Code controls 2 stepper motors without using libraries. Need help! Cannot solve problem: sketch.ino:31:19: error: variable or field '<>' declared void
Dear Forum members, this is the first time I use the Forum, however, I have been using Arduino for a while.
Apologies if I make any mistakes using the Forum, such as choosing wrong category or adressing the wrong participants. My goal was to send a question to the whole Forum in the appropriate category.
I am trying to further develop my coding skills by using functions and arrays, making codes cleaner and more efficient. The code posted below returns several erros of the same kind (example below):
Blockquote
sketch.ino:31:19: error: variable or field 'stepM1Run' declared void
void stepM1Run(stepBM1,stepEM1,amplitudeM1);
sketch.ino:32:19: error: variable or field 'stepM1Run' declared void
void stepM1Run(stepBM1,stepEM1,amplitudeM1) {
Blockquote
I have tried finding solutions for a while now. I have tried moving the functions to the top, bottom, but nothing seems to work. The code controls 2 stepper motors without using libraries. It works perfectly in version one without the functions and arrays.
could you please try to help?
Thank you.
Full code posted below.
// stepper2
// defines pins
const int openSensorPin = 2;
const int closeSensorPin = 3;
const int stepPinM1 = 4;
const int dirPinM1 = 5;
const int stepPinM2 = 9;
const int dirPinM2 = 10;
// defines variables
int stepBM1[13] = {1,2,3,4,5,6,7,8,9,10,11,12,13};
int stepEM1[13] = {1,2,3,4,5,6,7,8,9,10,11,12,13};
int amplitudeM1[13] = {1,2,3,4,5,6,7,8,9,10,11,12,13};
int stepBM2[13] = {1,2,3,4,5,6,7,8,9,10,11,12,13};
int stepEM2[13] = {1,2,3,4,5,6,7,8,9,10,11,12,13};
int amplitudeM2[13] = {1,2,3,4,5,6,7,8,9,10,11,12,13};
int i = 0;
int stepMotorM1 = 0;
int stepMotorM2 = 0;
// Define Functions
     for(stepMotorM1 = int stepBM1; stepMotorM1 < int stepEM1; stepMotorM1++) {
     digitalWrite(stepPinM1,HIGH);
     delayMicroseconds(int amplitudeM1);
     digitalWrite(stepPinM1,LOW);
   void stepM2Run(stepBM2,stepEM2,amplitudeM2);
   void stepM2Run(stepBM2,stepEM2,amplitudeM2){
     for(stepMotorM2 = int stepBM2; stepMotorM2 < int stepEM2; stepMotorM2++) {
     digitalWrite(stepPinM2,HIGH);
     delayMicroseconds(int amplitudeM2);
     digitalWrite(stepPinM2,LOW);
  //sets serial
  // sets pins
  pinMode (openSensorPin,INPUT_PULLUP);
  pinMode (closeSensorPin,INPUT_PULLUP);
  pinMode(stepPinM1,OUTPUT);
  pinMode(dirPinM1,OUTPUT);
  pinMode (stepPinM2,OUTPUT);
  pinMode (dirPinM2,OUTPUT);
  // Open Routine
  if (digitalRead (openSensorPin) == LOW) {
    digitalWrite(dirPinM1,LOW);
    digitalWrite(dirPinM2,LOW);
    for(i=0;i<=12;i++) {
      stepM1Run(stepBM1[i], stepEM1[i], amplitudeM1[i]);
      stepM2Run(stepBM2[i], stepEM2[i], amplitudeM2[i]);
   // Close Routine
   if(digitalRead(closeSensorPin) == LOW); {
    digitalWrite(dirPinM1,HIGH);
    digitalWrite(dirPinM2,HIGH);
if it helps, the original code that works perfectly but is very long and not at all optimized (no functions or arrays) is fully posted below.
Thank you again.
