - 'A');
// use WHEELPOS[0] & ROTORPOS[0] for UKW on Enigma D, Rocket K, & Swiss K
if ((i == 5) &&
((EnigmaCurrentData.machine_type == MACHINE_TYPE_ENIGMA_D) ||
(EnigmaCurrentData.machine_type == MACHINE_TYPE_ROCKET_K) ||
(EnigmaCurrentData.machine_type == MACHINE_TYPE_SWISS_K)))
byte p = EnigmaCurrentData.WHEELPOS[0] - (EnigmaCurrentData.ROTORPOS[0] - 1);
if (p < 'A')
p += 26;
k += (p - 'A');
if (k > 'Z')
k -= ('Z' + 1);
k -= 'A';
wheeltype = ((EnigmaCurrentData.WHEELTYPE[i] - 1) * 28) + k + 2;
k = pgm_read_byte(charptr + wheeltype);
if (p < 'A')
p += 26;
k -= (p - 'A');
if ((i == 5) &&
if (p < 'A')
p += 26;
k -= (p - 'A');
if (k < 'A')
k += 26;
#ifdef SERIAL_MODE
serial_monitor(k);
#endif
// after reflector
for (byte i = 0; i < 5; i++)
if (EnigmaCurrentData.WHEELTYPE[4 - i] != 0)
if (i < 4)
byte p = EnigmaCurrentData.WHEELPOS[i] - (EnigmaCurrentData.ROTORPOS[i] - 1);
if (p < 'A')
p += 26;
k += (p - 'A');
if (k > 'Z')
k -= 26;
wheeltype = (EnigmaCurrentData.WHEELTYPE[4 - i] - 1) * 28;
for (byte j = 0; j < 26; j++)
if ((pgm_read_byte(charptr + wheeltype + j + 2)) == k)
k1 = 'A' + j;
k = k1;
if (i < 4)
if (p < 'A')
p += 26;
k -= (p - 'A');
if (k < 'A')
k += 26;
#ifdef SERIAL_MODE
serial_monitor(k);
#endif
if (EffSTECKER[j] == k)
k1 = 'A' + j;
k = k1;
#ifdef SERIAL_MODE
serial_monitor(k);
#endif
return k;
} // encode_key()
// erase the background to crinkle black/gray
void erase_background(void)
for (int y = 0; y < 320; y++)
int r = random(10);
if (r < 2)
if (r < 4)
if (r < 7)
} // erase_background()
// increment a wheel position
void increment_wheel(int wheel)
EnigmaCurrentData.WHEELPOS[wheel]++;
if ((EnigmaCurrentData.WHEELPOS[wheel] > 'Z') || (EnigmaCurrentData.WHEELPOS[wheel] < 'A'))
EnigmaCurrentData.WHEELPOS[wheel] = 'A';
} // increment_wheel()
// see if it is time to rotate a wheel
bool is_carry(byte wheelType, byte wheelPos)
unsigned int wheeltype = (wheelType - 1) * 28;
byte k1 = pgm_read_byte(charptr + wheeltype);
byte k2 = pgm_read_byte(charptr + wheeltype + 1);
if ((wheelPos == k1) || (wheelPos == k2))
return(true);
return(false);
} // is_carry()
// loop forever
#ifdef SERIAL_MODE
process_serial();
#endif
process_buttons();
} // loop()
// move the wheels with each keypress, but before determining the resulting letter translation
void move_wheels(void)
byte i = 4;
bool carry = true;
do
i--;
if (carry)
EnigmaCurrentData.WHEELPOS[i]++;
if (i > 1)
carry = is_carry(EnigmaCurrentData.WHEELTYPE[4 - i], EnigmaCurrentData.WHEELPOS[i]);
carry = false;
// double stepping on second wheel
if (i == 2)
byte w2 = EnigmaCurrentData.WHEELPOS[2] + 1;
if (w2 > 'Z')
w2 = 'A';
if (is_carry(EnigmaCurrentData.WHEELTYPE[2], w2))
EnigmaCurrentData.WHEELPOS[2]++;
carry = true;
if (EnigmaCurrentData.WHEELPOS[i] > 'Z')
EnigmaCurrentData.WHEELPOS[i] = 'A';
carry = is_carry(EnigmaCurrentData.WHEELTYPE[4 - i], EnigmaCurrentData.WHEELPOS[i]) || carry;
if (i == 1)
carry = false;
} while (i > 0);
} // move_wheels()
// print machine type
void print_machine_type()
switch (EnigmaConfigData.machine_type)
case MACHINE_TYPE_M3:
tft.print("M3 (1939)");
case MACHINE_TYPE_M4:
tft.print("M4 (1942)");
case MACHINE_TYPE_ENIGMA_D:
tft.print("Enigma D");
case MACHINE_TYPE_ROCKET_K:
tft.print("Rocket K");
case MACHINE_TYPE_SWISS_K:
tft.print(" Swiss K");
} // print_machine_type
// detect button presses
void process_buttons()
boolean key_pressed = false;
boolean button_pressed = false;
boolean wait_for_release = false;
char encoded_key;
char pressed_key;
// See if there's any touch data for us
if (ts.bufferEmpty())
return;
// a point object holds x y and z coordinates.
