Thanks so much! I did so. Then it asked me to use the new SoftwareSerial library so I had to change NewSoftSerial to SoftwareSerial.
Now Im getting this error:
LinkSprite_cam_IR.ino: In function 'void SendResetCmd()':
LinkSprite_cam_IR.ino:71:26: error: call of overloaded 'write(int)' is ambiguous
LinkSprite_cam_IR.ino:71:26: note: candidates are:
In file included from LinkSprite_cam_IR.ino:3:0:
/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SoftwareSerial/SoftwareSerial.h:100:18: note: virtual size_t SoftwareSerial::write(uint8_t)
virtual size_t write(uint8_t byte);
Im not sure I understand that at all. Could you help me on that as well?
The write() takes either a byte or an array of bytes and a count.
Literals are interpreted as ints, in the absence of directives (or evidence) to the contrary. Some values can be interpreted more than one way, so the compiler needs help picking the right method.
You changed
mySerial.print(0x00, BYTE);
to
mySerial.write(0x00);
but that is one of the values that can be interpreted multiple ways. You need to help the compiler out:
It compiles now. Unfortunately there seems to be an issue because all I get is blank data in the serial monitor. I mean the Serial Monitor just scrolls up indefinitely but with nothing on screen.
And of course the resulting file on the SD card is 0 bytes.
Here is the full sketch:
/* Linksprite */
//SPITS OUT WHITE SCREEN SERIAL MONITOR SCROLLING DOWN BUT NO DATA SAVED TO SD
#include <SoftwareSerial.h>
byte incomingbyte;
SoftwareSerial mySerial(4,5); //Configure pin 4 and 5 as soft serial port
int a=0x0000,j=0,k=0,count=0; //Read Starting address
uint8_t MH,ML;
boolean EndFlag=0;
void SendResetCmd();
void SendTakePhotoCmd();
void SendReadDataCmd();
void StopTakePhotoCmd();
void setup(){
Serial.begin(19200);
mySerial.begin(38400);
SendResetCmd();
delay(4000); //After reset, wait 2-3 second to send take picture command
SendTakePhotoCmd();
while(mySerial.available()>0)
incomingbyte=mySerial.read();
byte a[32];
while(!EndFlag)
j=0;
k=0;
count=0;
SendReadDataCmd();
delay(25);
k++;
if((k>5)&&(j<32)&&(!EndFlag))
a[j]=incomingbyte;
if((a[j-1]==0xFF)&&(a[j]==0xD9)) //Check if the picture is over
EndFlag=1;
j++;
count++;
for(j=0;j<count;j++)
{ if(a[j]<0x10)
Serial.print("0");
Serial.print(a[j],HEX);
Serial.print(" ");
} //Send jpeg picture over the serial port
while(1);
//Send Reset command
void SendResetCmd()
mySerial.write((byte)0x56);
mySerial.write((byte)0x00);
mySerial.write((byte)0x26);
//Send take picture command
mySerial.write((byte)0x36);
mySerial.write((byte)0x01);
//Read data
MH=a/0x100;
ML=a%0x100;
mySerial.write((byte)0x32);
mySerial.write((byte)0x0c);
mySerial.write((byte)0x0a);
mySerial.write(MH);
mySerial.write(ML);
mySerial.write((byte)0x20);
a+=0x20; //address increases 32£¬set according to buffer size
void StopTakePhotoCmd(){
mySerial.write((byte)0x03);
25 milliseconds to get a response? Is that even in the same universe as reasonable?
k++;
a[j]=incomingbyte;
EndFlag=1;
j++;
count++;
I don't guess it matters whether there is room in the array.
Its a hardware manufacturer's tutorial so i guess they dont bother with little things like checking for array space and as for throwing the data away, I have the data written to an SD card in my other sketch, but in both cases the data is simply not there. I have logged the incomingbyte like so:
You can write to the manufacturer, and tell them that there code is crap, and wait for them to fix it, or fix it yourself.
How can you write the random amounts of unread data to an SD card in another sketch?
We need to see the sketch where you "prove" that you are reading nothing but 0 from the camera, along with a schematic showing how the camera is connected, and a link to the camera.
byte a[32]; // Create an array of 32 elements named a
int ii; // Create a variable named ii of int type
SendResetCmd(); // Send reset command to module
delay(2000); //Wait 2 second to send take picture command
SendTakePhotoCmd(); // Send take a picture command
delay(1000); // Wait 1 second after taking picture command
while(mySerial.available()>0) // while mySerial is available...
incomingbyte=mySerial.read(); // read serial incoming data & store it in "incomingbyte" which is a byte type
and the actual wiring is this one (it includes a tft shield for microSD storage:
The other sketch, as I mentioned, also ends up writing 0 bytes to a file. I never said that I could prove it was getting written anywhere. You're getting all "politician" on me! :-). That sketch is here, but its the same one except that it contains a snippet for writing bytes into a file.
When I said "and as for throwing the data away, I have the data written to an SD card in my other sketch" what I meant was that as opposed to this original sketch, I wasnt just reading the data and throwing it away. I was reading it and then storing it in a file.