// stepper1
// defines pins
const int stepPinMov = 4;
const int dirPinMov = 5;
const int stepPinExp = 9;
const int dirPinExp = 10;
  // sets pins
  pinMode(stepPinMov,OUTPUT);
  pinMode(dirPinMov,OUTPUT);
  pinMode (stepPinExp,OUTPUT);
  pinMode (dirPinExp,OUTPUT);
 Serial.begin(9600);                                                  // use the serial port
  if (digitalRead (openSensorPin) == LOW) {                           // open door
    digitalWrite(dirPinExp,LOW);                                      // enables the motor to move counterclockwise
    int stepMotorExp = 0;                                             //creates a variable integer called 'stepMotorExp'
    for(stepMotorExp = 0; stepMotorExp < 50; stepMotorExp++) {        // rotates motor (200 pulses for 1 revolution and 2mm linear motion)
    digitalWrite(stepPinExp,HIGH);
    delayMicroseconds(4000);                                          // defines speed
    digitalWrite(stepPinExp,LOW);
    for(stepMotorExp = 50; stepMotorExp < 125; stepMotorExp++) {      // rotates motor (200 pulses for 1 revolution and 2mm linear motion)
    delayMicroseconds(2667);                                          // defines speed
    for(stepMotorExp = 125; stepMotorExp < 250; stepMotorExp++) {     // rotates motor (200 pulses for 1 revolution and 2mm linear motion)
    delayMicroseconds(1600);                                          // defines speed
    for(stepMotorExp = 250; stepMotorExp < 450; stepMotorExp++) {     // rotates motor (200 pulses for 1 revolution and 2mm linear motion)
    delayMicroseconds(1000);                                          // defines speed
    for(stepMotorExp = 450; stepMotorExp < 775; stepMotorExp++) {     // rotates motor (200 pulses for 1 revolution and 2mm linear motion)
    delayMicroseconds(615);                                           // defines speed
    for(stepMotorExp = 775; stepMotorExp < 1250; stepMotorExp++) {    // rotates motor (200 pulses for 1 revolution and 2mm linear motion)
    delayMicroseconds(421);                                           // defines speed
    for(stepMotorExp = 1250; stepMotorExp < 3750; stepMotorExp++) {   // rotates motor (200 pulses for 1 revolution and 2mm linear motion)
    delayMicroseconds(400);                                           // defines speed
    for(stepMotorExp = 3750; stepMotorExp < 4225 ; stepMotorExp++) {  // rotates motor (200 pulses for 1 revolution and 2mm linear motion)
    for(stepMotorExp = 4225; stepMotorExp < 4550; stepMotorExp++) {   // rotates motor (200 pulses for 1 revolution and 2mm linear motion)
    for(stepMotorExp = 4550; stepMotorExp < 4750; stepMotorExp++) {   // rotates motor (200 pulses for 1 revolution and 2mm linear motion)
    for(stepMotorExp = 4750; stepMotorExp < 4875; stepMotorExp++) {   // rotates motor (200 pulses for 1 revolution and 2mm linear motion)
    for(stepMotorExp = 4875; stepMotorExp < 4950; stepMotorExp++) {   // rotates motor (200 pulses for 1 revolution and 2mm linear motion)
    for(stepMotorExp = 4950; stepMotorExp < 5000; stepMotorExp++) {   // rotates motor (200 pulses for 1 revolution and 2mm linear motion)
    delay (500);
    digitalWrite(dirPinMov,LOW);                                      // enables the motor to move counterclockwise
    int stepMotorMov = 0;                                             //creates a variable integer called 'stepMotor'
    for(stepMotorMov = 0; stepMotorMov < 50; stepMotorMov++) {        // rotates motor (200 pulses for 1 revolution and 8mm linear motion)
    digitalWrite(stepPinMov,HIGH);
    digitalWrite(stepPinMov,LOW);
    for(stepMotorMov = 50; stepMotorMov < 125; stepMotorMov++) {      // rotates motor (200 pulses for 1 revolution and 8mm linear motion)
    for(stepMotorMov = 125; stepMotorMov < 250; stepMotorMov++) {     // rotates motor (200 pulses for 1 revolution and 8mm linear motion)
    for(stepMotorMov = 250; stepMotorMov < 450; stepMotorMov++) {     // rotates motor (200 pulses for 1 revolution and 8mm linear motion)
    for(stepMotorMov = 450; stepMotorMov < 775; stepMotorMov++) {     // rotates motor (200 pulses for 1 revolution and 8mm linear motion)
    for(stepMotorMov = 775; stepMotorMov < 1250; stepMotorMov++) {    // rotates motor (200 pulses for 1 revolution and 8mm linear motion)
    for(stepMotorMov = 1250; stepMotorMov < 3750; stepMotorMov++) {   // rotates motor (200 pulses for 1 revolution and 8mm linear motion)
    for(stepMotorMov = 3750; stepMotorMov < 4225 ; stepMotorMov++) {  // rotates motor (200 pulses for 1 revolution and 8mm linear motion)