TS_Point p = ts.getPoint();
// Scale from ~0->4000 to tft.width using the calibration #'s
p.x = map(p.x, TS_MINX, TS_MAXX, 0, tft.width());
p.y = map(p.y, TS_MINY, TS_MAXY, 0, tft.height());
// // show where the screen was touched (for debugging purposes)
// tft.fillRect(0, 0, 240, 10, BLACK);
// tft.setTextColor( WHITE);
// tft.setTextSize(1);
// tft.setCursor(80, 0);
// tft.println("X: ");
// tft.setCursor(95, 0);
// tft.println(p.x);
// tft.setCursor(130, 0);
// tft.println("Y: ");
// tft.setCursor(145, 0);
// tft.println(p.y);
// now, empty any buffered data
while (! ts.bufferEmpty())
TS_Point p_discard = ts.getPoint();
case SPLASH_STATE:
if ((p.x >= 0) && (p.x <= 240) && (p.y >= 0) && (p.y <= 320))
button_pressed = true;
wait_for_release = true;
case OPERATE_STATE:
// click on the enigma logo or the machine type to enter config
if ((p.x >= 160) && (p.x <= 240) && (p.y >= 25) && (p.y <= 80))
// clear the tape
if ((p.x >= 0) && (p.x <= 240) && (p.y >= 100) && (p.y <= 115))
// click below the rotors - increment the letter
if ((p.y >= 70) && (p.y < 95))
// click below rotor 1
if ((p.x >= 0) && (p.x < 40))
// click below rotor 2
if ((p.x >= 40) && (p.x < 80))
// click below rotor 3
if ((p.x >= 80) && (p.x < 120))
// click below rotor 4
if ((p.x >= 120) && (p.x < 160))
// click above the rotors - decrement the letter
if ((p.y >= 0) && (p.y < 25))
// click above rotor 1
// click above rotor 2
// click above rotor 3
// click above rotor 4
// first row key is pressed
if ((p.y >= 213) && (p.y <= 237))
// Q is pressed
if ((p.x >= 7) && (p.x <= 31))
pressed_key = 'Q';
encoded_key = process_key_inputs(pressed_key);
key_pressed = true;
// W is pressed
if ((p.x >= 32) && (p.x <= 56))
pressed_key = 'W';
key_pressed = true;
// E is pressed
if ((p.x >= 57) && (p.x <= 81))
pressed_key = 'E';
key_pressed = true;
// R is pressed
if ((p.x >= 82) && (p.x <= 106))
pressed_key = 'R';
key_pressed = true;
// T is pressed
if ((p.x >= 107) && (p.x <= 131))
pressed_key = 'T';
key_pressed = true;
// Z is pressed
if ((p.x >= 132) && (p.x <= 156))
pressed_key = 'Z';
key_pressed = true;
// U is pressed
if ((p.x >= 157) && (p.x <= 181))
pressed_key = 'U';
key_pressed = true;
// I is pressed
if ((p.x >= 182) && (p.x <= 206))
pressed_key = 'I';
key_pressed = true;
// O is pressed
if ((p.x >= 207) && (p.x <= 232))
pressed_key = 'O';
key_pressed = true;
// second row key is pressed
if ((p.y >= 243) && (p.y <= 267))
// A is pressed
if ((p.x >= 19) && (p.x <= 43))
pressed_key = 'A';
key_pressed = true;
// S is pressed
if ((p.x >= 44) && (p.x <= 68))
pressed_key = 'S';
key_pressed = true;
// D is pressed
if ((p.x >= 69) && (p.x <= 93))
pressed_key = 'D';
key_pressed = true;
// F is pressed
if ((p.x >= 94) && (p.x <= 118))
pressed_key = 'F';
key_pressed = true;
// G is pressed
if ((p.x >= 119) && (p.x <= 143))
pressed_key = 'G';
key_pressed = true;
// H is pressed
if ((p.x >= 144) && (p.x <= 168))
pressed_key = 'H';
key_pressed = true;
// J is pressed
if ((p.x >= 169) && (p.x <= 193))
pressed_key = 'J';
key_pressed = true;
// K is pressed
if ((p.x >= 194) && (p.x <= 218))
pressed_key = 'K';
key_pressed = true;
// third row key is pressed
if ((p.y >= 269) && (p.y <= 293))
// P is pressed
pressed_key = 'P';
key_pressed = true;
// Y is pressed
pressed_key = 'Y';
key_pressed = true;
// X is pressed
pressed_key = 'X';
key_pressed = true;
// C is pressed
pressed_key = 'C';
key_pressed = true;