Here is that sketch. It is also a sketch from the manufacturer btw:
// www.linksprite.com
// Note:
// 1. SD must be formated to FAT16
// 2. As the buffer of softserial has 64 bytes,
// so the code read 32 bytes each time
// 3. Please add the libaray to the lib path
// * SD card attached to SPI bus as follows:
// * MOSI - pin 11
// * MISO - pin 12
// * CLK - pin 13
// * CS - pin 4
#include <SPI.h>
#include <SD.h>
SoftwareSerial mySerial(5,6); // 5,6 softserial
byte ZERO = 0x00;
byte incomingbyte;
int j=0,k=0,count=0,i=0x0000;
uint8_t MH,ML;
boolean EndFlag=0;
File myFile;
void SendResetCmd()
mySerial.write(0x56);
mySerial.write(ZERO);
mySerial.write(0x26);
/* Set ImageSize :
/* <1> 0x22 : 160*120
/* <2> 0x11 : 320*240
/* <3> 0x00 : 640*480
/* <4> 0x1D : 800*600
/* <5> 0x1C : 1024*768
/* <6> 0x1B : 1280*960
/* <7> 0x21 : 1600*1200
void SetImageSizeCmd(byte Size)
mySerial.write(0x54);
mySerial.write(0x01);
mySerial.write(Size);
/* Set BaudRate :
/* <1>¡¡0xAE : 9600
/* <2>¡¡0x2A : 38400
/* <3>¡¡0x1C : 57600
/* <4>¡¡0x0D : 115200
/* <5>¡¡0xAE : 128000
/* <6>¡¡0x56 : 256000
void SetBaudRateCmd(byte baudrate)
mySerial.write(0x24);
mySerial.write(0x03);
mySerial.write(baudrate);
mySerial.write(0x36);
MH=i/0x100;
ML=i%0x100;
mySerial.write(0x32);
mySerial.write(0x0c);
mySerial.write(0x0a);
mySerial.write(MH);
mySerial.write(ML);
mySerial.write(0x20);
i+=0x20;
while (!Serial)
; // wait for serial port to connect. Needed for Leonardo only
Serial.print("Initializing SD card...");
// On the Ethernet Shield, CS is pin 4. It's set as an output by default.
// Note that even if it's not used as the CS pin, the hardware SS pin
// (10 on most Arduino boards, 53 on the Mega) must be left as an output
// or the SD library functions will not work.
pinMode(10, OUTPUT);
if (!SD.begin(4))
Serial.println("initialization failed!");
return;
Serial.println("initialization done.");
Serial.println("please wait for picture....");
mySerial.begin(115200);
delay(100);
SendResetCmd();
delay(2000);
SetBaudRateCmd(0x2A);
delay(100);
byte a[32];
int ii;
SendResetCmd();
delay(2000); //Wait 2-3 second to send take picture command
SendTakePhotoCmd();
myFile = SD.open("pic.jpg", FILE_WRITE); //The file name should not be too long
while(!EndFlag)
j=0;
k=0;
count=0;
//mySerial.flush();
SendReadDataCmd();
delay(2000);
Serial.print("incoming...");
Serial.print(incomingbyte);
k++;
delay(1); //250 for regular
a[j]=incomingbyte;
if((a[j-1]==0xFF)&&(a[j]==0xD9)) //tell if the picture is finished
EndFlag=1;
j++;
count++;
if(a[j]<0x10) Serial.print("0");
Serial.print(a[j],HEX); // observe the image through serial port
Serial.print(" ");
for(ii=0; ii<count; ii++)
myFile.write(a[ii]);
myFile.close();
Serial.print("Finished writing data to file");
while(1);
Ok in 2 seconds at 38,400 bps, I get 38,400 x 2 = 76,800 bits / 8 = 9,600 bytes. I dont know about this stuff but I guess there is a header and terminal bunch of bits/bytes that are required for messaging which take up 9,600 - 7,800 = 1,800 bytes to get to the 7,800 you mentioned. But ok, so Im taking pictures at 160x120 pixels = 19,200 pixels. Each color pixel takes 24 bits, = 460,800 bits or 57,600 bytes or 57kb.
If I have 2 second delay that would be too short? So I should increase it to 9x that?
What do you mean by:
"You are already blocking because it takes longer to send "incoming..." and a multi-digit number at 115200 than it does to receive one byte."
My addition of the log line incoming... should be removed? But I added that as a debug, the problem was already there. But yes, Ill remove it. I just wanted to see if I could visualize any byte numbers in the serial monitor to make sure "something" or "anything" was coming in.
No the board doesnt have any leds except for the IR leds. But I was looking at the Tx/Rx on the UNO and I saw only the Tx blinking, not the Rx one. So I dont think its receiving anything from the Camera module.
Ok please explain to me why you say this throws away the data?
How many times do you read? How many bytes end up in incomingbyte? If the answers are not the same, what happens to the data that is not in incomingbyte?
There are start and stop bits, so sending a byte requires 10 intervals, not 8.
The delay is not too short. It is 2 seconds too long. Start reading serial data as soon as it arrives.
Surely you don't think that sending serial data takes no time. Serial data is written to a buffer, which is very fast, UNTIL the buffer gets full. Then, print() blocks until data has been shifted out. THAT takes time.
For debugging purposes, it is fine. In the end, it has to go.
The TX and RX LEDs are involved when Serial is sending/receiving data, not the SoftwareSerial instance.
Originally the problem was that I was getting compile errors because of an outdated coding format. This issue was actually solved. Later the problem became 00 as bytes. Sorry but I guess I wanted to leave the original post as notice that the code was outdated for anyone who ran into the problem.
But you're right, I did keep that old thread going until it merged with this one. I apologize.
Delta. I agree that if you look at just that part of the code it seems that way. But later in the sketch it reads the serial again and this time stores it into the array. The complete sketch is here:
You haven't really been able to understand the replies. So you have to either study the program and learn a lot more about C++ at the same time, or start with some easier projects.