    for(stepMotorMov = 4225; stepMotorMov < 4550; stepMotorMov++) {   // rotates motor (200 pulses for 1 revolution and 8mm linear motion)
    for(stepMotorMov = 4550; stepMotorMov < 4750; stepMotorMov++) {   // rotates motor (200 pulses for 1 revolution and 8mm linear motion)
    for(stepMotorMov = 4750; stepMotorMov < 4875; stepMotorMov++) {   // rotates motor (200 pulses for 1 revolution and 8mm linear motion)
    for(stepMotorMov = 4875; stepMotorMov < 4950; stepMotorMov++) {     // rotates motor (200 pulses for 1 revolution and 8mm linear motion)
    for(stepMotorMov = 4950; stepMotorMov < 5000; stepMotorMov++) {     // rotates motor (200 pulses for 1 revolution and 8mm linear motion)
  if(digitalRead(closeSensorPin) == LOW) {                          // close door
    digitalWrite(dirPinMov,HIGH);                                    // enables the motor to move counterclockwise
    delay (500);                                                      // half a second delay
    digitalWrite(dirPinExp,HIGH);                                      // enables the motor to move counterclockwise
    int stepMotorExp = 0;                                             //creates a variable integer called 'stepMotor'
    for(stepMotorExp = 0; stepMotorExp < 50; stepMotorExp++) {        // rotates motor (200 pulses for 1 revolution and 8mm linear motion)
    for(stepMotorExp = 50; stepMotorExp < 125; stepMotorExp++) {      // rotates motor (200 pulses for 1 revolution and 8mm linear motion)
    for(stepMotorExp = 125; stepMotorExp < 250; stepMotorExp++) {     // rotates motor (200 pulses for 1 revolution and 8mm linear motion)
    for(stepMotorExp = 250; stepMotorExp < 450; stepMotorExp++) {     // rotates motor (200 pulses for 1 revolution and 8mm linear motion)
    for(stepMotorExp = 450; stepMotorExp < 775; stepMotorExp++) {     // rotates motor (200 pulses for 1 revolution and 8mm linear motion)
    for(stepMotorExp = 775; stepMotorExp < 1250; stepMotorExp++) {    // rotates motor (200 pulses for 1 revolution and 8mm linear motion)
    for(stepMotorExp = 1250; stepMotorExp < 3750; stepMotorExp++) {   // rotates motor (200 pulses for 1 revolution and 8mm linear motion)
    for(stepMotorExp = 3750; stepMotorExp < 4225 ; stepMotorExp++) {  // rotates motor (200 pulses for 1 revolution and 8mm linear motion)
    for(stepMotorExp = 4225; stepMotorExp < 4550; stepMotorExp++) {   // rotates motor (200 pulses for 1 revolution and 8mm linear motion)
    for(stepMotorExp = 4550; stepMotorExp < 4750; stepMotorExp++) {   // rotates motor (200 pulses for 1 revolution and 8mm linear motion)
    for(stepMotorExp = 4750; stepMotorExp < 4875; stepMotorExp++) {   // rotates motor (200 pulses for 1 revolution and 8mm linear motion)
    for(stepMotorExp = 4875; stepMotorExp < 4950; stepMotorExp++) {   // rotates motor (200 pulses for 1 revolution and 8mm linear motion)
    for(stepMotorExp = 4950; stepMotorExp < 5000; stepMotorExp++) {   // rotates motor (200 pulses for 1 revolution and 8mm linear motion)
Thank you for your reply. Yes I have. I wrote the code posted below that works perfectly. However, trying to optimize it, it is the first time I am using arrays and functions. The "int" as you mentioned is a mistake I made using array for the first time. I will remove it and try again.
Thank you again. Would the types replace the "void" or would they go inside the function?
int stepM1Run(stepBM1,stepEM1,amplitudeM1);
   int stepM1Run(stepBM1,stepEM1,amplitudeM1) {
or
void stepM1Run(int stepBM1,int stepEM1,int amplitudeM1);
   void stepM1Run(int stepBM1,int stepEM1,int amplitudeM1) {
I got the sketch to compile correctly after your comments. Full code below. I will try using actual parameters to see if the code actually does what it is supposed to do correctly. If it works well I will post full code here again.
Thank you again.
// stepper2
// defines pins
int i = 0;
// Define Functions
     for(stepMotorM1 = stepBM1; stepMotorM1 < stepEM1; stepMotorM1++) {
     delayMicroseconds(amplitudeM1);
   void stepM2Run(int stepBM2,int stepEM2,int amplitudeM2){
     for(stepMotorM2 = stepBM2; stepMotorM2 < stepEM2; stepMotorM2++) {
     delayMicroseconds(amplitudeM2);
  //sets serial
  // sets pins
  // Open Routine
   // Close Routine
Thank you. I did. That is how I got as far as I did before reaching out. I guess I still made mistakes at this first attempt with functions. Thank you again for your attention. I hope this discussion helps others too.