// V is pressed
pressed_key = 'V';
key_pressed = true;
// B is pressed
pressed_key = 'B';
key_pressed = true;
// N is pressed
pressed_key = 'N';
key_pressed = true;
// M is pressed
pressed_key = 'M';
key_pressed = true;
// L is pressed
pressed_key = 'L';
key_pressed = true;
case CONFIG_STATE:
// detect LOAD button
if ((p.x >= 190) && (p.x <= 240) && (p.y >= 45) && (p.y <= 75))
// detect DISCARD button
if ((p.x >= 30) && (p.x <= 90) && (p.y >= 290) && (p.y < 320))
// detect ACTIVATE button
if ((p.x >= 150) && (p.x <= 210) && (p.y >= 290) && (p.y < 320))
// detect machine type button
if ((p.x >= 0) && (p.x <= 240) && (p.y >= 75) && (p.y < 95))
// detect reflector type button
if ((p.x >= 0) && (p.x <= 240) && (p.y >= 95) && (p.y < 115))
// detect tape group size button
if ((p.x >= 0) && (p.x <= 240) && (p.y >= 115) && (p.y < 135))
// detect wheel4 button
if ((p.x >= 110) && (p.x <= 135) && (p.y >= 150) && (p.y < 160))
// detect wheel3 button
if ((p.x >= 140) && (p.x <= 165) && (p.y >= 150) && (p.y < 160))
// detect wheel2 button
if ((p.x >= 170) && (p.x <= 195) && (p.y >= 150) && (p.y < 160))
// detect wheel1 button
if ((p.x >= 200) && (p.x <= 225) && (p.y >= 150) && (p.y < 160))
// detect ring4 button
if ((p.x >= 110) && (p.x <= 135) && (p.y >= 170) && (p.y < 180))
// detect ring3 button
if ((p.x >= 140) && (p.x <= 165) && (p.y >= 170) && (p.y < 180))
// detect ring2 button
if ((p.x >= 170) && (p.x <= 195) && (p.y >= 170) && (p.y < 180))
// detect ring1 button
if ((p.x >= 200) && (p.x <= 225) && (p.y >= 170) && (p.y < 180))
// detect setup type button
if ((p.x >= 0) && (p.x <= 180) && (p.y >= 40) && (p.y <= 70))
// detect rows of plugs
if ((((p.y >= 195) && (p.y <= 235)) || ((p.y >= 240) && (p.y < 280))) && ((EnigmaConfigData.machine_type == MACHINE_TYPE_M3) || (EnigmaConfigData.machine_type == MACHINE_TYPE_M4)))
if ((p.x >= 5) && (p.x <= 19))
if ((p.x >= 23) && (p.x <= 37))
if ((p.x >= 41) && (p.x <= 55))
if ((p.x >= 59) && (p.x <= 73))
if ((p.x >= 77) && (p.x <= 91))
if ((p.x >= 95) && (p.x <= 109))
if ((p.x >= 113) && (p.x <= 127))
if ((p.x >= 131) && (p.x <= 145))
if ((p.x >= 149) && (p.x <= 163))
if ((p.x >= 167) && (p.x <= 181))
if ((p.x >= 185) && (p.x <= 199))
if ((p.x >= 203) && (p.x <= 217))
if ((p.x >= 221) && (p.x <= 235))
if (button_pressed)
boolean debounce = true;
while ((wait_for_release) && (debounce))
while (ts.touched())
TS_Point discard_p = ts.getPoint();
delay(50);
// see if the touch has really gone away,
// or did we just slip through the built-in debounce ??
// if currently not being touched, then empty any buffered data
if (! ts.touched())
debounce = false;
if (key_pressed)
draw_keys(pressed_key, NOT_PRESSED);
draw_lights(encoded_key, NOT_PRESSED);
process_button_inputs(p);
} // process_buttons()
// act on button presses
void process_button_inputs(TS_Point p)
case SPLASH_STATE:
enigma_state = OPERATE_STATE;
// initialize the machine as an M3 (1939) machine by default
EnigmaCurrentData.machine_type = MACHINE_TYPE_M3;
// Rotors (right-to-left)
EnigmaCurrentData.WHEELTYPE[0] = USE_ROTOR_ETW; // ENTRY CONTACTS
EnigmaCurrentData.WHEELTYPE[1] = USE_ROTOR_1; // RIGHT ROTOR (NOTE THE REVERSED ORDER VS THE OTHER ARRAYS !!)
EnigmaCurrentData.WHEELTYPE[2] = USE_ROTOR_2; // MIDDLE ROTOR (NOTE THE REVERSED ORDER VS THE OTHER ARRAYS !!)
EnigmaCurrentData.WHEELTYPE[3] = USE_ROTOR_3; // LEFT ROTOR (NOTE THE REVERSED ORDER VS THE OTHER ARRAYS !!)
