Code Error--Exclamation point
I am using Jonah Model's code to read the switch state of a push button switch in my Flash/Arduino LED tester interface.
I get an error on the following line of code:
if (switchState ! lastSwitchState) {
The error reads
In function 'void loop()':
error: expected `)' before '!' token
I am not sure what function the exclamation point has in this script. Does anyone have any suggestions for what I might swap for the exclamation point? When I change it to an equals sign, there is no code error, but the push button is not being recognized AT ALL by Flash or my Processing Serial Proxy.
Thanks---v
The entire Arduino code is as follows:
  • Flash + Arduino LED Tester
  • by Jonah Model jmodel@parsaons.edu
  • modified from ARDUINO CONVERSATION, by beltran berrocal, b@progetto25zero1.com
    int inputInt ; // The incoming serial data is received as an integer
    int switchState = 0; // What is the current switch state?
    int lastSwitchState = 0; // Was the switch previously on, or off?
    int switchPin = 13; // Which digital i/o pin is setup for the switch?
    int potPin = 0; // Which analog pin gets the input from the potentiometer
    int currentPotVal = 0; // What is the current value from the potentiometer
    int lastPotVal = 0; // What was the last value from the potentiometer
    int counter = 0; // Counter for pinging serial port outbound
    // SETUP
    Serial.begin(19200); //setup serial conversation at 19200 baud
    pinMode(switchPin, INPUT); // sets the switch pin as input
    for (int i=0; i<12; i++) {
    pinMode(i, OUTPUT); // set all non-input pins to output
    digitalWrite(i,LOW);
    Serial.println("ready");
    Serial.println(switchState);
    // LOOP
    void loop () {
    // Ping now and then
    if (counter == 5000) {
    counter = 0;
    counter ++ ;
    //------------------------------------------------------------------------ LED LOGIC
    // Get the number of bytes (characters) available for reading over the serial port.
    // Serial.available() will be greater than 0 if any data has come in.
    // (The serial buffer can hold up to 64 bytes)
    if(Serial.available() > 0) {
    //must be a request to light up an LED
    //inputInt should be a number 2-9, but in binary it will come in as 50-57
    inputInt = Serial.read();
    if(inputInt > 50 && inputInt <= 57) {
    //a valid LED signal has been received from Flash
    // convert the byte to an int - getting ready for digitalWrite()
    int outputPort = inputInt-48;
    // Send back the number received as confirmation
    // IMPORTANT NOTE: Use Serial.println(), NOT Serial.print()
    Serial.println(outputPort);
    if(outputPort >= 2 && outputPort <= 9) {
    // turns all the LEDs OFF
    for (int i=2; i<10; i++) {
    // then turns your selected LED ON
    digitalWrite(outputPort, HIGH);
    // when we're done, default the inputInt to nothing
    inputInt = 0;
    //-------------------------------------------------------BINARY LEDS
    // ON
    if(inputInt == 65) {digitalWrite(2, HIGH);}
    if(inputInt == 66) {digitalWrite(3, HIGH);}
    if(inputInt == 67) {digitalWrite(4, HIGH);}
    if(inputInt == 68) {digitalWrite(5, HIGH);}
    if(inputInt == 69) {digitalWrite(6, HIGH);}
    if(inputInt == 70) {digitalWrite(7, HIGH);}
    if(inputInt == 71) {digitalWrite(8, HIGH);}
    if(inputInt == 72) {digitalWrite(9, HIGH);}
    // OFF
    if(inputInt == 97) {digitalWrite(2, LOW);}
    if(inputInt == 98) {digitalWrite(3, LOW);}
    if(inputInt == 99) {digitalWrite(4, LOW);}
    if(inputInt == 100) {digitalWrite(5, LOW);}
    if(inputInt == 101) {digitalWrite(6, LOW);}
    if(inputInt == 102) {digitalWrite(7, LOW);}
    if(inputInt == 103) {digitalWrite(8, LOW);}
    if(inputInt == 104) {digitalWrite(9, LOW);}
    //------------------------------------------------------------------------ SWITCH LOGIC
    // get the current state of the switch from our board
    switchState = digitalRead(switchPin);
    // if the switch has changed states, then let Flash know about it
    if (switchState == 1){
    Serial.println("switchOff");
    else if (switchState == 0){
    Serial.println("switchOn");
    //// now store the state for later comparison
    lastSwitchState = switchState;
    //slows down the visualization: each sentence will be emitted every .5 seconds
    // delay(50);
    //------------------------------------------------------------------------ ANALOG POT LOGIC
    currentPotVal = analogRead(potPin);
    if (currentPotVal < (lastPotVal + 5) && currentPotVal > (lastPotVal - 5) ) {
    Serial.print("potValue");
    Se
I think it should be != (not equals, that is).
I think you are right.
Along these lines:
My Flash LED Model---Processing Serial Code----Arduino TRIO is finally working!
