I have this code :
#include <WiFi.h>
#include <WiFiUdp.h>
#include <OSCMessage.h>
#include <Arduino.h>
#include <FastLED.h>
#include "M5_EXTIO2.h"
WiFiUDP Udp;
M5_EXTIO2 extio;
#define PIN_LED 21
#define NUM_LEDS 1
CRGB leds[NUM_LEDS];
int adc_0;
int adc_1;
int adc_2;
int adc_3;
int adc_4;
int adc_5;
int adc_6;
int adc_7;
const char* ssid = "LRB WIFI";
const char* pwd = "LRBW1F1!";
const IPAddress ip(192, 168, 0, 207);
const IPAddress gateway(192, 168, 0, 1);
const IPAddress subnet(255, 255, 255, 0);
// for OSC
unsigned int receivePort = 8888;
IPAddress outIp(192, 168, 0, 255);
unsigned int outPort = 7003;
bool ConnectWifi(void)
bool state = true;
int i = 0;
WiFi.begin(ssid, pwd);
WiFi.config(ip, gateway, subnet);
Serial.println("");
Serial.println("Connecting to WiFi");
// Wait for connection
Serial.print("Connecting");
Serial.print(".");
leds[0] = CRGB::Red;
FastLED.show();
delay(200);
leds[0] = CRGB::Black;
FastLED.show();
delay(200);
if (i > 20){
state = false;
i++;
if (state) {
Serial.println("");
Serial.print("Connected to ");
Serial.println(ssid);
Serial.print("IP address: ");
leds[0] = CRGB::Blue;
FastLED.show();
Serial.println("");
Serial.println("Connection failed.");
return state;
delay(2000);
// Setup Serial Monitor
Serial.println("Cocorico!");
FastLED.addLeds<WS2812, PIN_LED, GRB>(leds, NUM_LEDS);
while (!extio.begin(&Wire, 13, 15, 0x45)) { // Initialize EXT.IO2.
Serial.println("extio Connect Error");
delay(100);
extio.setAllPinMode(ADC_INPUT_MODE); // Set all pins to ADC input mode.
ConnectWifi(); // Connect to WiFi
adc_0 = extio.getAnalogInput(0, _12bit);
adc_1 = extio.getAnalogInput(1, _12bit);
adc_2 = extio.getAnalogInput(2, _12bit);
adc_3 = extio.getAnalogInput(3, _12bit);
adc_4 = extio.getAnalogInput(4, _12bit);
adc_5 = extio.getAnalogInput(5, _12bit);
adc_6 = extio.getAnalogInput(6, _12bit);
adc_7 = extio.getAnalogInput(7, _12bit);
OSCMessage msg("/coco/6");
//OSCMessage msg("/coco/piedG");
//OSCMessage msg("/coco/brasD");
//OSCMessage msg("/coco/brasG");
//OSCMessage msg("/coco/dos");
msg.add(adc_0);
msg.add(adc_1);
msg.add(adc_2);
msg.add(adc_3);
msg.add(adc_4);
msg.add(adc_5);
msg.add(adc_6);
msg.add(adc_7);
Udp.beginPacket(outIp, outPort);
msg.send(Udp);
Udp.endPacket();
msg.empty();
delay(33);
It compile well on my Mac, but on my Windows machine it gives me this error :
In file included from c:\Users\Louis R. Bouchard\Documents\Arduino\libraries\FastLED\src/FastLED.h:75,
from C:\Users\Louis R. Bouchard\Desktop\Projets\COCO\Arduino\IOsmall_To_OSC\IOsmall_To_OSC.ino:5:
c:\Users\Louis R. Bouchard\Documents\Arduino\libraries\FastLED\src/fastspi.h:157:23: note: '#pragma message: No hardware SPI pins defined. All SPI access will default to bitbanged output'
157 | # pragma message "No hardware SPI pins defined. All SPI access will default to bitbanged output"
In file included from C:\Users\Louis R. Bouchard\Desktop\Projets\COCO\Arduino\IOsmall_To_OSC\IOsmall_To_OSC.ino:3:
c:\Users\Louis R. Bouchard\Documents\Arduino\libraries\OSC/OSCMessage.h: In instantiation of 'OSCMessage& OSCMessage::add(T) [with T = int]':
C:\Users\Louis R. Bouchard\Desktop\Projets\COCO\Arduino\IOsmall_To_OSC\IOsmall_To_OSC.ino:129:12: required from here
c:\Users\Louis R. Bouchard\Documents\Arduino\libraries\OSC/OSCMessage.h:136:31: error: call of overloaded 'OSCData(int&)' is ambiguous
136 | OSCData * d = new OSCData(datum);
In file included from c:\Users\Louis R. Bouchard\Documents\Arduino\libraries\OSC/OSCMessage.h:29:
c:\Users\Louis R. Bouchard\Documents\Arduino\libraries\OSC/OSCData.h:106:5: note: candidate: 'OSCData::OSCData(boolean)'
106 | OSCData (boolean);
c:\Users\Louis R. Bouchard\Documents\Arduino\libraries\OSC/OSCData.h:102:9: note: candidate: 'OSCData::OSCData(double)'
102 | OSCData (double);
c:\Users\Louis R. Bouchard\Documents\Arduino\libraries\OSC/OSCData.h:101:9: note: candidate: 'OSCData::OSCData(float)'
101 | OSCData (float);
c:\Users\Louis R. Bouchard\Documents\Arduino\libraries\OSC/OSCData.h:100:5: note: candidate: 'OSCData::OSCData(unsigned int)'
100 | OSCData (unsigned int);
c:\Users\Louis R. Bouchard\Documents\Arduino\libraries\OSC/OSCData.h:96:9: note: candidate: 'OSCData::OSCData(int32_t)'
96 | OSCData (int32_t);
c:\Users\Louis R. Bouchard\Documents\Arduino\libraries\OSC/OSCData.h:67:5: note: candidate: 'OSCData::OSCData(char)'
67 | OSCData(char t);
c:\Users\Louis R. Bouchard\Documents\Arduino\libraries\OSC/OSCData.h:57:7: note: candidate: 'constexpr OSCData::OSCData(const OSCData&)'
57 | class OSCData
exit status 1
Compilation error: exit status 1
Someone knows what is wrong with Windows here? I'm using the latest IDE on both.
Thanks!