EnigmaCurrentData.WHEELTYPE[4] = USE_ROTOR_NONE; // ADDITIONAL WHEEL (M4 only)
EnigmaCurrentData.WHEELTYPE[5] = USE_ROTOR_UKWB; // REFLECTOR
// Initial Rotor Positions
EnigmaCurrentData.WHEELPOS[0] = 'A'; // LEFTMOST LETTER, ONLY ON M4
EnigmaCurrentData.WHEELPOS[1] = 'A'; // LEFTMOST LETTER ON M3
EnigmaCurrentData.WHEELPOS[2] = 'A'; // MIDDLE LETTER
EnigmaCurrentData.WHEELPOS[3] = 'A'; // RIGHTMOST LETTER
// Ring Settings
EnigmaCurrentData.ROTORPOS[0] = 1; // LEFTMOST ROTOR SETTING, ONLY ON M4
EnigmaCurrentData.ROTORPOS[1] = 1; // LEFTMOST ROTOR SETTING ON M3
EnigmaCurrentData.ROTORPOS[2] = 1; // MIDDLE ROTOR SETTING
EnigmaCurrentData.ROTORPOS[3] = 1; // RIGHTMOST ROTOR SETTING
// Initialize stecker with no plugs
remove_all_plugs();
calculate_stecker();
#ifdef SERIAL_MODE
show_rotors_over_serial();
#endif
draw_display();
case OPERATE_STATE:
enigma_state = CONFIG_STATE;
EnigmaConfigData.machine_type = EnigmaCurrentData.machine_type;
for (int i = 0; i < 27; i++)
EnigmaConfigData.STECKER[i] = EnigmaCurrentData.STECKER[i];
for (int i = 0; i < 6; i++)
EnigmaConfigData.WHEELTYPE[i] = EnigmaCurrentData.WHEELTYPE[i];
EnigmaConfigData.WHEELPOS[i] = EnigmaCurrentData.WHEELPOS[i];
EnigmaConfigData.ROTORPOS[i] = EnigmaCurrentData.ROTORPOS[i];
draw_display();
// clear the tape
clear_tape();
increment_wheel(0);
increment_wheel(1);
increment_wheel(2);
increment_wheel(3);
decrement_wheel(0);
decrement_wheel(1);
decrement_wheel(2);
decrement_wheel(3);
case CONFIG_STATE:
// process LOAD button
if ((p.x >= 190) && (p.x <= 240) && (p.y >= 40) && (p.y <= 70))
start_plug = 0; // just in case a plug activity was in progress
// initialize defaults (unless overriden)
EnigmaConfigData.WHEELTYPE[4] = USE_ROTOR_NONE; // ADDITIONAL WHEEL (M4 only)
remove_all_plugs();
EnigmaConfigData.machine_type = MACHINE_TYPE_M3;
EnigmaConfigData.WHEELTYPE[0] = USE_ROTOR_ETW;
EnigmaConfigData.WHEELTYPE[1] = USE_ROTOR_1;
EnigmaConfigData.WHEELTYPE[2] = USE_ROTOR_2;
EnigmaConfigData.WHEELTYPE[3] = USE_ROTOR_3;
EnigmaConfigData.WHEELTYPE[5] = USE_ROTOR_UKWB;
EnigmaConfigData.WHEELPOS[0] = 'A';
EnigmaConfigData.WHEELPOS[1] = 'A';
EnigmaConfigData.WHEELPOS[2] = 'A';
EnigmaConfigData.WHEELPOS[3] = 'A';
// Ring Settings
EnigmaConfigData.ROTORPOS[0] = 1;
EnigmaConfigData.ROTORPOS[1] = 1;
EnigmaConfigData.ROTORPOS[2] = 1;
EnigmaConfigData.ROTORPOS[3] = 1;
EnigmaConfigData.WHEELTYPE[1] = USE_ROTOR_3;
EnigmaConfigData.WHEELTYPE[2] = USE_ROTOR_1;
EnigmaConfigData.WHEELTYPE[3] = USE_ROTOR_2;
EnigmaConfigData.WHEELTYPE[5] = USE_ROTOR_UKWA;
EnigmaConfigData.WHEELPOS[2] = 'B';
EnigmaConfigData.WHEELPOS[3] = 'L';
// Ring Settings
EnigmaConfigData.ROTORPOS[1] = 24;
EnigmaConfigData.ROTORPOS[2] = 13;
EnigmaConfigData.ROTORPOS[3] = 22;
add_config_plug('A', 'M');
add_config_plug('F', 'I');
add_config_plug('N', 'V');
add_config_plug('P', 'S');
add_config_plug('T', 'U');
add_config_plug('W', 'Z');
EnigmaConfigData.machine_type = MACHINE_TYPE_ENIGMA_D;
EnigmaConfigData.WHEELTYPE[0] = USE_ROTOR_ETWD; // ENTRY CONTACTS
EnigmaConfigData.WHEELTYPE[1] = USE_ROTOR_D1; // RIGHT ROTOR (NOTE THE REVERSED ORDER VS THE OTHER ARRAYS !!)
EnigmaConfigData.WHEELTYPE[2] = USE_ROTOR_D2; // MIDDLE ROTOR (NOTE THE REVERSED ORDER VS THE OTHER ARRAYS !!)
EnigmaConfigData.WHEELTYPE[3] = USE_ROTOR_D3; // LEFT ROTOR (NOTE THE REVERSED ORDER VS THE OTHER ARRAYS !!)
EnigmaConfigData.WHEELTYPE[5] = USE_ROTOR_UKWD; // REFLECTOR
EnigmaConfigData.WHEELPOS[0] = 'A'; // LEFTMOST LETTER ON M4
EnigmaConfigData.WHEELPOS[1] = 'A'; // LEFTMOST LETTER ON M3
EnigmaConfigData.WHEELPOS[2] = 'A'; // MIDDLE LETTER
EnigmaConfigData.WHEELPOS[3] = 'A'; // RIGHTMOST LETTER
// Ring Settings
EnigmaConfigData.ROTORPOS[0] = 1; // LEFTMOST ROTOR SETTING ON M4
EnigmaConfigData.ROTORPOS[1] = 1; // LEFTMOST ROTOR SETTING ON M3
EnigmaConfigData.ROTORPOS[2] = 1; // MIDDLE ROTOR SETTING
EnigmaConfigData.ROTORPOS[3] = 1; // RIGHTMOST ROTOR SETTING
EnigmaConfigData.machine_type = MACHINE_TYPE_ROCKET_K;
EnigmaConfigData.WHEELTYPE[0] = USE_ROTOR_ETWR; // ENTRY CONTACTS
EnigmaConfigData.WHEELTYPE[1] = USE_ROTOR_R1; // RIGHT ROTOR (NOTE THE REVERSED ORDER VS THE OTHER ARRAYS !!)
EnigmaConfigData.WHEELTYPE[2] = USE_ROTOR_R2; // MIDDLE ROTOR (NOTE THE REVERSED ORDER VS THE OTHER ARRAYS !!)
EnigmaConfigData.WHEELTYPE[3] = USE_ROTOR_R3; // LEFT ROTOR (NOTE THE REVERSED ORDER VS THE OTHER ARRAYS !!)
EnigmaConfigData.WHEELTYPE[5] = USE_ROTOR_UKWR; // REFLECTOR
// Ring Settings
EnigmaConfigData.machine_type = MACHINE_TYPE_SWISS_K;
EnigmaConfigData.WHEELTYPE[0] = USE_ROTOR_ETWS; // ENTRY CONTACTS
EnigmaConfigData.WHEELTYPE[1] = USE_ROTOR_S1; // RIGHT ROTOR (NOTE THE REVERSED ORDER VS THE OTHER ARRAYS !!)
EnigmaConfigData.WHEELTYPE[2] = USE_ROTOR_S2; // MIDDLE ROTOR (NOTE THE REVERSED ORDER VS THE OTHER ARRAYS !!)
EnigmaConfigData.WHEELTYPE[3] = USE_ROTOR_S3; // LEFT ROTOR (NOTE THE REVERSED ORDER VS THE OTHER ARRAYS !!)
EnigmaConfigData.WHEELTYPE[5] = USE_ROTOR_UKWS; // REFLECTOR
// Ring Settings
EnigmaConfigData.WHEELTYPE[1] = USE_ROTOR_R2; // RIGHT ROTOR (NOTE THE REVERSED ORDER VS THE OTHER ARRAYS !!)
EnigmaConfigData.WHEELTYPE[2] = USE_ROTOR_R1; // MIDDLE ROTOR (NOTE THE REVERSED ORDER VS THE OTHER ARRAYS !!)
EnigmaConfigData.WHEELPOS[0] = 'J'; // LEFTMOST LETTER ON M4
EnigmaConfigData.WHEELPOS[1] = 'E'; // LEFTMOST LETTER ON M3
EnigmaConfigData.WHEELPOS[2] = 'Z'; // MIDDLE LETTER
// Ring Settings
EnigmaConfigData.ROTORPOS[0] = 26; // LEFTMOST ROTOR SETTING ON M4
EnigmaConfigData.ROTORPOS[1] = 17; // LEFTMOST ROTOR SETTING ON M3
EnigmaConfigData.ROTORPOS[2] = 16; // MIDDLE ROTOR SETTING
EnigmaConfigData.ROTORPOS[3] = 13; // RIGHTMOST ROTOR SETTING
EnigmaConfigData.WHEELTYPE[1] = USE_ROTOR_5;
EnigmaConfigData.WHEELTYPE[2] = USE_ROTOR_4;
EnigmaConfigData.WHEELPOS[1] = 'B';
EnigmaConfigData.WHEELPOS[2] = 'L';
// Ring Settings
EnigmaConfigData.ROTORPOS[1] = 2;
EnigmaConfigData.ROTORPOS[2] = 21;
EnigmaConfigData.ROTORPOS[3] = 12;
add_config_plug('A', 'V');
add_config_plug('B', 'S');
add_config_plug('C', 'G');
add_config_plug('D', 'L');
add_config_plug('F', 'U');
add_config_plug('H', 'Z');
add_config_plug('I', 'N');
add_config_plug('K', 'M');
add_config_plug('O', 'W');
add_config_plug('R', 'X');
EnigmaConfigData.machine_type = MACHINE_TYPE_M4;
EnigmaConfigData.WHEELTYPE[0] = USE_ROTOR_ETW; // ENTRY CONTACTS
EnigmaConfigData.WHEELTYPE[1] = USE_ROTOR_1; // RIGHT ROTOR (NOTE THE REVERSED ORDER VS THE OTHER ARRAYS !!)
EnigmaConfigData.WHEELTYPE[2] = USE_ROTOR_2; // MIDDLE ROTOR (NOTE THE REVERSED ORDER VS THE OTHER ARRAYS !!)
EnigmaConfigData.WHEELTYPE[3] = USE_ROTOR_3; // LEFT ROTOR (NOTE THE REVERSED ORDER VS THE OTHER ARRAYS !!)
EnigmaConfigData.WHEELTYPE[4] = USE_ROTOR_B; // ADDITIONAL WHEEL (M4 only)
EnigmaConfigData.WHEELTYPE[5] = USE_ROTOR_UKWBD; // REFLECTOR
// Ring Settings
tape_group_size = 4;
EnigmaConfigData.WHEELTYPE[2] = USE_ROTOR_4; // MIDDLE ROTOR (NOTE THE REVERSED ORDER VS THE OTHER ARRAYS !!)
EnigmaConfigData.WHEELTYPE[3] = USE_ROTOR_2; // LEFT ROTOR (NOTE THE REVERSED ORDER VS THE OTHER ARRAYS !!)
EnigmaConfigData.WHEELPOS[0] = 'V'; // LEFTMOST LETTER ON M4
EnigmaConfigData.WHEELPOS[1] = 'J'; // LEFTMOST LETTER ON M3
EnigmaConfigData.WHEELPOS[2] = 'N'; // MIDDLE LETTER
// Ring Settings
EnigmaConfigData.ROTORPOS[3] = 22; // RIGHTMOST ROTOR SETTING
add_config_plug('A', 'T');
add_config_plug('B', 'L');
add_config_plug('D', 'F');
add_config_plug('G', 'J');
add_config_plug('H', 'M');
add_config_plug('N', 'W');
add_config_plug('O', 'P');
add_config_plug('Q', 'Y');
add_config_plug('R', 'Z');
add_config_plug('V', 'X');
EnigmaConfigData.WHEELTYPE[1] = USE_ROTOR_8; // RIGHT ROTOR (NOTE THE REVERSED ORDER VS THE OTHER ARRAYS !!)
EnigmaConfigData.WHEELTYPE[2] = USE_ROTOR_6; // MIDDLE ROTOR (NOTE THE REVERSED ORDER VS THE OTHER ARRAYS !!)
EnigmaConfigData.WHEELTYPE[5] = USE_ROTOR_UKWB; // REFLECTOR
EnigmaConfigData.WHEELPOS[1] = 'U'; // LEFTMOST LETTER ON M3
EnigmaConfigData.WHEELPOS[3] = 'V'; // RIGHTMOST LETTER
// Ring Settings
EnigmaConfigData.ROTORPOS[2] = 8; // MIDDLE ROTOR SETTING
add_config_plug('A', 'N');
add_config_plug('E', 'Z');
add_config_plug('H', 'K');
add_config_plug('I', 'J');
add_config_plug('L', 'R');
add_config_plug('M', 'Q');
add_config_plug('O', 'T');
add_config_plug('P', 'V');
add_config_plug('S', 'W');
add_config_plug('U', 'X');
// redraw the config display for each config change
// process DISCARD button
#ifdef SERIAL_MODE
#endif
draw_display();
// process ACTIVATE button
EnigmaCurrentData.WHEELTYPE[i] = EnigmaConfigData.WHEELTYPE[i];
EnigmaCurrentData.WHEELPOS[i] = EnigmaConfigData.WHEELPOS[i];
EnigmaCurrentData.ROTORPOS[i] = EnigmaConfigData.ROTORPOS[i];
if (EnigmaConfigData.machine_type != EnigmaCurrentData.machine_type)
EnigmaCurrentData.machine_type = EnigmaConfigData.machine_type;
EnigmaCurrentData.STECKER[i] = EnigmaConfigData.STECKER[i];
#ifdef SERIAL_MODE
#endif
draw_display();
// process machine type button
if (EnigmaConfigData.machine_type != MACHINE_TYPE_SWISS_K)
EnigmaConfigData.machine_type = (MACHINE_TYPE)(((int)EnigmaConfigData.machine_type) + 1);
// common to all (unless overriden)
if ((EnigmaConfigData.WHEELTYPE[5] != USE_ROTOR_UKWA) &&
(EnigmaConfigData.WHEELTYPE[5] != USE_ROTOR_UKWB) &&
(EnigmaConfigData.WHEELTYPE[5] != USE_ROTOR_UKWC))
if ((EnigmaConfigData.WHEELTYPE[3] != USE_ROTOR_1) &&
(EnigmaConfigData.WHEELTYPE[3] != USE_ROTOR_2) &&
(EnigmaConfigData.WHEELTYPE[3] != USE_ROTOR_3))
EnigmaConfigData.WHEELTYPE[3] = USE_ROTOR_1;
if ((EnigmaConfigData.WHEELTYPE[2] != USE_ROTOR_1) &&
(EnigmaConfigData.WHEELTYPE[2] != USE_ROTOR_2) &&
(EnigmaConfigData.WHEELTYPE[2] != USE_ROTOR_3))
if ((EnigmaConfigData.WHEELTYPE[1] != USE_ROTOR_1) &&
(EnigmaConfigData.WHEELTYPE[1] != USE_ROTOR_2) &&
(EnigmaConfigData.WHEELTYPE[1] != USE_ROTOR_3))
if ((EnigmaConfigData.WHEELTYPE[5] != USE_ROTOR_UKWBD) &&
(EnigmaConfigData.WHEELTYPE[5] != USE_ROTOR_UKWCD))
if ((EnigmaConfigData.WHEELTYPE[4] != USE_ROTOR_B) &&
(EnigmaConfigData.WHEELTYPE[4] != USE_ROTOR_G))
if (EnigmaConfigData.WHEELTYPE[5] != USE_ROTOR_UKWD)
if ((EnigmaConfigData.WHEELTYPE[3] != USE_ROTOR_D1) &&
(EnigmaConfigData.WHEELTYPE[3] != USE_ROTOR_D2) &&
(EnigmaConfigData.WHEELTYPE[3] != USE_ROTOR_D3))
EnigmaConfigData.WHEELTYPE[3] = USE_ROTOR_D1;
if ((EnigmaConfigData.WHEELTYPE[2] != USE_ROTOR_D1) &&
(EnigmaConfigData.WHEELTYPE[2] != USE_ROTOR_D2) &&
(EnigmaConfigData.WHEELTYPE[2] != USE_ROTOR_D3))
if ((EnigmaConfigData.WHEELTYPE[1] != USE_ROTOR_D1) &&
(EnigmaConfigData.WHEELTYPE[1] != USE_ROTOR_D2) &&
(EnigmaConfigData.WHEELTYPE[1] != USE_ROTOR_D3))
EnigmaConfigData.WHEELTYPE[1] = USE_ROTOR_D3;
if (EnigmaConfigData.WHEELTYPE[5] != USE_ROTOR_UKWR)
if ((EnigmaConfigData.WHEELTYPE[3] != USE_ROTOR_R1) &&
(EnigmaConfigData.WHEELTYPE[3] != USE_ROTOR_R2) &&
(EnigmaConfigData.WHEELTYPE[3] != USE_ROTOR_R3))
EnigmaConfigData.WHEELTYPE[3] = USE_ROTOR_R1;
if ((EnigmaConfigData.WHEELTYPE[2] != USE_ROTOR_R1) &&
(EnigmaConfigData.WHEELTYPE[2] != USE_ROTOR_R2) &&
(EnigmaConfigData.WHEELTYPE[2] != USE_ROTOR_R3))
if ((EnigmaConfigData.WHEELTYPE[1] != USE_ROTOR_R1) &&
(EnigmaConfigData.WHEELTYPE[1] != USE_ROTOR_R2) &&
(EnigmaConfigData.WHEELTYPE[1] != USE_ROTOR_R3))
EnigmaConfigData.WHEELTYPE[1] = USE_ROTOR_R3;
if (EnigmaConfigData.WHEELTYPE[5] != USE_ROTOR_UKWS)
if ((EnigmaConfigData.WHEELTYPE[3] != USE_ROTOR_S1) &&
(EnigmaConfigData.WHEELTYPE[3] != USE_ROTOR_S2) &&
(EnigmaConfigData.WHEELTYPE[3] != USE_ROTOR_S3))
EnigmaConfigData.WHEELTYPE[3] = USE_ROTOR_S1;
if ((EnigmaConfigData.WHEELTYPE[2] != USE_ROTOR_S1) &&
(EnigmaConfigData.WHEELTYPE[2] != USE_ROTOR_S2) &&
(EnigmaConfigData.WHEELTYPE[2] != USE_ROTOR_S3))
if ((EnigmaConfigData.WHEELTYPE[1] != USE_ROTOR_S1) &&
(EnigmaConfigData.WHEELTYPE[1] != USE_ROTOR_S2) &&
(EnigmaConfigData.WHEELTYPE[1] != USE_ROTOR_S3))
EnigmaConfigData.WHEELTYPE[1] = USE_ROTOR_S3;
// process reflector type button
if (EnigmaConfigData.WHEELTYPE[5] == USE_ROTOR_UKWA)
if (EnigmaConfigData.WHEELTYPE[5] == USE_ROTOR_UKWB)
EnigmaConfigData.WHEELTYPE[5] = USE_ROTOR_UKWC;
if (EnigmaConfigData.WHEELTYPE[5] == USE_ROTOR_UKWBD)
EnigmaConfigData.WHEELTYPE[5] = USE_ROTOR_UKWCD;
// process tape group size button
switch (tape_group_size)
case 0:
tape_group_size = 3;
case 3:
case 4:
case 5:
tape_group_size += 1;
default:
tape_group_size = 0;
// process wheel4 button
if (EnigmaConfigData.WHEELTYPE[4] == USE_ROTOR_B)
EnigmaConfigData.WHEELTYPE[4] = USE_ROTOR_G;
// process wheel3 button
if (EnigmaConfigData.WHEELTYPE[3] < USE_ROTOR_D3)
EnigmaConfigData.WHEELTYPE[3]++;
if (EnigmaConfigData.WHEELTYPE[3] < USE_ROTOR_R3)
if (EnigmaConfigData.WHEELTYPE[3] < USE_ROTOR_S3)
default:
if (EnigmaConfigData.WHEELTYPE[3] < USE_ROTOR_8)
// process wheel2 button
if (EnigmaConfigData.WHEELTYPE[2] < USE_ROTOR_D3)
EnigmaConfigData.WHEELTYPE[2]++;
EnigmaConfigData.WHEELTYPE[2] = USE_ROTOR_D1;
if (EnigmaConfigData.WHEELTYPE[2] < USE_ROTOR_R3)
if (EnigmaConfigData.WHEELTYPE[2] < USE_ROTOR_S3)
EnigmaConfigData.WHEELTYPE[2] = USE_ROTOR_S1;
default:
if (EnigmaConfigData.WHEELTYPE[2] < USE_ROTOR_8)
// process wheel button
if (EnigmaConfigData.WHEELTYPE[1] < USE_ROTOR_D3)
EnigmaConfigData.WHEELTYPE[1]++;
if (EnigmaConfigData.WHEELTYPE[1] < USE_ROTOR_R3)
if (EnigmaConfigData.WHEELTYPE[1] < USE_ROTOR_S3)
default:
if (EnigmaConfigData.WHEELTYPE[1] < USE_ROTOR_8)
// process ring4 button
if (EnigmaConfigData.ROTORPOS[0] < 26)
EnigmaConfigData.ROTORPOS[0]++;
// process ring3 button
if (EnigmaConfigData.ROTORPOS[1] < 26)
EnigmaConfigData.ROTORPOS[1]++;
// process ring2 button
if (EnigmaConfigData.ROTORPOS[2] < 26)
EnigmaConfigData.ROTORPOS[2]++;
// process ring1 button
if (EnigmaConfigData.ROTORPOS[3] < 26)
EnigmaConfigData.ROTORPOS[3]++;
// process setup type button
config_setup++;
if (config_setup > CONFIG_SCHARNHORST_1943)
// detect top row of plugs
if ((p.y >= 195) && (p.y <= 235) && ((EnigmaConfigData.machine_type == MACHINE_TYPE_M3) || (EnigmaConfigData.machine_type == MACHINE_TYPE_M4)))
// process plug A button
process_plug_inputs('A');
process_plug_inputs('B');
process_plug_inputs('C');
process_plug_inputs('D');
process_plug_inputs('E');
process_plug_inputs('F');
process_plug_inputs('G');
process_plug_inputs('H');
process_plug_inputs('I');
process_plug_inputs('J');
process_plug_inputs('K');
process_plug_inputs('L');
process_plug_inputs('M');
// detect second row of plugs
if ((p.y >= 240) && (p.y <= 280) && ((EnigmaConfigData.machine_type == MACHINE_TYPE_M3) || (EnigmaConfigData.machine_type == MACHINE_TYPE_M4)))
process_plug_inputs('N');
process_plug_inputs('O');
process_plug_inputs('P');
process_plug_inputs('Q');
process_plug_inputs('R');
process_plug_inputs('S');
process_plug_inputs('T');
process_plug_inputs('U');
process_plug_inputs('V');
process_plug_inputs('W');
process_plug_inputs('X');
process_plug_inputs('Y');
process_plug_inputs('Z');
} // process_button_inputs()
// act on keypresses
char process_key_inputs(char pressed_key)
char encoded_key;
draw_keys(pressed_key, IS_PRESSED);
move_wheels();
encoded_key = encode_key(pressed_key);
add_char_to_tape(encoded_key);
draw_lights(encoded_key, IS_PRESSED);
return(encoded_key);
} // process_key_inputs()
// act on plug button inputs
void process_plug_inputs(char plug_char)
if (EnigmaConfigData.STECKER[plug_char - 65] != plug_char)
add_config_plug(EnigmaConfigData.STECKER[plug_char - 65], EnigmaConfigData.STECKER[plug_char - 65]);
add_config_plug(plug_char, plug_char);
if (start_plug != 0)
add_config_plug(plug_char, start_plug);
start_plug = 0;
if (start_plug == 0)
start_plug = plug_char;
if (start_plug == plug_char)
start_plug = 0;
start_plug = 0;
} // process_plug_inputs
// process serial inputs & outputs
void process_serial(void)
if (enigma_state == OPERATE_STATE)
if (Serial.available())
KeyPressed = Serial.read();
KeyPressed = KeyPressed & (255 - 32);
if ((KeyPressed > 'A' - 1) && (KeyPressed < 'Z' + 1))
SerialRead = true;
move_wheels();
draw_keys(KeyPressed, IS_PRESSED);
EncodedKey = encode_key(KeyPressed);
add_char_to_tape(EncodedKey);
draw_lights(EncodedKey, IS_PRESSED);
draw_keys(KeyPressed, NOT_PRESSED);
draw_lights(EncodedKey, NOT_PRESSED);
if ((SerialRead) && (!Serial.available()))
SerialRead = false;
} // process_serial()
// take out all plug wires at once
void remove_all_plugs(void)
strcpy(EnigmaCurrentData.STECKER, "ABCDEFGHIJKLMNOPQRSTUVWXYZ");
strcpy(EnigmaConfigData.STECKER, "ABCDEFGHIJKLMNOPQRSTUVWXYZ");
} // remove_all_plugs()
// send the current machine internal state out to serial
void serial_monitor(char k)
static byte SerialMonitorStepIndex;
